<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 brake issue]]></title><description><![CDATA[<p dir="auto">Lately, I've been having an interesting problem with the e30. Once the brakes heat up, the left rear rotor/caliper makes an awful squealing noise, but only while off the brakes. Once you press the pedal, it goes away. I've tried anti squeal but it didn't change anything. Any ideas on what's wrong? I'm thinking it's probably a dragging caliper, but maybe someone on here has some insight.</p>
]]></description><link>https://wibimmers.com/topic/4401/e30-brake-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:39:04 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4401.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jun 2016 02:46:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 brake issue on Sat, 02 Jul 2016 17:48:46 GMT]]></title><description><![CDATA[<p dir="auto">Honestly you could rent all of that but I knew I would need it in the future and could help others do wheel bearings if need be=)</p>
]]></description><link>https://wibimmers.com/post/70203</link><guid isPermaLink="true">https://wibimmers.com/post/70203</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sat, 02 Jul 2016 17:48:46 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Sat, 02 Jul 2016 14:03:24 GMT]]></title><description><![CDATA[<p dir="auto">I'd rent the slide hammer from an auto store for free. Just put down a 100% returnable deposit and away you go</p>
<p dir="auto">Sent from my SM-G930R4 using Tapatalk</p>
]]></description><link>https://wibimmers.com/post/70201</link><guid isPermaLink="true">https://wibimmers.com/post/70201</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Sat, 02 Jul 2016 14:03:24 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Sat, 02 Jul 2016 14:01:47 GMT]]></title><description><![CDATA[<p dir="auto">You can easily replace rear wheel bearings with everything on the car. Invest in a few tools at Harbor Freight to do it easily:</p>
<p dir="auto"><a href="http://m.harborfreight.com/fwd-front-wheel-bearing-adapters-66829.html" rel="nofollow ugc">http://m.harborfreight.com/fwd-front-wheel-bearing-adapters-66829.html</a></p>
<p dir="auto"><a href="http://m.harborfreight.com/heavy-duty-slide-hammer-and-puller-set-16-pc-60327.html" rel="nofollow ugc">http://m.harborfreight.com/heavy-duty-slide-hammer-and-puller-set-16-pc-60327.html</a></p>
<p dir="auto"><a href="http://m.harborfreight.com/2-pc-10-in-internal-and-external-circlip-pliers-60593.html?utm_referrer=https%3A%2F%2Fwww.google.com%2F" rel="nofollow ugc">http://m.harborfreight.com/2-pc-10-in-internal-and-external-circlip-pliers-60593.html?utm_referrer=https%3A%2F%2Fwww.google.com%2F</a></p>
]]></description><link>https://wibimmers.com/post/70200</link><guid isPermaLink="true">https://wibimmers.com/post/70200</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sat, 02 Jul 2016 14:01:47 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Sat, 02 Jul 2016 05:09:55 GMT]]></title><description><![CDATA[<p dir="auto">If you plan on dropping it like its hot, toss in some new bushings.</p>
<p dir="auto">The axle will still have to be removed</p>
]]></description><link>https://wibimmers.com/post/70196</link><guid isPermaLink="true">https://wibimmers.com/post/70196</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Sat, 02 Jul 2016 05:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Fri, 01 Jul 2016 23:37:24 GMT]]></title><description><![CDATA[<p dir="auto">None of the above, just take the wheel, rotor, and hub off</p>
]]></description><link>https://wibimmers.com/post/70185</link><guid isPermaLink="true">https://wibimmers.com/post/70185</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 01 Jul 2016 23:37:24 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Fri, 01 Jul 2016 22:54:12 GMT]]></title><description><![CDATA[<p dir="auto">I'll let you guys know more when I get back home on Sunday. In the meantime, what would you guys recommend for replacing the bearings? Just pull the trailing arms or drop the whole subframe out?</p>
]]></description><link>https://wibimmers.com/post/70184</link><guid isPermaLink="true">https://wibimmers.com/post/70184</guid><dc:creator><![CDATA[P_Roloff]]></dc:creator><pubDate>Fri, 01 Jul 2016 22:54:12 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Fri, 01 Jul 2016 14:43:57 GMT]]></title><description><![CDATA[<p dir="auto">Damn autocorrect lol. We didn't have time but yes that would be the next step.</p>
]]></description><link>https://wibimmers.com/post/70165</link><guid isPermaLink="true">https://wibimmers.com/post/70165</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Fri, 01 Jul 2016 14:43:57 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Thu, 30 Jun 2016 18:45:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/70129">YoungCR said:</a></strong></p>
<p dir="auto">Lubed the guide pins this afternoon. We're guessing it's a real wheel bearing going out. </p>
<p dir="auto">As opposed to a fake one</p>
<p dir="auto">But for serious. Jack the car up and see if there's play?</p>
]]></description><link>https://wibimmers.com/post/70147</link><guid isPermaLink="true">https://wibimmers.com/post/70147</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Thu, 30 Jun 2016 18:45:32 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Wed, 29 Jun 2016 23:10:08 GMT]]></title><description><![CDATA[<p dir="auto">Lubed the guide pins this afternoon. We're guessing it's a real wheel bearing going out.</p>
]]></description><link>https://wibimmers.com/post/70129</link><guid isPermaLink="true">https://wibimmers.com/post/70129</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 29 Jun 2016 23:10:08 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Wed, 29 Jun 2016 18:28:34 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the responses. They're new rotors as of last summer, along with new pagid red (bavauto) pads. Guide pins weren't replaced, so that's probably a good place to start.</p>
]]></description><link>https://wibimmers.com/post/70117</link><guid isPermaLink="true">https://wibimmers.com/post/70117</guid><dc:creator><![CDATA[P_Roloff]]></dc:creator><pubDate>Wed, 29 Jun 2016 18:28:34 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Tue, 28 Jun 2016 07:42:41 GMT]]></title><description><![CDATA[<p dir="auto">You can also take a short low speed drive around the neighborhood, avoid using the brakes (sorry kids!) and use an IR thermometer to compare rotor temperatures to see the extent of the dragging</p>
<p dir="auto">The remedy may end up being new caliper guide pins or just lubricating the ones that are in there</p>
]]></description><link>https://wibimmers.com/post/70058</link><guid isPermaLink="true">https://wibimmers.com/post/70058</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 28 Jun 2016 07:42:41 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Tue, 28 Jun 2016 05:33:37 GMT]]></title><description><![CDATA[<p dir="auto">I'll be up at my shop tomorrow if you want me to help look over it. Also have a spare set of rear pads and rotors too.</p>
]]></description><link>https://wibimmers.com/post/70055</link><guid isPermaLink="true">https://wibimmers.com/post/70055</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Tue, 28 Jun 2016 05:33:37 GMT</pubDate></item><item><title><![CDATA[Reply to E30 brake issue on Tue, 28 Jun 2016 03:14:19 GMT]]></title><description><![CDATA[<p dir="auto">If you haven't done this already drive it around the neighborhood until it starts making the noise, jack up the rear of the car, put it on jack stands, remove the left wheel and with some work gloves on turn the rotor (or better yet have a friend turn the other rear wheel) to see if the caliper is sticking or the rotor is warped.</p>
<p dir="auto">Are the pads new, what type are they, any uneven wear, etc.</p>
]]></description><link>https://wibimmers.com/post/70053</link><guid isPermaLink="true">https://wibimmers.com/post/70053</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 28 Jun 2016 03:14:19 GMT</pubDate></item></channel></rss>
