<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Diff fluid pump]]></title><description><![CDATA[<p dir="auto">Need to change the fluid in my diff. Looked up several DIY's for it and it seems pretty simple. My only question concerns putting the new fluid back in. I keep seeing references to pumping it back into the top hole, but, not sure what I'd pump it with. Anyone have any suggestions?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://wibimmers.com/topic/3306/diff-fluid-pump</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:42:54 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3306.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Dec 2014 00:09:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 23:29:08 GMT]]></title><description><![CDATA[<p dir="auto">Thanks all. Found a pump like the ones a few of you mentioned at Auto Zone. Now to pick up some fluid, and then make sure I can get the two plugs out before I start.</p>
]]></description><link>https://wibimmers.com/post/50618</link><guid isPermaLink="true">https://wibimmers.com/post/50618</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Thu, 04 Dec 2014 23:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 16:58:47 GMT]]></title><description><![CDATA[<p dir="auto">I just use a hand transfer pump from advance auto like this one. one tube goes into the diff fluid bottle and the other into the fill hole on the diff. You could even drain it this way too I suppose, just reverse the hoses.</p>
<p dir="auto"><img src="http://www.autobodytoolmart.com/images/Product/large/MTY-MV7241-Fluid-Transfer-Pump.jpg" alt="MTY-MV7241-Fluid-Transfer-Pump.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/50583</link><guid isPermaLink="true">https://wibimmers.com/post/50583</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Thu, 04 Dec 2014 16:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 05:03:50 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/50552">Boris3 said:</a></strong></p>
<p dir="auto">To the OP one key thing in changing diff or tyranny fluid if you've never done it before. Make sure you can open the fill plug before you remove the drain plug.</p>
<p dir="auto">This</p>
]]></description><link>https://wibimmers.com/post/50554</link><guid isPermaLink="true">https://wibimmers.com/post/50554</guid><dc:creator><![CDATA[michael1972]]></dc:creator><pubDate>Thu, 04 Dec 2014 05:03:50 GMT</pubDate></item><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 04:13:17 GMT]]></title><description><![CDATA[<p dir="auto">Unless you're using Redline... or maybe I've just had bad luck. Pumps never seem to fit.</p>
]]></description><link>https://wibimmers.com/post/50552</link><guid isPermaLink="true">https://wibimmers.com/post/50552</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Thu, 04 Dec 2014 04:13:17 GMT</pubDate></item><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 02:46:00 GMT]]></title><description><![CDATA[<p dir="auto">I should mention that my solution was done in a pinch, it was really late at night and I had forgotten about those pumps haha</p>
]]></description><link>https://wibimmers.com/post/50550</link><guid isPermaLink="true">https://wibimmers.com/post/50550</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Thu, 04 Dec 2014 02:46:00 GMT</pubDate></item><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 02:15:33 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/50537">wasnt m3 said:</a></strong></p>
<p dir="auto">You can buy pumps specifically for this at Auto Zone for $8. Threads right onto the diff fluid container.</p>
<p dir="auto">This, they look like a hand soap pump but bigger.</p>
]]></description><link>https://wibimmers.com/post/50546</link><guid isPermaLink="true">https://wibimmers.com/post/50546</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 04 Dec 2014 02:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 01:00:13 GMT]]></title><description><![CDATA[<p dir="auto">You can buy pumps specifically for this at Auto Zone for $8. Threads right onto the diff fluid container.</p>
]]></description><link>https://wibimmers.com/post/50537</link><guid isPermaLink="true">https://wibimmers.com/post/50537</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 04 Dec 2014 01:00:13 GMT</pubDate></item><item><title><![CDATA[Reply to Diff fluid pump on Thu, 04 Dec 2014 00:57:30 GMT]]></title><description><![CDATA[<p dir="auto">When I changed my diff mount (I removed the diff cover so I had to drain the fluid) I used a longish piece of clear flexible tubing pushed onto the end of a funnel. I ran the tubing from the fill hole up out the top of the passenger side rear wheel-well and had a friend pour the fluid into the funnel while I held the other end in the fill hole. It worked quite well actually</p>
]]></description><link>https://wibimmers.com/post/50536</link><guid isPermaLink="true">https://wibimmers.com/post/50536</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Thu, 04 Dec 2014 00:57:30 GMT</pubDate></item></channel></rss>
