<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E39 Overheating]]></title><description><![CDATA[<p dir="auto">Hey!! New to this site and hopefully able to get some input. My 01 530i keeps overheating after several "thought to be the problem" fixes.</p>
<p dir="auto">Including....</p>
<p dir="auto">Radiator</p>
<p dir="auto">Overflow resevoir tank that had a small crack</p>
<p dir="auto">Coil packs</p>
<p dir="auto">Fan Clutch</p>
<p dir="auto">We have taken alot of time to bleed thinking thats the issue. Still no luck. A local shop said its a hsad gasket...but hopefully its something else that could be checked.</p>
<p dir="auto">Thanks!!!!</p>
]]></description><link>https://wibimmers.com/topic/3029/e39-overheating</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:16 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3029.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Aug 2014 18:09:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E39 Overheating on Mon, 18 Aug 2014 23:12:55 GMT]]></title><description><![CDATA[<p dir="auto">Dont fix it let it sit in your driveway for 3 months. Thats what Ive been doing with mine lol. I dont overheat just coolant leak and Ive replaced all the same you have minus water pump :/. When were you headgaskets last done?</p>
<p dir="auto">Sent from my LG-LS970 using Tapatalk</p>
]]></description><link>https://wibimmers.com/post/46552</link><guid isPermaLink="true">https://wibimmers.com/post/46552</guid><dc:creator><![CDATA[I love my E39]]></dc:creator><pubDate>Mon, 18 Aug 2014 23:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to E39 Overheating on Mon, 18 Aug 2014 20:07:10 GMT]]></title><description><![CDATA[<p dir="auto">Like snap said make sure you bleed the cooling system untill you have heat or the car will always over heat</p>
]]></description><link>https://wibimmers.com/post/46551</link><guid isPermaLink="true">https://wibimmers.com/post/46551</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 18 Aug 2014 20:07:10 GMT</pubDate></item><item><title><![CDATA[Reply to E39 Overheating on Mon, 18 Aug 2014 20:06:13 GMT]]></title><description><![CDATA[<p dir="auto">If you replaced the water pump and thermostat and that was not it you most Likely need a head gasket after the overheat the first time I would. Check the coolant tank pressure while running check spark plugs for discoloration.</p>
<p dir="auto">Pressure rest the coolant system and leak test the cylinders.</p>
]]></description><link>https://wibimmers.com/post/46550</link><guid isPermaLink="true">https://wibimmers.com/post/46550</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 18 Aug 2014 20:06:13 GMT</pubDate></item><item><title><![CDATA[Reply to E39 Overheating on Mon, 18 Aug 2014 20:00:16 GMT]]></title><description><![CDATA[<p dir="auto">"Doesn't work" as in blower motor doesnt blow air ? or it blows air, it just isnt warm.</p>
<p dir="auto">Remember that you need to have the heater valve open (heater on hot) while bleeding the cooling system to prevent air  from being trapped in the heater core.</p>
]]></description><link>https://wibimmers.com/post/46549</link><guid isPermaLink="true">https://wibimmers.com/post/46549</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 18 Aug 2014 20:00:16 GMT</pubDate></item><item><title><![CDATA[Reply to E39 Overheating on Mon, 18 Aug 2014 19:51:01 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I forgot that on the list of things tried.</p>
<p dir="auto">Also I didnt mention the heated/ac does not work as well.</p>
]]></description><link>https://wibimmers.com/post/46548</link><guid isPermaLink="true">https://wibimmers.com/post/46548</guid><dc:creator><![CDATA[kaysee78]]></dc:creator><pubDate>Mon, 18 Aug 2014 19:51:01 GMT</pubDate></item><item><title><![CDATA[Reply to E39 Overheating on Mon, 18 Aug 2014 19:38:32 GMT]]></title><description><![CDATA[<p dir="auto">I would have done the thermostat and water pump right away.</p>
]]></description><link>https://wibimmers.com/post/46547</link><guid isPermaLink="true">https://wibimmers.com/post/46547</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Mon, 18 Aug 2014 19:38:32 GMT</pubDate></item></channel></rss>
