<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Spacers]]></title><description><![CDATA[<p dir="auto">What do you guys think the best way to go for 20-25mm spacers? The kind where they bolt to the hub then the wheel bolts to the spacer or a straight bolt through?</p>
]]></description><link>https://wibimmers.com/topic/3468/spacers</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:37:28 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3468.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Jan 2015 04:48:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Spacers on Mon, 02 Feb 2015 05:07:35 GMT]]></title><description><![CDATA[<p dir="auto">i've used 15/20mm spacer with long bolts, and also 4x100 to 5x120 adapters and have had no problems with failures.  However, I've stopped using all of them because they are a monumental pain the in butt, usually.  Wheel changes are harder, you have to have extra regular length lugs if you are still using winter tires which dont use spacers, and if you've ever had a spacer get seized to the hub, you'll want to kill yourself.</p>
]]></description><link>https://wibimmers.com/post/53643</link><guid isPermaLink="true">https://wibimmers.com/post/53643</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 02 Feb 2015 05:07:35 GMT</pubDate></item><item><title><![CDATA[Reply to Spacers on Thu, 29 Jan 2015 13:53:45 GMT]]></title><description><![CDATA[<p dir="auto">Opinion: I can't say I like that design for a 20mm spacer. The machined hole with taper for the lug seat must go through like 60%-70% (or more) of the spacer to leave enough room for the lug head to be fully recessed. Really doesn't leave a lot of material for structural strength....</p>
<p dir="auto">IDK... I just know 20mm spacers aren't huge - so machining a majority of it away to allow for a recessed lug just worries me. That and using lug bolts blow.</p>
<p dir="auto">My 20mm spacers for visual reference:</p>
<p dir="auto"><a href="http://s10.photobucket.com/user/CollinRice/media/5FB72257-5DFB-4B45-BB45-26A2CF53E273.jpg.html" rel="nofollow ugc"><img src="http://i10.photobucket.com/albums/a137/CollinRice/5FB72257-5DFB-4B45-BB45-26A2CF53E273.jpg" alt="5FB72257-5DFB-4B45-BB45-26A2CF53E273.jpg" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/53447</link><guid isPermaLink="true">https://wibimmers.com/post/53447</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Thu, 29 Jan 2015 13:53:45 GMT</pubDate></item><item><title><![CDATA[Reply to Spacers on Thu, 29 Jan 2015 05:56:14 GMT]]></title><description><![CDATA[<p dir="auto">Alright. Thanks for the input guys!</p>
]]></description><link>https://wibimmers.com/post/53440</link><guid isPermaLink="true">https://wibimmers.com/post/53440</guid><dc:creator><![CDATA[nick.e46.330i.]]></dc:creator><pubDate>Thu, 29 Jan 2015 05:56:14 GMT</pubDate></item><item><title><![CDATA[Reply to Spacers on Thu, 29 Jan 2015 03:30:34 GMT]]></title><description><![CDATA[<p dir="auto">Either. The spacers that use existing wheel studs would be best if used with ARP wheel studs</p>
]]></description><link>https://wibimmers.com/post/53433</link><guid isPermaLink="true">https://wibimmers.com/post/53433</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 29 Jan 2015 03:30:34 GMT</pubDate></item><item><title><![CDATA[Reply to Spacers on Wed, 28 Jan 2015 19:42:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/53305">Snap said:</a></strong></p>
<p dir="auto">H&amp;R trak+ spacers with green loctite and the correct hubcentric diameter to match the wheels you have is the way I would do it.</p>
<p dir="auto">Do you mean these?</p>
<p dir="auto"><a href="http://www.ecstuning.com/BMW-E46-330i-M54_3.0L/Wheels/Spacers/H-and-R/20mm/ES1303529/" rel="nofollow ugc">http://www.ecstuning.com/BMW-E46-330i-M54_3.0L/Wheels/Spacers/H-and-R/20mm/ES1303529/</a></p>
<p dir="auto">Or these?</p>
<p dir="auto"><a href="http://www.ecstuning.com/BMW-E46-330i-M54_3.0L/Wheels/Spacers/H-and-R/20mm/ES319/" rel="nofollow ugc">http://www.ecstuning.com/BMW-E46-330i-M54_3.0L/Wheels/Spacers/H-and-R/20mm/ES319/</a></p>
]]></description><link>https://wibimmers.com/post/53394</link><guid isPermaLink="true">https://wibimmers.com/post/53394</guid><dc:creator><![CDATA[nick.e46.330i.]]></dc:creator><pubDate>Wed, 28 Jan 2015 19:42:13 GMT</pubDate></item><item><title><![CDATA[Reply to Spacers on Wed, 28 Jan 2015 19:17:07 GMT]]></title><description><![CDATA[<p dir="auto">I'm running hubcentric 20mm spacers: Motorsports Hardware studs (loctite'd) and DUN.</p>
]]></description><link>https://wibimmers.com/post/53390</link><guid isPermaLink="true">https://wibimmers.com/post/53390</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Wed, 28 Jan 2015 19:17:07 GMT</pubDate></item><item><title><![CDATA[Reply to Spacers on Tue, 27 Jan 2015 16:02:18 GMT]]></title><description><![CDATA[<p dir="auto">I have some 1.5 inch spacers on my truck. They bolt on and came with locktite for the studs. Get quality hubcentric ones. Don't go with cheap/ebay ones.</p>
]]></description><link>https://wibimmers.com/post/53308</link><guid isPermaLink="true">https://wibimmers.com/post/53308</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 27 Jan 2015 16:02:18 GMT</pubDate></item><item><title><![CDATA[Reply to Spacers on Tue, 27 Jan 2015 07:53:43 GMT]]></title><description><![CDATA[<p dir="auto">H&amp;R trak+ spacers with green loctite and the correct hubcentric diameter to match the wheels you have is the way I would do it.</p>
]]></description><link>https://wibimmers.com/post/53305</link><guid isPermaLink="true">https://wibimmers.com/post/53305</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 27 Jan 2015 07:53:43 GMT</pubDate></item></channel></rss>
