  4. 1997 540i/A: High mileage ballin' on a budget.
53 Posts 9 Posters 0 Views 1 Watching
    The e39 get noisy when the guibo and/or the drive shaft center bearing gets worn.  Both replaceable (center bearing much less easily)  Rear wheel bearing will also cause weird vibrational humming.
      Do these still have the oil pump bolt falling out issues? A guy at work just got a 93 740iL and we need to check it because its common for the oil pump bolts to drop out until self destruction happens. Once the pump gets loose oil pressure is lost. If you haven't changed the oil yet it could be the wrong viscosity too.
      Sent from my potato phone
        I don't know about the bolts. Might not be a bad idea to check this out when I flush my trans.
        As for guibo/csb, I don't think it's that. The sound occurs occasionally, and I can go a whole day without it making noises. I need to really get under this thing and do some investigating.
          In before snap replies with the proper spelling of giubo.
            We prefer the incorrect spelling here, snap. What do you think this is, the MacArthur foundation? You think this is a satellite forum for Mensa? You think I got enough book learnin' to make the spelling not wrong?
            • CMartC
              CMartC
              CMart
              Yes
              Do these still have the oil pump bolt falling out issues? A guy at work just got a 93 740iL and we need to check it because its common for the oil pump bolts to drop out until self destruction happens. Once the pump gets loose oil pressure is lost. If you haven't changed the oil yet it could be the wrong viscosity too. Sent from my potato phone
              Excursion 7.3
              E30 LS1
                Shapow!
                You gettin this, camera guy?
                New roundel. Replaced bad courtesy light. replaced a burned out tail light bulb. Cleaned interior. Found a Lego man.
                  rampelsauce said:
                  Found a Lego man.
                  #WINNING. Is that roundel going in the collection?
                    Yes, the box is getting wonderfully full.
                    Edit:  Getting my 18's mounted/balanced next week.  Test fits soon, and will be broadcast here.
                    Also, working on a deal for some snows.  Picked up a new washer pump to replace my faulty one.
                      Snows installed, on car, kickin' ass.
                      So, I didn't get my 18's mounted yet because I'm trying to figure out what color to power coat them.
                      Bronze with a black lip?  Black with a bronze lip?  Hmmm.
                      I photoshopped a crappy picture of bronze with a black lip.
                      post-2584-0-08477600-1421547858thumb.pn
                        Is the interior tan?
                          Nope. Black on black, murdah'd out.
                            I say medium-dark gray satin finish
                            No metallic
                              I really like the bronze color though. Here's a sample piece I did. It's a bike hub.
                                Yeah i think that would look nice, all the same color though, no black/silver/purple lip
                                  If I don't sell them, I might keep the polished lip and do the centers bronze.
                                    e98359666412addbf132f79929380e35.jpgc445e60737c2c7dd929171b1e38b9c39.jpg915e674c5c743ded226d31526df4929a.jpg71b8e6a6e9958ba08f26fa46cf58edb8.jpg1e025f386af2550e1b0191785f890342.jpgf4b15502fc7e7aec4cb2b5a8e6faf14c.jpg
                                      It got cold so I stopped snapping pictures. No more scuba tank. Sounds pretty damn good. Throaty under load, huge difference. I'll post some post op pictures and a video with some sound. I posted an instagram video of the exhaust before I patched it, so follow me @rampelsauce.
                                        OE german exhaust systems be cray
                                        Is this what Dominic did to his car as well? That car sounds glorious
                                          OE german exhaust systems be cray Is this what Dominic did to his car as well? That car sounds glorious
                                          Muffler delete.  My car is like that, but quieter.  Getting rid of the tank makes a huge difference.
