<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[rim interchange]]></title><description><![CDATA[<p dir="auto">I know I've seen some information on which types of rims interchange with the E30 somewhere. Just can't seem to find it. Found a set of steel rims with snow tires mounted on them that are from what appears to be an early Mazda Miata. Rims are 4X100. Wondering if these will fit my car?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://wibimmers.com/topic/3022/rim-interchange</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:54 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3022.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Aug 2014 00:23:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to rim interchange on Wed, 20 Aug 2014 13:57:10 GMT]]></title><description><![CDATA[<p dir="auto">As long as the wheels are 4x100 and have a 57.1 or larger center bore they are possible to fit. If the center bore is larger than 57.1 you can get hubcentric rings to take up the slop. The offset will be heavily affected by how wide the wheels are so feel free to run those numbers past us when you find wheels you like.</p>
]]></description><link>https://wibimmers.com/post/46624</link><guid isPermaLink="true">https://wibimmers.com/post/46624</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 20 Aug 2014 13:57:10 GMT</pubDate></item><item><title><![CDATA[Reply to rim interchange on Mon, 18 Aug 2014 12:29:18 GMT]]></title><description><![CDATA[<p dir="auto">I have a set of Altimax Arctics that are 195/65/15 that I used for 2 months if you have 15's</p>
]]></description><link>https://wibimmers.com/post/46522</link><guid isPermaLink="true">https://wibimmers.com/post/46522</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Mon, 18 Aug 2014 12:29:18 GMT</pubDate></item><item><title><![CDATA[Reply to rim interchange on Sat, 16 Aug 2014 11:42:40 GMT]]></title><description><![CDATA[<p dir="auto">Miata centerbore is smaller, 54.1 versus the e30 57.1</p>
]]></description><link>https://wibimmers.com/post/46469</link><guid isPermaLink="true">https://wibimmers.com/post/46469</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 16 Aug 2014 11:42:40 GMT</pubDate></item><item><title><![CDATA[Reply to rim interchange on Sat, 16 Aug 2014 01:31:11 GMT]]></title><description><![CDATA[<p dir="auto">OK, nice to know. Might still be worth buying the tires, though. Could always sell the rims.</p>
]]></description><link>https://wibimmers.com/post/46456</link><guid isPermaLink="true">https://wibimmers.com/post/46456</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Sat, 16 Aug 2014 01:31:11 GMT</pubDate></item><item><title><![CDATA[Reply to rim interchange on Sat, 16 Aug 2014 00:53:16 GMT]]></title><description><![CDATA[<p dir="auto">You'd need spacers and longer wheel bolts.</p>
]]></description><link>https://wibimmers.com/post/46453</link><guid isPermaLink="true">https://wibimmers.com/post/46453</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Sat, 16 Aug 2014 00:53:16 GMT</pubDate></item></channel></rss>
