<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Under hood adhesive removal]]></title><description><![CDATA[<p dir="auto">Not very "technical" but does anyone have tips on removing the under hood adhesive without stripping the paint off as well? I've tried Goo-Gone, simple green, paint thinners... The foam was trash so I pulled it off and I'm not sure the current state is an improvement.</p>
]]></description><link>https://wibimmers.com/topic/3908/under-hood-adhesive-removal</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:49:14 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3908.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Aug 2015 03:26:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Under hood adhesive removal on Thu, 13 Aug 2015 13:00:36 GMT]]></title><description><![CDATA[<p dir="auto">Good idea the WD40. Will have to try that myself.</p>
]]></description><link>https://wibimmers.com/post/61023</link><guid isPermaLink="true">https://wibimmers.com/post/61023</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Thu, 13 Aug 2015 13:00:36 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Thu, 13 Aug 2015 02:17:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the ideas. Tried Wd-40 tonight on a small area and seems to be working better then anything else I tried. Might try some of the others tomorrow if I have time.</p>
]]></description><link>https://wibimmers.com/post/61009</link><guid isPermaLink="true">https://wibimmers.com/post/61009</guid><dc:creator><![CDATA[DevianceInDark]]></dc:creator><pubDate>Thu, 13 Aug 2015 02:17:43 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Wed, 12 Aug 2015 22:40:47 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/60988">CMart said:</a></strong></p>
<p dir="auto">Kerosene is my go to for removing anything.</p>
<p dir="auto">This is the time where you fess up to using kerosene to remove your mother-in-law from your life.</p>
]]></description><link>https://wibimmers.com/post/61002</link><guid isPermaLink="true">https://wibimmers.com/post/61002</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 12 Aug 2015 22:40:47 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Wed, 12 Aug 2015 18:16:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Another good one.</p>
<p dir="auto">Used this on all of my moto chains to clean them. Just made sure to re-lube after kerosene evaporates</p>
]]></description><link>https://wibimmers.com/post/60992</link><guid isPermaLink="true">https://wibimmers.com/post/60992</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Wed, 12 Aug 2015 18:16:20 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Wed, 12 Aug 2015 16:31:51 GMT]]></title><description><![CDATA[<p dir="auto">Kerosene is my go to for removing anything.</p>
]]></description><link>https://wibimmers.com/post/60988</link><guid isPermaLink="true">https://wibimmers.com/post/60988</guid><dc:creator><![CDATA[CMart]]></dc:creator><pubDate>Wed, 12 Aug 2015 16:31:51 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Wed, 12 Aug 2015 13:10:08 GMT]]></title><description><![CDATA[<p dir="auto">3M adhesive remover works well. Advance Auto has it for $12.00 can</p>
]]></description><link>https://wibimmers.com/post/60976</link><guid isPermaLink="true">https://wibimmers.com/post/60976</guid><dc:creator><![CDATA[Hammerdown]]></dc:creator><pubDate>Wed, 12 Aug 2015 13:10:08 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Wed, 12 Aug 2015 11:49:35 GMT]]></title><description><![CDATA[<p dir="auto">I didn't even think of WD! I'll try it out tonight. Thanks!</p>
]]></description><link>https://wibimmers.com/post/60972</link><guid isPermaLink="true">https://wibimmers.com/post/60972</guid><dc:creator><![CDATA[DevianceInDark]]></dc:creator><pubDate>Wed, 12 Aug 2015 11:49:35 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Wed, 12 Aug 2015 07:42:34 GMT]]></title><description><![CDATA[<p dir="auto">I was going to recommend wd40 as well. Carb cleaner would ruin the finish of the paint and make it dull at the very least. If you spray on wd40 and let it soak in for a few minutes, it should all wipe off with a little elbow grease.</p>
]]></description><link>https://wibimmers.com/post/60969</link><guid isPermaLink="true">https://wibimmers.com/post/60969</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 12 Aug 2015 07:42:34 GMT</pubDate></item><item><title><![CDATA[Reply to Under hood adhesive removal on Wed, 12 Aug 2015 03:49:35 GMT]]></title><description><![CDATA[<p dir="auto">Wd-40?</p>
<p dir="auto">Will carb cleaner kill the paint?</p>
]]></description><link>https://wibimmers.com/post/60967</link><guid isPermaLink="true">https://wibimmers.com/post/60967</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Wed, 12 Aug 2015 03:49:35 GMT</pubDate></item></channel></rss>
