<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[S65 missing a cam gear cover?!]]></title><description><![CDATA[<p dir="auto">Guys, check this out. I'm working on bluE92's car right now and we took off the valve cover to find some.......irregularities. I'm looking for thoughts. </p>
<p dir="auto">Pulled the cover off to find several abnormalities that are concerning and wanted to get some other opinions on the risk factor here. So basically, someone (prior owner or shop or something) drilled/ground out part of the original valve cover, as well as made a cut on the inside edge of the cylinder head surface where the cover/gasket attach to on one of the corners. That was troubling but whatever - the gasket around it wasn't leaking and seems to seal so ok..</p>
<p dir="auto">The bigger issue is this: I was looking around in the head for any other issues and noticed a chunk of plastic (clearly not manufactured) wedged between the wall of the cylinder head and a cam roller. Was able to pull it out with pliers pretty easily and inspect. Photos attached. </p>
<p dir="auto">Then we looked at the cam gear covers and noticed one of these covers is missing. I have attached a picture of what the BMW repair manual shows that they have covers on the end - one of the shafts is missing a cover altogether - again, photo attached. It looks like the piece of plastic I found was actually from the cover...also interesting is the cover that's missing is the one that should sit right next to the edge of the valve cover where someone at some point drilled/cut out part of the material. I am concerned that they damaged the cover in the process, and over time it ripped apart, thus the piece of plastic that was found inside the head. I'm concerned that there may be other pieces in there and it's just a matter of sheer dumb luck that the motor hasn't siezed yet - the piece of plastic we found, if loose, could easily find its way into the cam gear and destroy the motor. Again, see photos.</p>
<p dir="auto">I'm trying to get second opinions on how to proceed at this point i.e. get another cover? Do I trust there's no other hidden piece of shredded plastic waiting to wreck this car? What really sucks is that it looks like the part is not sold separately, but part of a larger assembly that costs $965 at Turner motorsports</p>
<p dir="auto">Here's how it SHOULD look:</p>
<p dir="auto"><a href="http://s1170.photobucket.com/user/wardjt1983/media/s65_correct_camgear_covers_zps9oiug8gn.png.html" rel="nofollow ugc"><img src="http://i1170.photobucket.com/albums/r526/wardjt1983/s65_correct_camgear_covers_zps9oiug8gn.png" alt="s65correctcamgearcoverszps9oiug8gn.p" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Here's what it currently looks like:</p>
<p dir="auto"><a href="http://s1170.photobucket.com/user/wardjt1983/media/fed_up_zpsgduo4d24.png.html" rel="nofollow ugc"><img src="http://i1170.photobucket.com/albums/r526/wardjt1983/fed_up_zpsgduo4d24.png" alt="fedupzpsgduo4d24.png" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Here is what happened to the valve cover when that corner was cut/drilled:</p>
<p dir="auto"><a href="http://s1170.photobucket.com/user/wardjt1983/media/IMG_0197_zpspjswgt4r.jpg.html" rel="nofollow ugc"><img src="http://i1170.photobucket.com/albums/r526/wardjt1983/IMG_0197_zpspjswgt4r.jpg" alt="IMG0197zpspjswgt4r.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">and finally here is the piece of plastic I removed from under the cam roller:</p>
<p dir="auto"><a href="http://s1170.photobucket.com/user/wardjt1983/media/IMG_0198_zpswvvrb1lh.jpg.html" rel="nofollow ugc"><img src="http://i1170.photobucket.com/albums/r526/wardjt1983/IMG_0198_zpswvvrb1lh.jpg" alt="IMG0198zpswvvrb1lh.jpg" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/topic/3633/s65-missing-a-cam-gear-cover</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:40:06 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3633.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Mar 2015 21:30:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to S65 missing a cam gear cover?! on Mon, 30 Mar 2015 15:49:19 GMT]]></title><description><![CDATA[<p dir="auto">If you need a new can gear let me know. I get employee pricing at the dealer. Would need to drive down to Woodstock and pick it up though. I would replace it most defenitly.</p>
]]></description><link>https://wibimmers.com/post/56473</link><guid isPermaLink="true">https://wibimmers.com/post/56473</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Mon, 30 Mar 2015 15:49:19 GMT</pubDate></item><item><title><![CDATA[Reply to S65 missing a cam gear cover?! on Sun, 29 Mar 2015 05:19:34 GMT]]></title><description><![CDATA[<p dir="auto">only piece of plastic found is that. Shavings already collected in the oil filter.</p>
]]></description><link>https://wibimmers.com/post/56416</link><guid isPermaLink="true">https://wibimmers.com/post/56416</guid><dc:creator><![CDATA[i_love_cars]]></dc:creator><pubDate>Sun, 29 Mar 2015 05:19:34 GMT</pubDate></item><item><title><![CDATA[Reply to S65 missing a cam gear cover?! on Sat, 28 Mar 2015 22:37:17 GMT]]></title><description><![CDATA[<p dir="auto">Yikes! My first thought was that the cover broke and caused the damage, but it's hard to believe a piece of plastic could take off that much aluminum. Is that the only piece of plastic you found? Any shavings/pieces in the oil pan or filter?</p>
]]></description><link>https://wibimmers.com/post/56396</link><guid isPermaLink="true">https://wibimmers.com/post/56396</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Sat, 28 Mar 2015 22:37:17 GMT</pubDate></item></channel></rss>
