<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What's a good substitute for Dextron II?]]></title><description><![CDATA[<p dir="auto">Getting a light thunk in the trans (88 325i automatic) between 2nd and 1st gear when slowing down, usually around 20mph. I'm thinking that I may need to add a little trans fluid, however, the manual calls for Dextron II, and it isn't made anymore. What is everybody using as a substitute these days? Don't want to buy the wrong stuff and end up burning a trans.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://wibimmers.com/topic/3221/what-s-a-good-substitute-for-dextron-ii</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:52:32 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3221.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Nov 2014 21:57:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What's a good substitute for Dextron II? on Mon, 03 Nov 2014 02:51:55 GMT]]></title><description><![CDATA[<p dir="auto">FWIW I'm running Redline D4 ATF in the 318is MT.</p>
]]></description><link>https://wibimmers.com/post/49344</link><guid isPermaLink="true">https://wibimmers.com/post/49344</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Mon, 03 Nov 2014 02:51:55 GMT</pubDate></item><item><title><![CDATA[Reply to What's a good substitute for Dextron II? on Sun, 02 Nov 2014 22:11:00 GMT]]></title><description><![CDATA[<p dir="auto">Great! Thanks!</p>
]]></description><link>https://wibimmers.com/post/49338</link><guid isPermaLink="true">https://wibimmers.com/post/49338</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Sun, 02 Nov 2014 22:11:00 GMT</pubDate></item><item><title><![CDATA[Reply to What's a good substitute for Dextron II? on Sun, 02 Nov 2014 22:04:43 GMT]]></title><description><![CDATA[<p dir="auto">Dexron III and Dexron IV "meet or exceed" Dexron II specifications</p>
<p dir="auto">Using dexron III or IV when dexron II is called for is perfectly acceptable. Id run Valvoline Max-Life ATF if I were you</p>
]]></description><link>https://wibimmers.com/post/49337</link><guid isPermaLink="true">https://wibimmers.com/post/49337</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 02 Nov 2014 22:04:43 GMT</pubDate></item></channel></rss>
