<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rubber floor plug?]]></title><description><![CDATA[<p dir="auto">Figured out why the drivers floorboard kept on getting wet after rain.</p>
<p dir="auto"><img src="http://uploads.tapatalk-cdn.com/20160910/176b853ed0658e82952e6556af1e37be.jpg" alt="176b853ed0658e82952e6556af1e37be.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Seem to be missing a plug. Anyone replaced these or have diy suggestions?</p>
]]></description><link>https://wibimmers.com/topic/4511/rubber-floor-plug</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:36:22 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4511.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Sep 2016 20:20:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rubber floor plug? on Tue, 18 Oct 2016 13:31:47 GMT]]></title><description><![CDATA[<p dir="auto">Most auto parts stores have a "help!" section with various rubber caps and plugs that should fit in there if you cant make it to a dealer.</p>
]]></description><link>https://wibimmers.com/post/73051</link><guid isPermaLink="true">https://wibimmers.com/post/73051</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Tue, 18 Oct 2016 13:31:47 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Tue, 13 Sep 2016 18:57:53 GMT]]></title><description><![CDATA[<p dir="auto">i was going to suggest aluminum foil tape</p>
<p dir="auto">"in the end, all that will be left is cockroaches, Twinkies, and aluminum foil tape (still sticking) in the burning piles of ash. "</p>
<p dir="auto">or something like that.</p>
]]></description><link>https://wibimmers.com/post/71986</link><guid isPermaLink="true">https://wibimmers.com/post/71986</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Tue, 13 Sep 2016 18:57:53 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sun, 11 Sep 2016 21:59:57 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. Avoid the wasps or nuke from a safe distance.</p>
<p dir="auto">I cleaned the pan and patched things up with a piece of sheet steel and seam sealer for the rust hole. We'll see how the gas pedal holds up. Went with a plug and rtv for the drain plug hole. Remembered that I did this with the race car and its held up fine.</p>
]]></description><link>https://wibimmers.com/post/71956</link><guid isPermaLink="true">https://wibimmers.com/post/71956</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sun, 11 Sep 2016 21:59:57 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sun, 11 Sep 2016 20:58:08 GMT]]></title><description><![CDATA[<p dir="auto">I believe that i could cut the patch panel/gas pedal out of my parts car if someone wanted, but it may have to wait for the weather to cool down since i believe there is a wasp nest inside the car or near it.</p>
]]></description><link>https://wibimmers.com/post/71955</link><guid isPermaLink="true">https://wibimmers.com/post/71955</guid><dc:creator><![CDATA[SamHolzmann]]></dc:creator><pubDate>Sun, 11 Sep 2016 20:58:08 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sat, 10 Sep 2016 22:09:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/71938">Earl said:</a></strong></p>
<p dir="auto">The girlfriends gas pedal mount rotted of the floor and somehow works well staying in the carpet lol. I need to tackle that repair there. Cutting the pedal out of a donor car is all I can think of </p>
<p dir="auto">Actually that's not a bad idea. Fab a sleeve over the base of the pedal that's held in place by the carpet.</p>
]]></description><link>https://wibimmers.com/post/71941</link><guid isPermaLink="true">https://wibimmers.com/post/71941</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 10 Sep 2016 22:09:12 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sat, 10 Sep 2016 22:02:48 GMT]]></title><description><![CDATA[<p dir="auto">^^^i did not have a gas pedal issue though</p>
]]></description><link>https://wibimmers.com/post/71940</link><guid isPermaLink="true">https://wibimmers.com/post/71940</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Sat, 10 Sep 2016 22:02:48 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sat, 10 Sep 2016 22:02:10 GMT]]></title><description><![CDATA[<p dir="auto">As crappy as it is to do, could get the bondo fiberglass kits &amp; do the area in question.</p>
<p dir="auto">I did this to my drivers side floor after it was patched with some welds. It does not leak any more.</p>
<p dir="auto">I also tossed my stock carpet because it was disgusting and never dried.</p>
]]></description><link>https://wibimmers.com/post/71939</link><guid isPermaLink="true">https://wibimmers.com/post/71939</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Sat, 10 Sep 2016 22:02:10 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sat, 10 Sep 2016 22:00:32 GMT]]></title><description><![CDATA[<p dir="auto">The girlfriends gas pedal mount rotted of the floor and somehow works well staying in the carpet lol. I need to tackle that repair there. Cutting the pedal out of a donor car is all I can think of</p>
]]></description><link>https://wibimmers.com/post/71938</link><guid isPermaLink="true">https://wibimmers.com/post/71938</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sat, 10 Sep 2016 22:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sat, 10 Sep 2016 21:42:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. Figure I'll patch the floor for the other hole. The metal floor stub piece that the gas pedal fits over is about 3/4 rusted through. Just try to fab a new piece or are there other options for rigging the gas pedal?This is the daily beater so functional ideas win over pretty.</p>
]]></description><link>https://wibimmers.com/post/71935</link><guid isPermaLink="true">https://wibimmers.com/post/71935</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 10 Sep 2016 21:42:25 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sat, 10 Sep 2016 21:11:21 GMT]]></title><description><![CDATA[<p dir="auto">You can order them new. Check <a href="http://realoem.com" rel="nofollow ugc">realoem.com</a> to get the exact part number</p>
]]></description><link>https://wibimmers.com/post/71933</link><guid isPermaLink="true">https://wibimmers.com/post/71933</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sat, 10 Sep 2016 21:11:21 GMT</pubDate></item><item><title><![CDATA[Reply to Rubber floor plug? on Sat, 10 Sep 2016 21:10:25 GMT]]></title><description><![CDATA[<p dir="auto">Looks like I've got bigger issues</p>
<p dir="auto"><img src="http://uploads.tapatalk-cdn.com/20160910/22b66420dcf2fd29e651fde922c66e77.jpg" alt="22b66420dcf2fd29e651fde922c66e77.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/71932</link><guid isPermaLink="true">https://wibimmers.com/post/71932</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 10 Sep 2016 21:10:25 GMT</pubDate></item></channel></rss>
