I installed my new license plate mounting plugs, screws, and washers yesterday. The old ones were left in when the trunk was resprayed. I have a feeling the whole hatch will be resprayed when the car goes back to paint so I will make sure to remove all of the trunk handle inserts and the license plate mounting plugs so they don't just spray over them again. I do need to figure out the correct part number for the license plate screw plastic caps. They're a bit bigger than the interior screw caps.
I also finally finished a project that I have been working on for 2 years off and on. I set it aside and forgot about it countless times when it made me angry and wasn't turning out great.
I can post in process pictures that I took along the way if anyone is interested in what I all did.
That's the shaved trunk release panel right?
It looks the most like a compact =P
you should probably scrape a little of the paint off where the tires are drawn to make it seem lower.
ASSPROOF Auctions?
Are you going to get that button custom made in stainless steel?
Progress over this past week has mostly been chipping away at undercoating removal by hand. I have the center portion stripped all the way to the gas tank area and half of a floorboard/rocker completed.
I did get some time to remove the fabric covered sunroof shuttle so that I can take the headliner, A pillars, shuttle, and drivers seat to the upholsterer.
I also got my front subframe, crossbar, fuel line cover and window tracks back from Zach
I cleaned the sunroof tracking on Saturday (no pictures of that as my phone died before I finished) and removed the side pieces from the sunroof to replace them.
I also cleaned the underside of the sunroof and noticed the edge of the vinyl sheet is peeling up. I'm not quite sure what would be the best thing to adhere it back to the sunroof. I had though about replacing it but I don't see it listed as a part in the diagrams on realoem.com
Maybe if you weren't streaming live you're phone wouldn't have died
The video was useless. You weren't even responding to my comments!
Spray adhesive perhaps? 3M super 90?
