<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Engine Issues]]></title><description><![CDATA[<p dir="auto">So I have e30 325is and recently when I start her up on a half tank or less the revs drop to under 1 and the car sputters and dies, but when I have a full tank she starts right up, the revs are normal and does not die and acts totally normal. I was thinking it could be a possible fuel pump issue but Im not too sure. Anyone have any idea of whats the issue? Thanks!</p>
]]></description><link>https://wibimmers.com/topic/3772/engine-issues</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:41:51 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3772.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Jun 2015 02:25:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Engine Issues on Fri, 05 Jun 2015 14:19:10 GMT]]></title><description><![CDATA[<p dir="auto">On E28's there is an in tank transfer pump. If that fails they tend no not run or run like crap if the tank get lower than 1/4.</p>
]]></description><link>https://wibimmers.com/post/58791</link><guid isPermaLink="true">https://wibimmers.com/post/58791</guid><dc:creator><![CDATA[mkoepp]]></dc:creator><pubDate>Fri, 05 Jun 2015 14:19:10 GMT</pubDate></item><item><title><![CDATA[Reply to Engine Issues on Wed, 03 Jun 2015 17:36:22 GMT]]></title><description><![CDATA[<p dir="auto">From what you have laid out, the simplest explanation points to a fuel pressure issue. If you want to start throwing parts at it, then a fuel filter may not be a bad maintenance item to do. Checking fuel pressure with a gauge would be a proper first start though.</p>
]]></description><link>https://wibimmers.com/post/58696</link><guid isPermaLink="true">https://wibimmers.com/post/58696</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 03 Jun 2015 17:36:22 GMT</pubDate></item></channel></rss>
