<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[driveline fluid for my E46 XI]]></title><description><![CDATA[<p dir="auto">In my quest for diff and TC fluids, I found out a couple things.I am more or less looking for input on said fluids I plan on using, and any experience with them as well. I plan on using Pentosin MTF2 75w-80 GL4 in the trans(manual) and the TC. I understand some use redline ATF fluid for that, but after reading a post on E46fanatics,  an oil analysis showed Pentosin to be closest to OE spec fluid and with the TC being all gear driven, it made sense to me.</p>
<p dir="auto">The second part is the diff fluid. It seems Redline 75w-90 is the go to for this, but my old indy shop says he wouldn't.(They only use OE fluids from BMW). Zimbrick wants 22 bucks for half a qt.... <img src="/assets/uploads/files/emoticons_default_ohmy.png" alt=":o" class=" img-fluid img-markdown" width="20" height="20" /> seems excessive to me...I was going to use either redline, liquimoly, or Castrol syntrax. Any input on the matter is appreciated!</p>
]]></description><link>https://wibimmers.com/topic/3534/driveline-fluid-for-my-e46-xi</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:02:32 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3534.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Feb 2015 03:10:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to driveline fluid for my E46 XI on Thu, 19 Feb 2015 04:15:31 GMT]]></title><description><![CDATA[<p dir="auto">I would agree. I think the pentosin will work well.</p>
<p dir="auto">Sent from my BMW GS4 using tapatalk</p>
]]></description><link>https://wibimmers.com/post/54479</link><guid isPermaLink="true">https://wibimmers.com/post/54479</guid><dc:creator><![CDATA[Spezio]]></dc:creator><pubDate>Thu, 19 Feb 2015 04:15:31 GMT</pubDate></item><item><title><![CDATA[Reply to driveline fluid for my E46 XI on Thu, 19 Feb 2015 02:18:31 GMT]]></title><description><![CDATA[<p dir="auto">Pretty sure I used Amsoil 75-90 if I remember correctly. This reminds me that I should probably do the diff fluid this spring, it's been about 4 years now. I really wouldn't worry about the brand of fluid for the diff so much as the trans.</p>
]]></description><link>https://wibimmers.com/post/54462</link><guid isPermaLink="true">https://wibimmers.com/post/54462</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 19 Feb 2015 02:18:31 GMT</pubDate></item><item><title><![CDATA[Reply to driveline fluid for my E46 XI on Thu, 19 Feb 2015 00:14:16 GMT]]></title><description><![CDATA[<p dir="auto">In my g250 manual which calls for dexron3 I have used Royal Purple Synchromax (their fluid for manuals that require ATF).  I switched to the UUC recommended Redline atf/gear oil mix when I put in the lightweight flywheel and the transmission seems to shift nicer.  This may only apply to the g250 though.</p>
]]></description><link>https://wibimmers.com/post/54455</link><guid isPermaLink="true">https://wibimmers.com/post/54455</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 19 Feb 2015 00:14:16 GMT</pubDate></item><item><title><![CDATA[Reply to driveline fluid for my E46 XI on Wed, 18 Feb 2015 15:12:16 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! There does seem to be more of debate when it comes to tranny fluid. I am between mobil and redline at the moment for the diff.. What do you run in your non M diff wasnt m3? (i thought you had the 3 wagon too)</p>
]]></description><link>https://wibimmers.com/post/54421</link><guid isPermaLink="true">https://wibimmers.com/post/54421</guid><dc:creator><![CDATA[Spezio]]></dc:creator><pubDate>Wed, 18 Feb 2015 15:12:16 GMT</pubDate></item><item><title><![CDATA[Reply to driveline fluid for my E46 XI on Wed, 18 Feb 2015 14:04:46 GMT]]></title><description><![CDATA[<p dir="auto">I find that the tranny fluid can make a huge difference, I ran royal purple in my e36 ZF this year and was very impressed by it. <br />
In regards to diff fluid for the e46 I just did mine with mobile 1 gear oil and it doesn't make any more noise than before, and may be a little bit smoother but it is pretty hard to tell. <br />
It seems that they are picky with what fluid you put in the trans, but don't really care whats in the diff.</p>
]]></description><link>https://wibimmers.com/post/54413</link><guid isPermaLink="true">https://wibimmers.com/post/54413</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 18 Feb 2015 14:04:46 GMT</pubDate></item><item><title><![CDATA[Reply to driveline fluid for my E46 XI on Wed, 18 Feb 2015 05:02:16 GMT]]></title><description><![CDATA[<p dir="auto">I recently changed from royal purple to redline mtl in the transmission in my m roadster and couldn't believe the difference. Feels so much smoother. I ordered from pegasus and had it next day.</p>
]]></description><link>https://wibimmers.com/post/54401</link><guid isPermaLink="true">https://wibimmers.com/post/54401</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Wed, 18 Feb 2015 05:02:16 GMT</pubDate></item></channel></rss>
