<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need help replacing starter]]></title><description><![CDATA[<p dir="auto">in a 1989 325i. I need to get this installed to be able to sell the car. Someone who can help me install it for really cheap. I'm at UWM, as is the car. 414-204-3455.</p>
]]></description><link>https://wibimmers.com/topic/3140/need-help-replacing-starter</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:49:41 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3140.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Oct 2014 03:08:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need help replacing starter on Thu, 02 Oct 2014 00:50:15 GMT]]></title><description><![CDATA[<p dir="auto">3/8" 12pt wrench will hold the torx head bolts on the trans side, just get it in place and let it hit the bell housing to keep the bolt from turning and you will be able to remove the nuts from the engine side.</p>
]]></description><link>https://wibimmers.com/post/48117</link><guid isPermaLink="true">https://wibimmers.com/post/48117</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 02 Oct 2014 00:50:15 GMT</pubDate></item><item><title><![CDATA[Reply to Need help replacing starter on Wed, 01 Oct 2014 23:55:54 GMT]]></title><description><![CDATA[<p dir="auto">Ive removed and installed my starter with the manifold in place with just some socket extensions and the intake boot removed</p>
]]></description><link>https://wibimmers.com/post/48114</link><guid isPermaLink="true">https://wibimmers.com/post/48114</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 01 Oct 2014 23:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to Need help replacing starter on Wed, 01 Oct 2014 23:08:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/48070">jkisting said:</a></strong></p>
<p dir="auto">Hit up Rawsomotion in germantown.</p>
<p dir="auto">You can do the started yourself. I just helped my brother in August do his starter on his 1991 525i. So probably a very similar if not the same job.</p>
<p dir="auto">You remove the intake manifold and coolant hoses/whatever is in your way. and remove the starter. Can be done in under 2 hours. Start to finish.</p>
]]></description><link>https://wibimmers.com/post/48107</link><guid isPermaLink="true">https://wibimmers.com/post/48107</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Wed, 01 Oct 2014 23:08:27 GMT</pubDate></item></channel></rss>
