  4. Lifted E30 V2
Lifted E30 V2
    Video #2: "I love how it just dumps right out the hood".
    Everyone agrees 😉
      Oh. Side note. I do know how to shift, but the damn clutch pedal is all weird. I have an E46 flywheel and clutch in it right now, and something must not be appropriate (self adjusting issues?)  because the clutch pedal has two "spots" in it and doesn't release quickly.
      If I get ambitious this weekend I may switch the flywheel and clutch back over to the E stuff.
        Put a huge Cummins sticker on the back window, and some deer skulls and maybe a bowtech sticker. Lets people know you’re not afraid of anything
          Awesome man. Just pure awesome. I need to come check this thing out.
            Got the block heater wired up! Now my block can be warm all winter long!
            I also made up a gauge plate, and went a touch nostalgic on it, it is made out of the license plate that the swapped e30 had on it for it's whole life. Thought it was kind of cool. Holds the glow plug switch as well as a couple gauges. Should do the trick. The super cheap boost gauge is hella bright so that may have to be changed.
            I also modified the throttle brackets and put an e34 cable in the car so the throttle is no longer sketchy, but that doesn't really deserve a picture.
            Next steps involve modifying things from their current place to a place that allows me to get the hood on the car. This is primarily coolant stuff and exhaust.
              Maybe just some window tint on the super bright gauge?
                That bright gauge is comical [emoji16]
                • stealthbimmerS
                  stealthbimmerS
                  stealthbimmer
                  Mask off the numbers and just spray bomb it black
                  1997 328ic
                    I am likely going to put a cover over it or just put the light on a switch. Shall see, for now it will just blind me.
                    My dad asked for this video today, which I kind of forgot about. Always good for a chuckle.
                    I've always thought the noise once I got up there was the tires slipping, but I now see it was the rear bumper touching the ground. Impressive.
                    It looks so much more boring in video!
                      Got the alternator mount figured out the other day, isn't anything great, but it works and drives the water pump just fine.
                      I cut apart the existing power steering brackets as the shape of them caused belt interference with the primary belt, and that was no good.
                      Was going to weld it back together, but realized there isn't much of a need for it. So it shall do for now!
                      Got the appropriate upper radiator hose in, fits much better!
                        does the factory m21 have a block heater??
                          Sure does!
                            The block heater is pretty awesome, that video is even better!!. As im sure you are aware, replace those v-belts before you snap one!
                              It's starting to look better. Though I know it will never look good.
                              Added an air filter to the turbo, as well as a boost controller in the off chance I can get more than waste-gate pressure.
                              Made a mount for the fuel filter as well as installing the late model style expansion tank.
                              I worked on bleeding the cooling system last night and feel pretty confident that I got it right the first go, which is nice.
                              More things to do, weld plate over EGR port on the intake tube (currently has a kinked hose on it), route crank case breather somewhere, create an actual exhaust.
                              Things are nearing completion for the swap! Then it's back to chassis based goodness!
                                Back to daily driver duty in january then eh? Nice work dude, very quick work on this a-typical project
                                  Haha, I actually didn't notice that. The main belt (Water pump and alt.) is new, due to needing a custom length.
                                  The power steering belt is clearly old and should be replaced now that I look at it. Though I could also just wait for it to break lol.
                                  I somewhat fear for starting it in the cold, especially knowing that the starter sticks if it doesn't start. Going to try leaving it outside this Tuesday (high of -1 here....) and see if it starts on its own (fuel gel, battery, tolerances etc) and I guess if it passes that test I may drive it frequently.
                                  The more I drive it the more I want to change the clutch over, so maybe driving it a lot is a good idea.
                                  Thanks for the kind words!
                                    It's Tuesday, did it start?  My gas e36 barely started...
                                      Not sure, the ignition cylinder is a mess and I had taken the key out due to leaving it outside, so I couldn't get the key to turn.
                                      I did peek in the tank and it didn't look too optimistic
                                        Toss a match in the gas tank to warm up the fuel? 👀
                                          ^Meh, why not.
                                          Just ordered an intercooler, because this pig needs more power!
                                          Was driving it around Saturday and attempted to get up to highway speed, and it was painful. I don't have a tach (yet) and wasn't WOT so I guess there may be more in it, but holy crap was it crawling along.
                                          It was fun snapping necks during accel, black smoke coming from the hood.
                                          To do list.
                                          -Tach
                                          -Oil Temp gauge (ordered)
                                          -Intercooler (pipe routing unsure)
                                          -Crank case breather to intake filter
                                          I find to do lists amusing, as this car will never be "done".
