<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Experience needed]]></title><description><![CDATA[<p dir="auto">Hello fellow wibmw owners. This is my first post and sadly it's me needing help, and a lot of it. Unfortunately my head gasket is junk on my 98 bmw 323is 2.5L i6 and it needs to be replaced asap. I havnt looked into a lot of shops because frankly I'm not sure I trust local shops with a bmw. I'd rather do it in someone's garage with someone who's done it before where I can help get the job done. I'd try and tackle it my self but I've never done a head gasket. Anywho reason for my post is I either need a really well know shop who has experience with e36 head gaskets or someone's help on here in doing the job. I don't have much money but will get a loan to get my beloved bimmer back up and functional.</p>
<p dir="auto">thank you in advance for any replies and help. </p>
<p dir="auto">I was at the last wi bimmers meet this year as well had a great cruise with most of you.</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2016_01_image.jpeg.83e5f3db31f0da53e7746484c0ef4271.jpeg"><img src="/assets/uploads/files/monthly_2016_01_image.thumb.jpeg.9268fd4b494d1118fe49c0f9b9f64372.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="750" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2016_01_image.jpeg.efe9962e376df20d81e2a214b577bcef.jpeg"><img src="/assets/uploads/files/monthly_2016_01_image.thumb.jpeg.d8a8a7504321b18912f51bea2d39f163.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
]]></description><link>https://wibimmers.com/topic/4173/experience-needed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:46:16 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4173.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Jan 2016 23:47:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Experience needed on Thu, 28 Jan 2016 13:37:21 GMT]]></title><description><![CDATA[<p dir="auto">Too bad, keep your coolant fresh folks!</p>
]]></description><link>https://wibimmers.com/post/65562</link><guid isPermaLink="true">https://wibimmers.com/post/65562</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 28 Jan 2016 13:37:21 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Tue, 26 Jan 2016 14:03:11 GMT]]></title><description><![CDATA[<p dir="auto">I spoke to him yesterday and it looks like the head gasket blew, had a cracked head and scored cams.  He's getting a used engine with 83k on it that they are going to install for him.</p>
]]></description><link>https://wibimmers.com/post/65477</link><guid isPermaLink="true">https://wibimmers.com/post/65477</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Tue, 26 Jan 2016 14:03:11 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 23:04:49 GMT]]></title><description><![CDATA[<p dir="auto">I wish I had more time that I could have volunteered my services (and heated garage) but you're in good hand with Olins.  It's a solid group over there.</p>
]]></description><link>https://wibimmers.com/post/65138</link><guid isPermaLink="true">https://wibimmers.com/post/65138</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Fri, 15 Jan 2016 23:04:49 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 21:12:42 GMT]]></title><description><![CDATA[<p dir="auto">Air being trapped by the water pump causes no flow and no heat. Air being pushed in from a combustion chamber to cooling system leak would cause this. Do you have rough could startups? You should start with a hydrocarbon test of the coolant. This will tell you if combustion gasses are entering the coolant.</p>
]]></description><link>https://wibimmers.com/post/65134</link><guid isPermaLink="true">https://wibimmers.com/post/65134</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Fri, 15 Jan 2016 21:12:42 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 19:18:56 GMT]]></title><description><![CDATA[<p dir="auto">The heat not getting hot is what doesn't make sense to me. Even with a bad head gasket, your heat would get hot.</p>
]]></description><link>https://wibimmers.com/post/65131</link><guid isPermaLink="true">https://wibimmers.com/post/65131</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 15 Jan 2016 19:18:56 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 19:03:13 GMT]]></title><description><![CDATA[<p dir="auto">I bled the cooling system after doing thermostat and it still gets more air in the system obviously leaking somewhere (most likely the HG) yes it has coolant in it and it's not low. Every so often I check it when I'm letting air out of the tank. Heater core could be clogged but that doesn't explain to me why I keep getting air in the system. The shop I took it to will diagnos it first before tearing it apart.</p>
]]></description><link>https://wibimmers.com/post/65129</link><guid isPermaLink="true">https://wibimmers.com/post/65129</guid><dc:creator><![CDATA[Disturbedodin95]]></dc:creator><pubDate>Fri, 15 Jan 2016 19:03:13 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 18:35:13 GMT]]></title><description><![CDATA[<p dir="auto">i was gonna say, you sure this is a head gasket? or is that just your guess? could be a number of things. hopefully the shop you brought it to will diagnose before just diving into a head gasket job...</p>
]]></description><link>https://wibimmers.com/post/65126</link><guid isPermaLink="true">https://wibimmers.com/post/65126</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Fri, 15 Jan 2016 18:35:13 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 08:38:14 GMT]]></title><description><![CDATA[<p dir="auto">Your heat doesnt work? Is your coolant level low? If not you could have a clogged heater core as well.</p>
]]></description><link>https://wibimmers.com/post/65111</link><guid isPermaLink="true">https://wibimmers.com/post/65111</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 15 Jan 2016 08:38:14 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 04:49:23 GMT]]></title><description><![CDATA[<p dir="auto">If air comes out of the bleeder....is the cooling system bled?</p>
]]></description><link>https://wibimmers.com/post/65110</link><guid isPermaLink="true">https://wibimmers.com/post/65110</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 15 Jan 2016 04:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 03:49:56 GMT]]></title><description><![CDATA[<p dir="auto">It overheats when it wants to. After a drive or during one it over heats and I shut it off immediately. Upon opening the hood I use a flat head and loosen the bleeder screw on the top of the coolant tank, when I do this sometimes a little air comes out sometimes a lot. I drive it everyday. I decided to take it to the shop notes above (thanks pat) and they're starting the work Monday 1/25/16. It's pricey but id like to be able to drive my car without having any thing to worry about again. Plus I don't have any heat coming out of my vents so it's a hassle driving to work in the morning. Once this problem is resolved I can start saving for the aftermarket parts that I want... Again I thank you all for your responses</p>
]]></description><link>https://wibimmers.com/post/65109</link><guid isPermaLink="true">https://wibimmers.com/post/65109</guid><dc:creator><![CDATA[Disturbedodin95]]></dc:creator><pubDate>Fri, 15 Jan 2016 03:49:56 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Fri, 15 Jan 2016 03:28:58 GMT]]></title><description><![CDATA[<p dir="auto">Did it overheat or anything? Coolant in oil? I could help but would need to be towed to my shop in IL.</p>
]]></description><link>https://wibimmers.com/post/65108</link><guid isPermaLink="true">https://wibimmers.com/post/65108</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Fri, 15 Jan 2016 03:28:58 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Wed, 13 Jan 2016 01:53:14 GMT]]></title><description><![CDATA[<p dir="auto">However you do it inspect the head carefully for cracks. A "bad head gasket " sometimes is actually a crack from exhaust valve to the water jacket on one of the middle cylinders. It's not a hard job I've done several.</p>
]]></description><link>https://wibimmers.com/post/65038</link><guid isPermaLink="true">https://wibimmers.com/post/65038</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 13 Jan 2016 01:53:14 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Tue, 12 Jan 2016 15:16:25 GMT]]></title><description><![CDATA[<p dir="auto">He lives near me in Milton.</p>
<p dir="auto">Take it to Olin's.  They do quality work from what I have heard.  I know their Hunter Engineering rep really well and he only has good things to tell me about them.  That and the number of euro's I constantly see parked outside of their shop tells me they already have that clientele built up and wouldn't be shocked by an e36.</p>
]]></description><link>https://wibimmers.com/post/65002</link><guid isPermaLink="true">https://wibimmers.com/post/65002</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Tue, 12 Jan 2016 15:16:25 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Tue, 12 Jan 2016 14:11:40 GMT]]></title><description><![CDATA[<p dir="auto">I could be of assistance pending your location. I have a shop in Appleton where it could be done quickly, less the head being resurfaced.<br />
It's a pretty quick job, though I have only done it in e30's lol. E36 bay isn't too much different though. <br />
That one is single VANOS right? M52b25<br />
As stated prior, parts list is easy as well.</p>
]]></description><link>https://wibimmers.com/post/64997</link><guid isPermaLink="true">https://wibimmers.com/post/64997</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Tue, 12 Jan 2016 14:11:40 GMT</pubDate></item><item><title><![CDATA[Reply to Experience needed on Mon, 11 Jan 2016 23:54:30 GMT]]></title><description><![CDATA[<p dir="auto">Ah yes,  I saw you there in the chariot formerly owned by Ryan. </p>
<p dir="auto">Where are you located? I personally cant offer any help in-person at the moment but would be glad to help compile parts lists, help answer questions and instill some confidence that its pretty simple and you can do it.  Lots of folks on here have done head gaskets on 24Vs so hopefully someone else will be able to help turn wrenches. Just be sure you are aware of what can happen to the hollow camshafts and how to prevent it .....</p>
]]></description><link>https://wibimmers.com/post/64976</link><guid isPermaLink="true">https://wibimmers.com/post/64976</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 11 Jan 2016 23:54:30 GMT</pubDate></item></channel></rss>
