<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 battery box repair help wanted]]></title><description><![CDATA[<p dir="auto">Dug into this today and it looks like I need a bit more battery box work than I thought on the beater e30.</p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/06/29/746d83d62da094313a6e3294c5242812.jpg" alt="746d83d62da094313a6e3294c5242812.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Before I start a beater quality repair job (sheet metal and a rivet gun) I thought I'd ask if there is anyone in the SE Wisconsin area with some cutting and welding skills that has done this before and might be able to help out. I'n not looking for restoration quality. Just want to see if there is a reasonable cost option out there that makes more sense than what will be my DIY hack job.</p>
]]></description><link>https://wibimmers.com/topic/3825/e30-battery-box-repair-help-wanted</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:04:29 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3825.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Jun 2015 00:38:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 battery box repair help wanted on Fri, 03 Jul 2015 00:09:37 GMT]]></title><description><![CDATA[<p dir="auto">Form follows function. Looks good to me!</p>
]]></description><link>https://wibimmers.com/post/59707</link><guid isPermaLink="true">https://wibimmers.com/post/59707</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 03 Jul 2015 00:09:37 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Thu, 02 Jul 2015 20:59:36 GMT]]></title><description><![CDATA[<p dir="auto">Done, now just need to let it all dry.</p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/07/02/662449a13035c275054bb7cc17e20097.jpg" alt="662449a13035c275054bb7cc17e20097.jpg" class=" img-fluid img-markdown" /><img src="http://images.tapatalk-cdn.com/15/07/02/b416e848fd06fb199d24a81a6ceb1168.jpg" alt="b416e848fd06fb199d24a81a6ceb1168.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/07/02/701419e082f96e95a52b659b6cd7d652.jpg" alt="701419e082f96e95a52b659b6cd7d652.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/07/02/e34bc728a0624ca12352d4653c7b8dfa.jpg" alt="e34bc728a0624ca12352d4653c7b8dfa.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/59703</link><guid isPermaLink="true">https://wibimmers.com/post/59703</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Thu, 02 Jul 2015 20:59:36 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Wed, 01 Jul 2015 22:10:18 GMT]]></title><description><![CDATA[<p dir="auto">Some progress. Need to wait 24hrs for the seam sealer to dry before painting the battery well and undercoating the outside.</p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/07/01/66364bbc5dfef33bf281d32ca6a42c30.jpg" alt="66364bbc5dfef33bf281d32ca6a42c30.jpg" class=" img-fluid img-markdown" /><img src="http://images.tapatalk-cdn.com/15/07/01/2e3a4067b77fe2b219f2fc4d92a1043a.jpg" alt="2e3a4067b77fe2b219f2fc4d92a1043a.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/07/01/897e44eed9f13d747d03936a906b7691.jpg" alt="897e44eed9f13d747d03936a906b7691.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/07/01/493f05f74518bd4eaadc8c8cc165ccc8.jpg" alt="493f05f74518bd4eaadc8c8cc165ccc8.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/59673</link><guid isPermaLink="true">https://wibimmers.com/post/59673</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Wed, 01 Jul 2015 22:10:18 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 20:20:22 GMT]]></title><description><![CDATA[<p dir="auto">I ended up going for the hack route. Did a bit more cutting, sprayed some rust reformer (yeah I know por-15 would have been better), cut and bent some sheet metal to fit, drilled for rivets, primed and an initial paint coat on the new piece.. Need to pick up some seam sealer. Should be able to finish up tomorrow. Install, rivet, seam seal, paint the inside, and undercoat the outside. We'll see how it turns out.</p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/06/30/977708ad5cae6fb1529a47a2aee0f699.jpg" alt="977708ad5cae6fb1529a47a2aee0f699.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/06/30/395ea0ed3fec9fd0163cc904479d8af4.jpg" alt="395ea0ed3fec9fd0163cc904479d8af4.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/59616</link><guid isPermaLink="true">https://wibimmers.com/post/59616</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 30 Jun 2015 20:20:22 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 19:10:55 GMT]]></title><description><![CDATA[<p dir="auto">Do you have an air compressor? </p>
<p dir="auto">I have a portable welding service if need be, but It would be interesting to do without my tools available. </p>
<p dir="auto">If possible, I could bend up the required section before I came, and then cut/weld to fit at your place. </p>
<p dir="auto">also, My tig is the only portable welder i have, unless you have 220v. </p>
<p dir="auto">I live in Princeton WI now. About 30 minutes west of fond du lac.</p>
]]></description><link>https://wibimmers.com/post/59615</link><guid isPermaLink="true">https://wibimmers.com/post/59615</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Tue, 30 Jun 2015 19:10:55 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 03:58:56 GMT]]></title><description><![CDATA[<p dir="auto">Understood.</p>
<p dir="auto">Yeah, welding has been on the learn to do list for a while and hasn't happened.</p>
<p dir="auto">I'll hold off on the full box option but appreciate the offer.</p>
]]></description><link>https://wibimmers.com/post/59586</link><guid isPermaLink="true">https://wibimmers.com/post/59586</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 30 Jun 2015 03:58:56 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 03:50:36 GMT]]></title><description><![CDATA[<p dir="auto">Since I am not a professional I still like to take my time with things to make sure they are done half way decent. I'm assuming that you don't have a welder, and in order for me to fix the rust I will have to have the car at my house. That's where the problem is. I simpley don't have the room to keep another car at my place to work on. It's easier for me to just work on my bench with a new box insert and then take a day cut metal out and weld it in the car.</p>
]]></description><link>https://wibimmers.com/post/59585</link><guid isPermaLink="true">https://wibimmers.com/post/59585</guid><dc:creator><![CDATA[johnprusinski]]></dc:creator><pubDate>Tue, 30 Jun 2015 03:50:36 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 03:31:35 GMT]]></title><description><![CDATA[<p dir="auto">Wow. No doubt that you could stand on it. That is one serious box!</p>
<p dir="auto">My battery well has enough metal that I don't think I need the full box insert. I'm looking for more of a repair of the back end of the well.</p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/06/29/cde449b21b2ce79d5ac36558b16a5cdb.jpg" alt="cde449b21b2ce79d5ac36558b16a5cdb.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://images.tapatalk-cdn.com/15/06/29/496d1ae76579ad13ff7f4d83036a3c2e.jpg" alt="496d1ae76579ad13ff7f4d83036a3c2e.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/59583</link><guid isPermaLink="true">https://wibimmers.com/post/59583</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 30 Jun 2015 03:31:35 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 03:16:19 GMT]]></title><description><![CDATA[<p dir="auto">Here is what I came up with.</p>
<p dir="auto"><a href="http://s892.photobucket.com/user/john_prusinski/media/FB_IMG_1435633731948_zpskjtsiosa.jpg.html" rel="nofollow ugc"><img src="http://i892.photobucket.com/albums/ac124/john_prusinski/FB_IMG_1435633731948_zpskjtsiosa.jpg" alt="FBIMG1435633731948zpskjtsiosa.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="http://s892.photobucket.com/user/john_prusinski/media/FB_IMG_1435633741731_zps3raoyucx.jpg.html" rel="nofollow ugc"><img src="http://i892.photobucket.com/albums/ac124/john_prusinski/FB_IMG_1435633741731_zps3raoyucx.jpg" alt="FBIMG1435633741731zps3raoyucx.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="http://s892.photobucket.com/user/john_prusinski/media/FB_IMG_1435633753420_zpskehy7q8m.jpg.html" rel="nofollow ugc"><img src="http://i892.photobucket.com/albums/ac124/john_prusinski/FB_IMG_1435633753420_zpskehy7q8m.jpg" alt="FBIMG1435633753420zpskehy7q8m.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I can weld, but they do not look pretty. They are strong though. I was standing on it the other day while I was taping my rear window. I can see if I still have the template and I can see if I can create something.</p>
]]></description><link>https://wibimmers.com/post/59582</link><guid isPermaLink="true">https://wibimmers.com/post/59582</guid><dc:creator><![CDATA[johnprusinski]]></dc:creator><pubDate>Tue, 30 Jun 2015 03:16:19 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 02:26:17 GMT]]></title><description><![CDATA[<p dir="auto">Will do.</p>
<p dir="auto">Front part of the box is solid, started digging into the rear pulling out loose paint and metal and the hole kept getting bigger. Joys of rust.</p>
]]></description><link>https://wibimmers.com/post/59580</link><guid isPermaLink="true">https://wibimmers.com/post/59580</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 30 Jun 2015 02:26:17 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 02:09:59 GMT]]></title><description><![CDATA[<p dir="auto">Keep us updated.</p>
]]></description><link>https://wibimmers.com/post/59579</link><guid isPermaLink="true">https://wibimmers.com/post/59579</guid><dc:creator><![CDATA[CMart]]></dc:creator><pubDate>Tue, 30 Jun 2015 02:09:59 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 02:04:20 GMT]]></title><description><![CDATA[<p dir="auto">Done. Thanks!</p>
]]></description><link>https://wibimmers.com/post/59578</link><guid isPermaLink="true">https://wibimmers.com/post/59578</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 30 Jun 2015 02:04:20 GMT</pubDate></item><item><title><![CDATA[Reply to E30 battery box repair help wanted on Tue, 30 Jun 2015 01:41:24 GMT]]></title><description><![CDATA[<p dir="auto">Johnprusinski rebuilt his e30 battery box. Try sending him a PM, not sure how much he gets on here.</p>
]]></description><link>https://wibimmers.com/post/59572</link><guid isPermaLink="true">https://wibimmers.com/post/59572</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Tue, 30 Jun 2015 01:41:24 GMT</pubDate></item></channel></rss>
