<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 Control Arm Bushing Tool.]]></title><description><![CDATA[<p dir="auto">Anyone have a control arm bushing tool I could borrow or rent?   I need to replace the control arm on my e30, and don't feel like spending $100 on a tool I'm going to use once <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">Many thanks!</p>
]]></description><link>https://wibimmers.com/topic/3883/e30-control-arm-bushing-tool.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:46 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3883.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Jul 2015 13:14:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Mon, 17 Aug 2015 19:32:10 GMT]]></title><description><![CDATA[<p dir="auto">Just in case anyone is wondering what I wound up doing:</p>
<p dir="auto">My control arm itself was fine.  I was replacing my struts and tore the boot on the outer ball joint.  After several failed attempts at finding a replacement that fit, I was prepared just to replace the whole damn arm just to get the car back on the road.  &lt;&lt; Impatience got the best of me, not my finest hour.   After a few beers, and a couple days away from the car, i tried ordering a cheapo ball joint, took the boot off that, and voila! Back in business.</p>
<p dir="auto">Anyway, struts installed, boot replaced, and many happy miles under the tires since.</p>
<p dir="auto">I did say that one of the reasons for getting this car was to learn on...</p>
<p dir="auto">Nonetheless, thanks for all the input on how to work the bushings. I'm sure it will come up eventually.</p>
]]></description><link>https://wibimmers.com/post/61166</link><guid isPermaLink="true">https://wibimmers.com/post/61166</guid><dc:creator><![CDATA[BenDem]]></dc:creator><pubDate>Mon, 17 Aug 2015 19:32:10 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Mon, 17 Aug 2015 15:19:00 GMT]]></title><description><![CDATA[<p dir="auto">This has worked great for me multiple times to separate ball joints and tie rod ends w/o damage to the boots:</p>
<p dir="auto"><a href="http://m.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html?utm_referrer=direct%2Fnot%20provided" rel="nofollow ugc">http://m.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html?utm_referrer=direct%2Fnot%20provided</a></p>
<p dir="auto">Just use anti seize on the long bolt and be prepared for the gunshot bang when the joint releases</p>
]]></description><link>https://wibimmers.com/post/61151</link><guid isPermaLink="true">https://wibimmers.com/post/61151</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Mon, 17 Aug 2015 15:19:00 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Mon, 17 Aug 2015 14:12:45 GMT]]></title><description><![CDATA[<p dir="auto">If you are reusing the ball joints do not use the pickle fork to separate them from the knuckle.  Once you have the nut off just tap on the knuckle with a hammer and the ball joint will separate.  If you use the pickle fork you will damage the boot and need a new ball joint.</p>
]]></description><link>https://wibimmers.com/post/61147</link><guid isPermaLink="true">https://wibimmers.com/post/61147</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Mon, 17 Aug 2015 14:12:45 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Mon, 17 Aug 2015 07:36:33 GMT]]></title><description><![CDATA[<p dir="auto">Sam and I did hers about two weekends ago and the lollipops popped right on with dish soap. No mallet or special tool needed. All lemforder parts too</p>
]]></description><link>https://wibimmers.com/post/61130</link><guid isPermaLink="true">https://wibimmers.com/post/61130</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Mon, 17 Aug 2015 07:36:33 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Mon, 17 Aug 2015 01:09:34 GMT]]></title><description><![CDATA[<p dir="auto">FYI the correct procedure is to use a lube like dishsoap and install them quickly and set the car on the ground before it dries so there is no preload. I always use centered e36 m3 bushings for e30 and e36 because they have more solid area vs air space. It's a fight but I have always done them with control arm on the car, lots of soap and twisting, a large deadblow hammer can help to get them started.</p>
<p dir="auto">Sent from my potato phone.</p>
]]></description><link>https://wibimmers.com/post/61122</link><guid isPermaLink="true">https://wibimmers.com/post/61122</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 17 Aug 2015 01:09:34 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Mon, 27 Jul 2015 19:59:40 GMT]]></title><description><![CDATA[<p dir="auto">i made a wood contraption to push the control arm into the bushing.  take long 2x4 or 2x6 and drill a hole in it just bigger than the end of the control arm. place the lollipop to position the opening over the hole. put some lag screws into the wood around the bracket part of the lollipop to hold it from rotating.  while standing on top of the 2x4, and using soap as a lube like others have said, twist twist twist and push down. its hard work but it will go down. make sure you stop every so often to check that you havent pushed it in too far!</p>
<p dir="auto">another thing that I've heard, but never tried, was to put your control arms in the freezer to get the metal to shrink a little to help it go in. if you do this make sure you let it warm back up to ambient temperature before you install it on the car.</p>
]]></description><link>https://wibimmers.com/post/60541</link><guid isPermaLink="true">https://wibimmers.com/post/60541</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 27 Jul 2015 19:59:40 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Sun, 26 Jul 2015 15:21:03 GMT]]></title><description><![CDATA[<p dir="auto">Thanks.  I'll give it a shot.</p>
]]></description><link>https://wibimmers.com/post/60503</link><guid isPermaLink="true">https://wibimmers.com/post/60503</guid><dc:creator><![CDATA[BenDem]]></dc:creator><pubDate>Sun, 26 Jul 2015 15:21:03 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Sun, 26 Jul 2015 15:13:42 GMT]]></title><description><![CDATA[<p dir="auto">Wifi spasm...</p>
]]></description><link>https://wibimmers.com/post/60502</link><guid isPermaLink="true">https://wibimmers.com/post/60502</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sun, 26 Jul 2015 15:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Sun, 26 Jul 2015 15:12:41 GMT]]></title><description><![CDATA[<p dir="auto">If the control arm is on the car I expect you would need the tool. I was replacing everything so did this with the control arm off the car.</p>
<p dir="auto">I used dawn dish soap uncut to lune the end of the CA and the sleeve on the cab and just threaded it on. The end of the lemforder control arm has a slight threading so you can just 'screw' it on. Grab the lollipop and rotate it clock wise as you push against the control arm. It will take a bit of work but it goes on. One side went on fairly easily. The other side I had to have someone stand on the control arm while I threaded on the CAB. Took a lot more muscle but I got it on.</p>
<p dir="auto">Make sure you have the lollipop orientation correct. I had to redo one.</p>
<p dir="auto">Not sure if it makes a difference but I was also using the m3 offset cabs.</p>
]]></description><link>https://wibimmers.com/post/60501</link><guid isPermaLink="true">https://wibimmers.com/post/60501</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sun, 26 Jul 2015 15:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Sun, 26 Jul 2015 15:03:04 GMT]]></title><description><![CDATA[<p dir="auto">Ya it's called soapy water, wood and a hammer</p>
]]></description><link>https://wibimmers.com/post/60500</link><guid isPermaLink="true">https://wibimmers.com/post/60500</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Sun, 26 Jul 2015 15:03:04 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Sun, 26 Jul 2015 14:56:34 GMT]]></title><description><![CDATA[<p dir="auto">My bushings are fine, it's just he control arm that needs replaced.   How did you get the bushing back on the control arm?  I thought you needed a special tool.</p>
]]></description><link>https://wibimmers.com/post/60499</link><guid isPermaLink="true">https://wibimmers.com/post/60499</guid><dc:creator><![CDATA[BenDem]]></dc:creator><pubDate>Sun, 26 Jul 2015 14:56:34 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Control Arm Bushing Tool. on Sun, 26 Jul 2015 13:45:52 GMT]]></title><description><![CDATA[<p dir="auto">A couple things that have worked for me:</p>
<p dir="auto">This works great for separating ball joints and tie rods from the control arm</p>
<p dir="auto"><a href="http://m.harborfreight.com/catalogsearch/result?q=ball+joint+separator" rel="nofollow ugc">http://m.harborfreight.com/catalogsearch/result?q=ball+joint+separator</a></p>
<p dir="auto">A basic gear puller will help get the bushing off the end of the control arm. Same one I used for the rear subframe bushing.</p>
<p dir="auto">For reinstall you can get lollipops with bushings already pressed in from bimmerworld if you don't want to use the vise , press route. Poly goes in easier.</p>
]]></description><link>https://wibimmers.com/post/60498</link><guid isPermaLink="true">https://wibimmers.com/post/60498</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sun, 26 Jul 2015 13:45:52 GMT</pubDate></item></channel></rss>
