<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutch master cylinder 'skipping']]></title><description><![CDATA[<p dir="auto">Hey guys, have a strange problem. Obviously the solution is 'replace your clutch master cylinder' but i'm wondering if anyone has the technical knowledge to know whats going on and how long I have to catastrophic failure.</p>
<p dir="auto">Anyways, the other day i get into the car and drive and the clutch pedal does a 'skip'. basically , the pedal is firm at the top, than as soon as you press a little it jumps the first 1/4 of pedal travel with no resistance, than you hit the pressure of the cylinder and all is normal, car shifts fine.  So of course I assumed it was the clutch return spring -- that the rod had broken and it was jumping around. I tried to look inside the spring to check, but its impossible to see in the car.  So I order a new one and dove in today for the job.  Well, i've got the spring out and its not broken...(freakin $80 new part not needed!) and the 'skip' seems to be internally in the clutch master cylinder.  I pulled the dust boot back and the rear snap ring and seal are in place so beyond that no idea.</p>
<p dir="auto">So what the hell is going on in there and how long till it blows a seal and I'm stranded? I'm doing a 1000 mile road trip on the 23rd so I have to get things buttoned up before then.</p>
]]></description><link>https://wibimmers.com/topic/4464/clutch-master-cylinder-skipping</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:01:58 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4464.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Aug 2016 14:51:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutch master cylinder 'skipping' on Wed, 17 Aug 2016 20:47:06 GMT]]></title><description><![CDATA[<p dir="auto">they do, but they only replace the stock soft line. the clearance to get the to the hardline at the back of the master is even worse than e30s/e28s on the e34 v8 cars. i could barely get to it and that's with the transmission out of the car. when I replace the master this time, I'm yanking those sumbitches and going with the SS line from the master to the hardlines at the slave. i was going to do the line when I did the 5 speed swap, but the stock lines were in good enough shape I didnt bother.</p>
<p dir="auto">2 weeks is probably too long, but no worries, I should be able to gather the sizes from internet research</p>
]]></description><link>https://wibimmers.com/post/71264</link><guid isPermaLink="true">https://wibimmers.com/post/71264</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Wed, 17 Aug 2016 20:47:06 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch master cylinder 'skipping' on Wed, 17 Aug 2016 03:33:03 GMT]]></title><description><![CDATA[<p dir="auto">I'm out of town now but could get them to you in like 2 weeks if you could wait. Nobody makes SS clutch lines for V8 e34's?</p>
]]></description><link>https://wibimmers.com/post/71253</link><guid isPermaLink="true">https://wibimmers.com/post/71253</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 17 Aug 2016 03:33:03 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch master cylinder 'skipping' on Mon, 15 Aug 2016 17:23:34 GMT]]></title><description><![CDATA[<p dir="auto">thanks, but these are in the category of 'get a new one, don't want to do this job ever again'.  however, can I borrow them to get the fitting sizes to get a SS clutch line made?</p>
<p dir="auto">i did some research on how a cylinder like this is put together inside, and my only guess is somehow the pushrod has come unseated from the piston and is clicking into place every time I push the pedal. don't know if it will fail soon because of this, but it needs to be replaced.  i got a high quote to get it replaced at Kummrow ($530!!) -  they have done really good work for me, but 'mind blown' on that price. anyways, I am going to roll the dice and order a replacement and bring it with my on my road trip since I don't have time to do it before then, then just tackle it later.</p>
]]></description><link>https://wibimmers.com/post/71189</link><guid isPermaLink="true">https://wibimmers.com/post/71189</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 15 Aug 2016 17:23:34 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch master cylinder 'skipping' on Sat, 13 Aug 2016 22:27:51 GMT]]></title><description><![CDATA[<p dir="auto">I don't have a answer but if you need a spare master/slave let me know, I got used ones I can pull off the parts car.</p>
]]></description><link>https://wibimmers.com/post/71163</link><guid isPermaLink="true">https://wibimmers.com/post/71163</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sat, 13 Aug 2016 22:27:51 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch master cylinder 'skipping' on Sat, 13 Aug 2016 15:06:18 GMT]]></title><description><![CDATA[<p dir="auto">video (crappy, i know) of the 'skip'. the clutch return spring is removal at this point.</p>
]]></description><link>https://wibimmers.com/post/71157</link><guid isPermaLink="true">https://wibimmers.com/post/71157</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 13 Aug 2016 15:06:18 GMT</pubDate></item></channel></rss>
