<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NCS Expert and Coding]]></title><description><![CDATA[<p dir="auto">Thought I would let folks know that I will have the ability to code BMW's here in a few weeks. I ordered a cable:</p>
<p dir="auto"><a href="http://www.ebay.com/itm/160657246345?ssPageName=STRK:MEWNX:IT&amp;_trksid=p3984.m1497.l2649" rel="nofollow ugc">http://www.ebay.com/itm/160657246345?ssPageName=STRK:MEWNX:IT&amp;_trksid=p3984.m1497.l2649</a></p>
<p dir="auto">The cable with the NCS Expert software will let me code. Should be pretty fun. Let me know if anyone is interested in learning. We could drink beer and learn to code bimmers (like nothing could go wrong with that scenario).</p>
]]></description><link>https://wibimmers.com/topic/335/ncs-expert-and-coding</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:47:46 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/335.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Oct 2011 14:24:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NCS Expert and Coding on Thu, 17 Nov 2011 21:10:50 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>Snyperx said:</strong></p>
<p dir="auto">I would need to check. I know I could get them. The only issue is the cable I have only works on the newer BMW's that use the OBD type connector.</p>
<p dir="auto">E46 has the OBDII interface, let me know if you can get the files. There's some stuff I'd like to get programmed s well! Thanks.</p>
]]></description><link>https://wibimmers.com/post/3950</link><guid isPermaLink="true">https://wibimmers.com/post/3950</guid><dc:creator><![CDATA[zer0kid]]></dc:creator><pubDate>Thu, 17 Nov 2011 21:10:50 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Thu, 17 Nov 2011 00:09:35 GMT]]></title><description><![CDATA[<p dir="auto">I would need to check. I know I could get them. The only issue is the cable I have only works on the newer BMW's that use the OBD type connector.</p>
]]></description><link>https://wibimmers.com/post/3942</link><guid isPermaLink="true">https://wibimmers.com/post/3942</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Thu, 17 Nov 2011 00:09:35 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Tue, 15 Nov 2011 21:43:26 GMT]]></title><description><![CDATA[<p dir="auto">Do you have the data files for an E46 and Winfpk?</p>
]]></description><link>https://wibimmers.com/post/3921</link><guid isPermaLink="true">https://wibimmers.com/post/3921</guid><dc:creator><![CDATA[zer0kid]]></dc:creator><pubDate>Tue, 15 Nov 2011 21:43:26 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Mon, 14 Nov 2011 20:08:56 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>need4speed1299 said:</strong></p>
<p dir="auto">This is interesting. Is this just for the body control?</p>
<p dir="auto">Yes, mostly body control (lights, light testing, windows, mirrors, etc...) I did read an article on a potential way to code out the speed limiter, but that is pretty advanced. I am not even close to that yet.</p>
]]></description><link>https://wibimmers.com/post/3906</link><guid isPermaLink="true">https://wibimmers.com/post/3906</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Mon, 14 Nov 2011 20:08:56 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Fri, 11 Nov 2011 05:29:25 GMT]]></title><description><![CDATA[<p dir="auto">This is interesting. Is this just for the body control?</p>
]]></description><link>https://wibimmers.com/post/3874</link><guid isPermaLink="true">https://wibimmers.com/post/3874</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Fri, 11 Nov 2011 05:29:25 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Fri, 11 Nov 2011 03:52:23 GMT]]></title><description><![CDATA[<p dir="auto">Just did my first code a little bit ago. I programmed the feature to be able to put all my windows up using the key FOB. Now I need to disable the cold bulb checking feature in preparation for my new LED tail lights and LED angel eye headlights.</p>
]]></description><link>https://wibimmers.com/post/3873</link><guid isPermaLink="true">https://wibimmers.com/post/3873</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Fri, 11 Nov 2011 03:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Sat, 05 Nov 2011 14:34:20 GMT]]></title><description><![CDATA[<p dir="auto">Well I got my cable in them mail and connected up the car and was able to do some basic connectivity checks and everything worked great. I have not tried to code anything yet, but am going to work on getting a full backup of the car prior. The first code I want to do is to make it so all the windows close when the vehicle is locked from the key fob. She be pretty cool. I also am looking at after market headlights and will need to code out a couple of the bulb checks so the car doesn't throw errors. The other option is to purchase cancellers which I don't want to do.</p>
]]></description><link>https://wibimmers.com/post/3803</link><guid isPermaLink="true">https://wibimmers.com/post/3803</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Sat, 05 Nov 2011 14:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Sun, 30 Oct 2011 14:47:23 GMT]]></title><description><![CDATA[<p dir="auto">I don't see the real advantage of this since you own a e90? With all e9x and newer vehicles almost all the control modules that you replace programming and coding are needed to properly replace it. SO you can only do half of that. I guess if you worked on older vehicles it could be helpful but does this work on all bmw's?</p>
]]></description><link>https://wibimmers.com/post/3668</link><guid isPermaLink="true">https://wibimmers.com/post/3668</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Sun, 30 Oct 2011 14:47:23 GMT</pubDate></item><item><title><![CDATA[Reply to NCS Expert and Coding on Thu, 27 Oct 2011 20:55:16 GMT]]></title><description><![CDATA[<p dir="auto">IBUS interface as well? <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">Ahhh to have newer bmw <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/3598</link><guid isPermaLink="true">https://wibimmers.com/post/3598</guid><dc:creator><![CDATA[camarok]]></dc:creator><pubDate>Thu, 27 Oct 2011 20:55:16 GMT</pubDate></item></channel></rss>
