<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Slick question on turbo stuffins]]></title><description><![CDATA[<p dir="auto">So this will be a complete waste of time for most.</p>
<p dir="auto">Differences in journal/ball bearing</p>
<p dir="auto">The question in questioning:</p>
<p dir="auto">What is the minimum oil pressure a turbo shall require at let's say 7-10k rpm?</p>
<p dir="auto">How much oil flow does the turbo need</p>
<p dir="auto">0-300gpm?</p>
<p dir="auto">Minimum amount of oil needed in a closed system( separate tank and cooler would be used)</p>
<p dir="auto">How many qts?</p>
]]></description><link>https://wibimmers.com/topic/4319/slick-question-on-turbo-stuffins</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:34:03 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4319.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Apr 2016 03:49:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Slick question on turbo stuffins on Sat, 21 May 2016 17:01:18 GMT]]></title><description><![CDATA[<p dir="auto">Lots of pumps available for this type of system, ranging from 75$ to 200ish for a good one. Scavenge pumps.</p>
]]></description><link>https://wibimmers.com/post/68990</link><guid isPermaLink="true">https://wibimmers.com/post/68990</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Sat, 21 May 2016 17:01:18 GMT</pubDate></item><item><title><![CDATA[Reply to Slick question on turbo stuffins on Sat, 21 May 2016 02:22:36 GMT]]></title><description><![CDATA[<p dir="auto">I will be doing this on a 2 stroke engine so there is no oil pressure. So I should probably first ding an oil pump.</p>
<p dir="auto">I recently purchased a 3-4 gpm pump for the hydraulic cooler on the dyno. Seems to work good not sure what kind of pressure it would build.</p>
]]></description><link>https://wibimmers.com/post/68977</link><guid isPermaLink="true">https://wibimmers.com/post/68977</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Sat, 21 May 2016 02:22:36 GMT</pubDate></item><item><title><![CDATA[Reply to Slick question on turbo stuffins on Fri, 20 May 2016 21:05:43 GMT]]></title><description><![CDATA[<p dir="auto">All turbo manufactures have specs for oil pressure. Very very different oil needs for journal bearing and ball bearing systems. Running a separate tank  with a ball bearing system can be very beneficial, as you can run lighter oil, for more efficient operation and faster transient response, as you often need quite a thick oil with a high output turbocharged engine.</p>
]]></description><link>https://wibimmers.com/post/68953</link><guid isPermaLink="true">https://wibimmers.com/post/68953</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Fri, 20 May 2016 21:05:43 GMT</pubDate></item><item><title><![CDATA[Reply to Slick question on turbo stuffins on Fri, 20 May 2016 17:38:56 GMT]]></title><description><![CDATA[<p dir="auto">Without being an engineer at Honeywell/Garrett, I would go about figuring this out emprically.</p>
<p dir="auto">-Find the oil pressure specs for your engines operating range  (lowest pressure and highest pressure)</p>
<p dir="auto">-Obtain an oil fitting with restrictor that you would use with your chosen turbo</p>
<p dir="auto"> <img src="http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Oil%20Supply/gtoilinlet035-01.jpg" alt="gtoilinlet035-01.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">-Build a pressure vessel/container that can hold approximately a gallon of oil and withstand the highest pressure your oil pump can generate.</p>
<p dir="auto">-Add an air fitting to the pressure vessel, set your air compressor regulator to the lowest pressure, see how much oil flows out over a given time. Repeat with your regulator set  at the highest pressure.</p>
<p dir="auto">-Oil should probably be warmed to 200-230F for this experiment for greater accuracy.</p>
]]></description><link>https://wibimmers.com/post/68934</link><guid isPermaLink="true">https://wibimmers.com/post/68934</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 20 May 2016 17:38:56 GMT</pubDate></item><item><title><![CDATA[Reply to Slick question on turbo stuffins on Wed, 27 Apr 2016 02:36:20 GMT]]></title><description><![CDATA[<p dir="auto">Great question. Im here to wait for a good answer.</p>
]]></description><link>https://wibimmers.com/post/68342</link><guid isPermaLink="true">https://wibimmers.com/post/68342</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Wed, 27 Apr 2016 02:36:20 GMT</pubDate></item></channel></rss>
