<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[e36 m3 stalling, help!]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">My '99 m3 developed a problem on the way home today, when I let off the gas to come to a stop the car dies. I can restart it easily and it will idle just fine, but the minute I touch the gas it will bog and, if I dont stall it, it is extremely sluggish until I get to around 2000rpm. It seems to be fine above there. It throws a check engine light every once in a while when it stalls but it goes away as soon as I start it again. I also noticed that it bucks a bit if I'm cruising around 2k rpm. </p>
<p dir="auto">Any things to check/advice would be appreciated</p>
]]></description><link>https://wibimmers.com/topic/3972/e36-m3-stalling-help</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:49:32 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3972.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Sep 2015 00:27:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to e36 m3 stalling, help! on Thu, 10 Sep 2015 03:22:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/61726">wasnt m3 said:</a></strong></p>
<p dir="auto">I have a good intake boot from my m roadster laying around if you're in a pinch. I just deleted the traction control stuff (which you should do). Just order an intake boot from a car without asc.</p>
<p dir="auto">I used a bunch of tape and was able to seal it back up enough to get to work in the morning, I'm about to order a new boot and completely forgot about the ASC delete, I was planning on doing it eventually, thanks for reminding me!</p>
]]></description><link>https://wibimmers.com/post/61728</link><guid isPermaLink="true">https://wibimmers.com/post/61728</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Thu, 10 Sep 2015 03:22:13 GMT</pubDate></item><item><title><![CDATA[Reply to e36 m3 stalling, help! on Thu, 10 Sep 2015 03:00:16 GMT]]></title><description><![CDATA[<p dir="auto">I have a good intake boot from my m roadster laying around if you're in a pinch. I just deleted the traction control stuff (which you should do). Just order an intake boot from a car without asc.</p>
]]></description><link>https://wibimmers.com/post/61726</link><guid isPermaLink="true">https://wibimmers.com/post/61726</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 10 Sep 2015 03:00:16 GMT</pubDate></item><item><title><![CDATA[Reply to e36 m3 stalling, help! on Thu, 10 Sep 2015 01:46:21 GMT]]></title><description><![CDATA[<p dir="auto">I was going to say ICV but Snap nailed it haha</p>
]]></description><link>https://wibimmers.com/post/61724</link><guid isPermaLink="true">https://wibimmers.com/post/61724</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 10 Sep 2015 01:46:21 GMT</pubDate></item><item><title><![CDATA[Reply to e36 m3 stalling, help! on Thu, 10 Sep 2015 01:38:35 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/09/09/de17b08991e60b17d3272858e882cb1f.jpg" alt="de17b08991e60b17d3272858e882cb1f.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Snap you nailed it. The boot tore where the ICV hose connects, PO taped it up and the hose completely fell out on the way home. I was thinking all sorts of sensors/coil packs/expensive stuff because the boot looked perfect from above...</p>
<p dir="auto">Sent from my XT1080 using Tapatalk</p>
]]></description><link>https://wibimmers.com/post/61722</link><guid isPermaLink="true">https://wibimmers.com/post/61722</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Thu, 10 Sep 2015 01:38:35 GMT</pubDate></item><item><title><![CDATA[Reply to e36 m3 stalling, help! on Thu, 10 Sep 2015 01:02:29 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like a torn intake boot/large intake leak</p>
]]></description><link>https://wibimmers.com/post/61714</link><guid isPermaLink="true">https://wibimmers.com/post/61714</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 10 Sep 2015 01:02:29 GMT</pubDate></item></channel></rss>
