    Ground down 30mm sockets are what a couple of the techs at concours use. I even broke one of them when I did the driveshaft upgrade on the eta 😕 having a strong impact is probably required too.
      Started on the output shaft seal last night.
      I had to grind down a socket to fit but got the nut off with an impact fairly easy after that. The flange pulled right off without needing a puller.
      I then used a slide hammer with a hook attachment at the end to pull the seal out.
      I then lubricated the new seal and started it in the bore with my hands. I used a brass drift and drove it in about 3mm from flush (the thickness of two pennies)
      At this point I put the flange back onto the output shaft and tightened the nut, seating the seal the rest of the way. The next step is to torque the output flange nut in two stages. First torque it to 140ft/lbs, then remove the nut, add loctite (Bentley specifies 242 but I will be using 271), and torque the nut to 89 ft/lbs. I could not find any way to hold the flange to 140ft/lbs at home. I grenaded a screwdriver in a failed attempt. I brought the trans into work today so that I can take a piece of angle iron and bolt it to the flange. This way I can clamp that in a vice and it should be easier. The only thing I am afraid of now is the ground down socket breaking. Hopefully it holds up.
        Good news, my method at work worked=) The nut is now torqued properly. Now I just need to do the detent springs tonight and I am finished with it
          Replaced the detent springs yesterday evening. I freshened up the holding plate and installed new bolts too (yes they're stainless=P)
          What I started with
          The springs looked a hair compressed more than the new springs. By hand the rates didn't feel much different. There really was nothing to take a picture of for the new springs, so here it is all done=)
          Now onto find what to refresh next=) I have an e34 steering coupler on the way and more parts from Germany=P
              Thinking of E34's , how is she?
                Pretty Good=) Haven't had any issues
                  A burnout a day keeps the CEL away
                    That's been on since the day I bought it haha. SRS light too=P
                    • Dominic540D
                      Dominic540D
                      Dominic540
                      Wait, the SRS light can be off on an e34? Haha
                        Earl, how long did it take for IE to ship you your brass pivot for the fork?
                        Update also, please.
                          It was about a week before my order was even picked and shipped.
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            Looking good, Earl. If you're interested, I have a Racing Dynamics E36 318 strut brace that I don't need in my parts pile... not sure if you already have one/want one.
                              Clutch components arrived from CaTuned=)
                              I just need the m20 flywheel shim/washer and I have everything to mate the engine to the trans.
                              I also picked up a 2.93 medium case lsd for cheap. I am going to see how it cleans up and decide what  I want to do with it from there. It is CRUSTY haha
                                Work your magic on it!
                                  Won't the 2.93 be pretty slow behind the 4cyl?  The m50 cars had a 3.15.
                                    The car came with a 3.45 from the factory. It will be much slower but this car isn't made to be fast. It will get stellar gas mileage which makes it an even better cruiser=P
                                      The z3 rack is for avoiding pot holes and the diff is for going slow over bumps. #lowlife
                                        More goodies arrived from Germany
                                        Thanks again to my friend Kitty for all of the help finding and importing items. It is a set of MHW tail lights, a euro console, and alcantara to repair my drivers bolsters.
                                        The MHW's are in pretty excellent shape. One thing that puzzles me on how to solve is this dead spider stuck between the lenses
                                        He left a crystal sort of reside inside with him too. I think the only way to get him out is to heat the lights and pull off the lenses, but I don't want to risk damaging the lights=/
                                        They look great otherwise=)
                                        The console is basically the same as the US console, but does not have the holes in it for the stupid cup holder insert.
                                        I also finally found a spot where I can bring the car to work on it. My parents offered to let me work on it in their garage so I cleaned that up a little and started reorganizing. I should be able to fit with room to spare around all sides=)
                                        Going to see when I can get the car delivered and then go from there
                                          Those lights are sweet!
                                          The final stretch!!
