<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 Gas gauge question]]></title><description><![CDATA[<p dir="auto">I posted this on r3v and figured I'd try here as well. My gas gauge on the 1990 e30 325i has always been off--going from reading full to empty after about 6 gallons in a 16 gallon tank. Both the right and left tank level senders are new. My symptoms are those of the wrong gauge in the cluster: the gauge for the smaller 55 liter tank will read empty on a half full 63 liter tank.</p>
<p dir="auto">I picked up a used motometer gauge a while back that has the part number 1 373 678 but the part number doesn't match up with any e30 part numbers I've been able to find. Aside from pulling the cluster and installing it I can't tell if this is actually what I need. Any e30 gauge experts here?</p>
<p dir="auto">Real oem part numbers for the gauge for the bigger e30 tank (in the m20 325i, is, ix,and 1990-92 ic) is: 62-13-1-381-886 or 888 for the Canada/ Europe model</p>
<p dir="auto">Part number for the gauge for the smaller e30 gas tank:</p>
<p dir="auto">62-13-1-374-822 or 823, or for the early model m10 engine cars 812 and 813</p>
<p dir="auto">Part number for the e30 M3 fuel gauge is:</p>
<p dir="auto">62-13-1-380-867 or 381-483</p>
<p dir="auto">So the question is what used gauge did I pick up?</p>
]]></description><link>https://wibimmers.com/topic/4282/e30-gas-gauge-question</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:00:29 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4282.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Mar 2016 17:02:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 Gas gauge question on Mon, 28 Mar 2016 05:25:18 GMT]]></title><description><![CDATA[<p dir="auto">Funny that you should mention that. I do happen to have two 5 gallon race jugs and a siphon pump. Thanks for the suggestion.</p>
]]></description><link>https://wibimmers.com/post/67443</link><guid isPermaLink="true">https://wibimmers.com/post/67443</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Mon, 28 Mar 2016 05:25:18 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Gas gauge question on Mon, 28 Mar 2016 04:53:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/67441">Boris3 said:</a></strong></p>
<p dir="auto">Thanks. I had been playing with the numbers as well and actually contacted that eBay seller to see what car they had pulled it out of. No such luck, it's a third party seller and they didn't know.</p>
<p dir="auto">Spot on with the ease of swapping the gauge. But this is on the track car which is in storage with a full tank... so it'll take a while plus a session to burn up enough gas to see if the swapped gauge is what I needed. Still that may be what I'll end up doing.</p>
<p dir="auto">a pair of 5 gallon buckets and a siphon and you could check it in a garage.</p>
]]></description><link>https://wibimmers.com/post/67442</link><guid isPermaLink="true">https://wibimmers.com/post/67442</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 28 Mar 2016 04:53:27 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Gas gauge question on Mon, 28 Mar 2016 03:13:22 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I had been playing with the numbers as well and actually contacted that eBay seller to see what car they had pulled it out of. No such luck, it's a third party seller and they didn't know.</p>
]]></description><link>https://wibimmers.com/post/67441</link><guid isPermaLink="true">https://wibimmers.com/post/67441</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Mon, 28 Mar 2016 03:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Gas gauge question on Mon, 28 Mar 2016 03:00:18 GMT]]></title><description><![CDATA[<p dir="auto">could possibly be the manufacturer's part number. VDO, motometer, any manufacturer shown? my search turned up the same thing: nada.</p>
<p dir="auto">i tried to de-code your part number by adding possible main groups and sub groups to give it 11 digits, but no luck there.</p>
<p dir="auto">one ebay listing has your same unknown part number for sale <a href="http://www.ebay.com/itm/BMW-3-Series-E30-6090001098-Fuel-Gauge-/271901310506?hash=item3f4e94be2a:g:0KQAAOSwrklVfTAV&amp;vxp=mtr" rel="nofollow ugc">http://www.ebay.com/itm/BMW-3-Series-E30-6090001098-Fuel-Gauge-/271901310506?hash=item3f4e94be2a:g:0KQAAOSwrklVfTAV&amp;vxp=mtr</a></p>
<p dir="auto">i'm sure you don't like wasting time as much as the next guy, but pulling the cluster and swapping the gauges takes less than an hour.</p>
]]></description><link>https://wibimmers.com/post/67440</link><guid isPermaLink="true">https://wibimmers.com/post/67440</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 28 Mar 2016 03:00:18 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Gas gauge question on Sun, 27 Mar 2016 18:26:19 GMT]]></title><description><![CDATA[<p dir="auto">My 91 325i has a MotoMeter with part number 1 381 886 like realoem shows</p>
<p dir="auto">I can certainly understand your confusion. Those part numbers show a gauge for an E30. I did see that number reference an e39 525i at one source but its difficult to find a whole lot on those numbers</p>
]]></description><link>https://wibimmers.com/post/67426</link><guid isPermaLink="true">https://wibimmers.com/post/67426</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 27 Mar 2016 18:26:19 GMT</pubDate></item></channel></rss>
