    AKG has the best price I have found, they seem to be permanently on sale, and the parts fit good.  I have some pics of the subframe ones and the rear sway reinforcements installed on my build thread if you want to see.  Very easy to weld in, I used my Hobart 110 flux core.
    I just checked it out. I'm not sure if I will actually need any of them... I will be reinforcing the front myself, and I 90% sure I will be tying my cage into the rear subframe... Hmmm.  And I won't be using a rear sway bar either. Yup. Nevermind guys!
      The AKG kit definitely requires a hammer to shape the outer piece=P lol
        Pretty sure all of the kits need to be bent after one side is welded, It sure beefs up the motor mount area doesn't it.
          Sure does lol
            Here is how far the welder got yesterday. Should be done today or Monday=)
            My CA Tuned front brake lines and clutch line came and they look great. I forgot to upload a picture to my photobucket though=/
            I assembled my calipers last night. All of them except for one went together great. There is one that I cannot get the piston past the o-ring and it is frustrating the hell out of me. I will be trying at it more today.
            Carrier bushings in
            Inner seal in
            All three that are done
            Here is how far the other front goes in
            I tried doing it all sorts of ways and then finally managed to get it stuck. I will hopefully figure it out but I know for sure the o-ring is the issue.
            Side note: one of the axles gave out on my daily as I pulled into work today so I am both unsure of how I am getting home, how I am getting to the shop tomorrow, and what I am going to do for a daily in general.
              Axle gave out completely?  Like broke off?
              Sucks on the caliper.  you might have to disassemble the other front to compare all the parts to make sure they are the same.
                I pulled the o-ring out yesterday and made sure the piston fits in the bore and it is smooth as butter. Something with the o-ring is keeping it from nicely sliding in=/
                The axle went from being no issue, to clunking very quiet intermittently, to clunking under load very audibly in under 5 minutes...lol I am thinking an engine or trans mount wore out and made an intermittent vibration that I have been having and after it doing it a few times, caused the axle to wear out
                  Not cool.
                  So howd you get home?
                    Uncle drove me home=)
                      Nice!  Is the car fixable?
                        Yeah. Just an axle=) Doing it tomorrow
                          CV axles ar grand ol' things aren't they?
                            Sure are lol
                              Not much was done this weekend. John and I spent Saturday trying to fix my daily. We assumed it was the passenger side axle, due to axle grease being spun around by the inner cv. After replacing it nothing has changed. The issue has to be something diff or trans related and since the car got hit by the semi, it isn't worth fixing. Hopefully we are either missing something easy, or something pops up for sale at a reasonable price instead of all of the over inflated crap currently.
                              Anyways, onto the car that matters. Subframe got finished Friday=)
                              Then primered
                              And then painted
                              My ECS Tuning order shipped out Friday as well and should be here today or tomorrow. Once that comes I can assemble my front hubs, attach my caliper carriers, and get my calipers finished with their new bleeders.
                              I was looking through my phone pictures Saturday morning and happened across this one. Eventually the car will be finished...
                                I hope that's hashtag wrinkle black paint on the subframe
                                  It is hashtag satin black to have a smooth mounting surface for the engine mounts=)
                                  • ClassEC
                                    ClassEC
                                    ClassE
                                    What's the thought process on the braided clutch line Earl? Haven't heard if this - better /firmer pedal feel?
                                      Firmer pedal feel=) It does exactly the same thing as braided brake lines.
                                        My ECS order arrived yesterday. I started right away on assembling my hubs and installing my speed bleeders.
                                        (the lighting was terrible for all of these phone pictures so I apologize in advance)
                                        Here is where I started, bare freshly powdercoated knuckles.
                                        I then took these rear dust covers
                                        and fitted them to the knuckles.
                                        After that I opened up these guys
                                        and tapped them on with a mallet
                                        Well, I only got one fully down. Reason is that I am an idiot and was tapping on the outer races/hubs instead of waiting to grab my socket and tapping them on from the inner race. From the multiple people I have asked, there shouldn't be any damage to the bearings since I wasn't bashing on them like Bam Bam with a wooden club. The use of a rubber mallet also saved me. I am waiting to do the other one until tonight when I will have my socket=)
                                        After all of that I installed my speed bleeders.
                                        I don't have any installed pictures because the sun went down and the lights in my living room are terrible.
                                        I did however only install 3 successfully. The fourth one I threaded in by hand like the previous 3. However, after slowly threading it in with a wrench, it felt like it wasn't going any further or tightening. I backed it out to see this:
                                        I am not quite sure how the threads stripped without applying any more torque than a simple turn of the wrench. I sent ECS an email about it, but I will probably just need to order a new one. I also made sure to take a cotton swab and get the stripped threads out of the bleeder hole so that they don't go into the bore=)
                                        Never a dull moment I guess. More updates tomorrow I am hoping.
                                          ECS is sending me a replacement bleeder free of charge. That right there is why I always order through them=) Great customer service.
                                          On a side note, I picked everything up from the shop at lunch. I should be getting the stubborn hub down on the knuckle tonight, as well as bolting the calipers and rotors on to get an idea of how it will all come together.
