<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cosmoline Removal From Painted Surfaces?!?]]></title><description><![CDATA[<p dir="auto">Has anyone found - or heard of - a good way to remove the OEM applied cosmoline from the engine bay (inner fenders, strut towers, etc...).  I've done a bunch of searching and it seems no one has a "good" solution.  I tried non-chlorinated Brake Kleen after reading a bunch of people suggesting it, but wasn't pleased with the results.  It seemed to still leave a layer after multiple applications, and in the areas it appears to be fully removed it seems to soften the paint.</p>
<p dir="auto">I'm not concerned with time or elbow grease - I just want the crap off the bay!  Anyone had good results with certain products or processes?!?</p>
]]></description><link>https://wibimmers.com/topic/4287/cosmoline-removal-from-painted-surfaces</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:34:14 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4287.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Apr 2016 16:37:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cosmoline Removal From Painted Surfaces?!? on Wed, 06 Apr 2016 15:29:31 GMT]]></title><description><![CDATA[<p dir="auto">I have also heard of people using oven cleaner to remove cosmoline but I cant tell you if it works or not.</p>
]]></description><link>https://wibimmers.com/post/67743</link><guid isPermaLink="true">https://wibimmers.com/post/67743</guid><dc:creator><![CDATA[andyhundley]]></dc:creator><pubDate>Wed, 06 Apr 2016 15:29:31 GMT</pubDate></item><item><title><![CDATA[Reply to Cosmoline Removal From Painted Surfaces?!? on Wed, 06 Apr 2016 13:32:15 GMT]]></title><description><![CDATA[<p dir="auto">I may try a 75/25 or 50/50 mix of lacquer thinner and a mineral thinner (mineral thinner to thin the thinner..... Thinner).</p>
<p dir="auto">Less harsh = more scrubbing.... But more control and less chance of getting too much paint removal.</p>
]]></description><link>https://wibimmers.com/post/67735</link><guid isPermaLink="true">https://wibimmers.com/post/67735</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Wed, 06 Apr 2016 13:32:15 GMT</pubDate></item><item><title><![CDATA[Reply to Cosmoline Removal From Painted Surfaces?!? on Wed, 06 Apr 2016 13:08:45 GMT]]></title><description><![CDATA[<p dir="auto">So I gave lacquer thinner a try on one of the small brackets I plan to remove from the bay.  The lacquer thinner cuts through the cosmoline wonderfully!</p>
<p dir="auto">.... Unfortunately it also cuts through the paint under it equally well!</p>
<p dir="auto">Lacquer thinner on a rag removes the cosmoline in about 2-3 seconds of light scrubbing, however I found that any more then 2-3 seconds and you'll start to get into the paint under it.  It's especially bad if there is any paint flake or scratches - those areas will pull up paint even faster (especially because there is no cosmoline on that scratch/flake so the lacquer thinner starts on the paint immediately).  If you scrub on a spot for 10 seconds or more.... Bye-bye paint.</p>
<p dir="auto">I think a person *could* use lacquer thinner - but you'd need to be very careful not to overdo it in quantity or scrubbing.  I'd also be concerned about making the painted surfaces "splotchy" by the varying  scrub times.</p>
<p dir="auto">A quick pass with the lacquer thinner really does eat the cosmoline quickly tho - I'm just not sure it's worth the risk of going too far into the paint.</p>
]]></description><link>https://wibimmers.com/post/67734</link><guid isPermaLink="true">https://wibimmers.com/post/67734</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Wed, 06 Apr 2016 13:08:45 GMT</pubDate></item><item><title><![CDATA[Reply to Cosmoline Removal From Painted Surfaces?!? on Sun, 03 Apr 2016 17:09:27 GMT]]></title><description><![CDATA[<p dir="auto">Every day. Works extremely well to remove scuffs, paint transfer, overspray, etc. Now, if your car had lacquer based paint, I would worry haha.</p>
]]></description><link>https://wibimmers.com/post/67635</link><guid isPermaLink="true">https://wibimmers.com/post/67635</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Sun, 03 Apr 2016 17:09:27 GMT</pubDate></item><item><title><![CDATA[Reply to Cosmoline Removal From Painted Surfaces?!? on Sun, 03 Apr 2016 16:27:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/67612">wasnt m3 said:</a></strong></p>
<p dir="auto">I'd try lacquer thinner. No, it won't hurt your paint. </p>
<p dir="auto">Not that I don't believe you - but do you have any experience using lacquer thinner on automotive paint?  My dad uses lacquer thinner a bit around their sign shop (usually for removing paint I believe...) and I know it's some pretty harsh stuff.</p>
]]></description><link>https://wibimmers.com/post/67632</link><guid isPermaLink="true">https://wibimmers.com/post/67632</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Sun, 03 Apr 2016 16:27:01 GMT</pubDate></item><item><title><![CDATA[Reply to Cosmoline Removal From Painted Surfaces?!? on Sun, 03 Apr 2016 02:11:40 GMT]]></title><description><![CDATA[<p dir="auto">never could get it off of my e30s. (short of using abrasive methods for engine parts) i gave up though once i thought i might start doing more harm than good.  cosmoline &gt; damaged paint.</p>
]]></description><link>https://wibimmers.com/post/67620</link><guid isPermaLink="true">https://wibimmers.com/post/67620</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sun, 03 Apr 2016 02:11:40 GMT</pubDate></item><item><title><![CDATA[Reply to Cosmoline Removal From Painted Surfaces?!? on Sat, 02 Apr 2016 16:54:00 GMT]]></title><description><![CDATA[<p dir="auto">I'd try lacquer thinner. No, it won't hurt your paint.</p>
]]></description><link>https://wibimmers.com/post/67612</link><guid isPermaLink="true">https://wibimmers.com/post/67612</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Sat, 02 Apr 2016 16:54:00 GMT</pubDate></item></channel></rss>
