<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[e46 328i shake]]></title><description><![CDATA[<p dir="auto">Ok I have a 2000 e46 328i I just balanced the wheels and that didn't solve the shake. My wheels are not bent. The sake starts at about 50mph. While driveing strait I noticed that the steering wheel will shake then go away for about 3 seconds then slowly come back and go away and come back. Could it be control arm bushings? Possibly a tie rod?</p>
]]></description><link>https://wibimmers.com/topic/4008/e46-328i-shake</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:56:59 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4008.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Sep 2015 23:28:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to e46 328i shake on Sun, 27 Sep 2015 00:50:48 GMT]]></title><description><![CDATA[<p dir="auto">Does it steady out when you apply the brakes? Check the tie rod ends but it probably is the control arm bushings. I have replaced failed ones on 3 different e30s and e36s. I install the OEM centered style ones for an e36 m3, they have more rubber vs airspace so they last longer but don't coat any more. I think the e46 might use a slightly different one though, never done one of those.</p>
]]></description><link>https://wibimmers.com/post/62156</link><guid isPermaLink="true">https://wibimmers.com/post/62156</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Sun, 27 Sep 2015 00:50:48 GMT</pubDate></item><item><title><![CDATA[Reply to e46 328i shake on Sun, 27 Sep 2015 00:39:00 GMT]]></title><description><![CDATA[<p dir="auto">I'd check both the control arm bushings and tie rod ends. Either of those could likely cause the shimmy.</p>
]]></description><link>https://wibimmers.com/post/62155</link><guid isPermaLink="true">https://wibimmers.com/post/62155</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Sun, 27 Sep 2015 00:39:00 GMT</pubDate></item></channel></rss>
