<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Another new guy]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I may not live in WI anymore, but used to and I didn't get far, I can see your fair state outside my window. Thought I join up and see what's happening in the area. I have a few 2002s and M10 e30s. Bought my first '02 out of Stoughton many years ago.</p>
<p dir="auto">Anyway, I'm also looking for a M10 5-spd g240 transmission. '83 e21 preferable, but others will do. Core (bad transmission internals) is ok. I'll wander over to the WTB section...</p>
<p dir="auto">Thanks!</p>
<p dir="auto">Tim</p>
]]></description><link>https://wibimmers.com/topic/3599/another-new-guy</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:48:57 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3599.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Mar 2015 19:08:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Another new guy on Mon, 23 Mar 2015 12:52:11 GMT]]></title><description><![CDATA[<p dir="auto">Hip -- thanks for the link. Wow, that would be great if you'd like to sell me the leftovers. I'm thinking that'll likely be what I need.</p>
<p dir="auto">I'll shoot you a PM.</p>
]]></description><link>https://wibimmers.com/post/56160</link><guid isPermaLink="true">https://wibimmers.com/post/56160</guid><dc:creator><![CDATA[TimMN]]></dc:creator><pubDate>Mon, 23 Mar 2015 12:52:11 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sun, 22 Mar 2015 15:04:02 GMT]]></title><description><![CDATA[<p dir="auto">Here's a link that explains the bellhousing swap in case my explanation was just a confusing mess:</p>
<p dir="auto"><a href="http://www.bmwe21.net/forum/viewtopic.php?f=61&amp;t=19851" rel="nofollow ugc">http://www.bmwe21.net/forum/viewtopic.php?f=61&amp;t=19851</a></p>
]]></description><link>https://wibimmers.com/post/56113</link><guid isPermaLink="true">https://wibimmers.com/post/56113</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Sun, 22 Mar 2015 15:04:02 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sun, 22 Mar 2015 14:34:54 GMT]]></title><description><![CDATA[<p dir="auto">Okay. Be aware though that the e21 crossmember and shifter platform are different. The crossmember isn't a big deal, but the shifter may give you some trouble. The e30 shifter is generally regarded as a better design, but it doesn't work with the e21 trans. I've never looked at putting the e21 shifter in an e30, so no clue how hard that would be....</p>
<p dir="auto">I have an e21 g240, but it's for my swap. I've swapped the bellhousing with a m42 g240 so that I can have a working speedometer and use the stock shifter in my e21 after the m42 swap. This means I have a leftover e30 g240 and an m10 bellhousing... You could have them cheap if you want them <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/56112</link><guid isPermaLink="true">https://wibimmers.com/post/56112</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Sun, 22 Mar 2015 14:34:54 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sun, 22 Mar 2015 14:24:31 GMT]]></title><description><![CDATA[<p dir="auto">HipMF -- the preference for the e21 trans is for the mechanical speedo drive. For compatibility with '02s in case it gets swapped around down the road. It is a 'nice to have', not essential.</p>
<p dir="auto">A e30 m10 trans will work just fine in the e30!</p>
<p dir="auto">(I'm still looking...)</p>
]]></description><link>https://wibimmers.com/post/56111</link><guid isPermaLink="true">https://wibimmers.com/post/56111</guid><dc:creator><![CDATA[TimMN]]></dc:creator><pubDate>Sun, 22 Mar 2015 14:24:31 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 21 Mar 2015 14:37:51 GMT]]></title><description><![CDATA[<p dir="auto">Welcome</p>
]]></description><link>https://wibimmers.com/post/56067</link><guid isPermaLink="true">https://wibimmers.com/post/56067</guid><dc:creator><![CDATA[mkoepp]]></dc:creator><pubDate>Sat, 21 Mar 2015 14:37:51 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Fri, 20 Mar 2015 15:12:34 GMT]]></title><description><![CDATA[<p dir="auto">hmm? Why the preferance for an e21 trans if it's for an e30?</p>
]]></description><link>https://wibimmers.com/post/56028</link><guid isPermaLink="true">https://wibimmers.com/post/56028</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Fri, 20 Mar 2015 15:12:34 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Mon, 16 Mar 2015 08:31:20 GMT]]></title><description><![CDATA[<p dir="auto">Welcome! The 2002 looks great!</p>
]]></description><link>https://wibimmers.com/post/55813</link><guid isPermaLink="true">https://wibimmers.com/post/55813</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Mon, 16 Mar 2015 08:31:20 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sun, 15 Mar 2015 16:28:59 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the welcoming reception everyone.</p>
<p dir="auto">JC, I'm north of LaCrosse a bit.</p>
<p dir="auto">HipMF, good guess -- I've considered a M42 swap several times over the years,  but I'm sticking with the M10. The g240 trans is for one of my e30s, it came with an automatic.</p>
<p dir="auto">A g245 would bolt up, but I'm not sure if the driveshaft splines have enough travel to make up for the extra length of the transmission. They are also more popular with the '02 set.</p>
]]></description><link>https://wibimmers.com/post/55773</link><guid isPermaLink="true">https://wibimmers.com/post/55773</guid><dc:creator><![CDATA[TimMN]]></dc:creator><pubDate>Sun, 15 Mar 2015 16:28:59 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sun, 15 Mar 2015 16:23:21 GMT]]></title><description><![CDATA[<p dir="auto">Welcome to here</p>
]]></description><link>https://wibimmers.com/post/55771</link><guid isPermaLink="true">https://wibimmers.com/post/55771</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Sun, 15 Mar 2015 16:23:21 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sun, 15 Mar 2015 16:21:10 GMT]]></title><description><![CDATA[<p dir="auto">Welcome</p>
]]></description><link>https://wibimmers.com/post/55770</link><guid isPermaLink="true">https://wibimmers.com/post/55770</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Sun, 15 Mar 2015 16:21:10 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sun, 15 Mar 2015 00:39:43 GMT]]></title><description><![CDATA[<p dir="auto">Welcome aboard.</p>
]]></description><link>https://wibimmers.com/post/55748</link><guid isPermaLink="true">https://wibimmers.com/post/55748</guid><dc:creator><![CDATA[Narcosis]]></dc:creator><pubDate>Sun, 15 Mar 2015 00:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 14 Mar 2015 22:49:01 GMT]]></title><description><![CDATA[<p dir="auto">Nice!</p>
<p dir="auto">Let me take a guess; M42 swap? I have a spare G245, and a couple M42 G240s, but I'm guessing that doesn't help you...</p>
<p dir="auto">Welcome.</p>
]]></description><link>https://wibimmers.com/post/55744</link><guid isPermaLink="true">https://wibimmers.com/post/55744</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Sat, 14 Mar 2015 22:49:01 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 14 Mar 2015 14:38:00 GMT]]></title><description><![CDATA[<p dir="auto">Whereabouts on the river? I live in platteville but will be moving to the Albert lea MN in a couple months.</p>
]]></description><link>https://wibimmers.com/post/55725</link><guid isPermaLink="true">https://wibimmers.com/post/55725</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Sat, 14 Mar 2015 14:38:00 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 14 Mar 2015 14:30:36 GMT]]></title><description><![CDATA[<p dir="auto">Here's the presentable '02</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_03_2015_post-3596-0-57487200-1426343308.jpg"><img src="/assets/uploads/files/monthly_03_2015_post-3596-0-57487200-1426343308_thumb.jpg" alt="post-3596-0-57487200-1426343308thumb.jp" class=" img-fluid img-markdown" width="1000" height="668" /></a></p>
<p dir="auto">As for the other 2 2002s, one is a project, and the third is cheating -- it is my e46 dd.</p>
]]></description><link>https://wibimmers.com/post/55724</link><guid isPermaLink="true">https://wibimmers.com/post/55724</guid><dc:creator><![CDATA[TimMN]]></dc:creator><pubDate>Sat, 14 Mar 2015 14:30:36 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 14 Mar 2015 14:11:36 GMT]]></title><description><![CDATA[<p dir="auto">Welcome! I would love to own an 02 but it sounds like you have a strong hold on the supply. Haha looking forward to a shot of the collection.</p>
]]></description><link>https://wibimmers.com/post/55721</link><guid isPermaLink="true">https://wibimmers.com/post/55721</guid><dc:creator><![CDATA[DevianceInDark]]></dc:creator><pubDate>Sat, 14 Mar 2015 14:11:36 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 14 Mar 2015 04:43:13 GMT]]></title><description><![CDATA[<p dir="auto">Welcome! You can't tell us about an '02 collection and not post pics.</p>
]]></description><link>https://wibimmers.com/post/55715</link><guid isPermaLink="true">https://wibimmers.com/post/55715</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sat, 14 Mar 2015 04:43:13 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 14 Mar 2015 00:56:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/55702">Snap said:</a></strong></p>
<p dir="auto">I was dyslexic and read it as "i can see your state fair"</p>
<p dir="auto">I think Wisconsin has 5 state fairs.</p>
]]></description><link>https://wibimmers.com/post/55706</link><guid isPermaLink="true">https://wibimmers.com/post/55706</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Sat, 14 Mar 2015 00:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Sat, 14 Mar 2015 00:11:48 GMT]]></title><description><![CDATA[<p dir="auto">I was dyslexic and read it as "i can see your state fair"</p>
]]></description><link>https://wibimmers.com/post/55702</link><guid isPermaLink="true">https://wibimmers.com/post/55702</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sat, 14 Mar 2015 00:11:48 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Fri, 13 Mar 2015 23:30:38 GMT]]></title><description><![CDATA[<p dir="auto">Welcome!</p>
]]></description><link>https://wibimmers.com/post/55700</link><guid isPermaLink="true">https://wibimmers.com/post/55700</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Fri, 13 Mar 2015 23:30:38 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Fri, 13 Mar 2015 22:44:23 GMT]]></title><description><![CDATA[<p dir="auto">Welcome</p>
]]></description><link>https://wibimmers.com/post/55694</link><guid isPermaLink="true">https://wibimmers.com/post/55694</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 13 Mar 2015 22:44:23 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Fri, 13 Mar 2015 21:14:45 GMT]]></title><description><![CDATA[<p dir="auto">Nope, I'm in the Mississippi river valley.</p>
]]></description><link>https://wibimmers.com/post/55689</link><guid isPermaLink="true">https://wibimmers.com/post/55689</guid><dc:creator><![CDATA[TimMN]]></dc:creator><pubDate>Fri, 13 Mar 2015 21:14:45 GMT</pubDate></item><item><title><![CDATA[Reply to Another new guy on Fri, 13 Mar 2015 20:20:45 GMT]]></title><description><![CDATA[<p dir="auto">So you live on a houseboat on Lake Michigan?  Where do you park the 02's?</p>
]]></description><link>https://wibimmers.com/post/55687</link><guid isPermaLink="true">https://wibimmers.com/post/55687</guid><dc:creator><![CDATA[REKIII]]></dc:creator><pubDate>Fri, 13 Mar 2015 20:20:45 GMT</pubDate></item></channel></rss>
