<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E34 Heater Core Leak?]]></title><description><![CDATA[<p dir="auto">My car has been losing coolant since I've gotten it. At first there was a crack in a tube going from the reservoir to the radiator but I fixed that up. Then I kept getting losing coolant after that but I didn't see anything dripping so I assumed it was a leaking head gasket. Now the dripping is back and it is coming from the back of the engine block, it is dripping on to the down pipe of the exhaust and around that general area. I'm thinking it is the heater core or maybe some tubes going to the heater core. Anyone have any ideas? If I do need to get a new heater core, are they all $150 or does someone know where you can get a better priced one. Thanks!</p>
]]></description><link>https://wibimmers.com/topic/2876/e34-heater-core-leak</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:42:50 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2876.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Jul 2014 22:40:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E34 Heater Core Leak? on Tue, 08 Jul 2014 20:31:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/44452">tsweers89 said:</a></strong></p>
<p dir="auto">Back of the engine on a v8, most likely a valley pan which is under the intake manifold. e34's are known to have bad heater cores but that would be leaking inside the car. Otherwise there are some 2 coolant hoses that go to the heater core in the engine bay. Id inspect the valley pan and go from there. If no leak is visually seen there then pressure test the system and inspect.</p>
<p dir="auto">Are you talking about #5 in the diagram? </p>
<p dir="auto"><img src="http://s22.postimg.org/616910h41/105.png" alt="105.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/44512</link><guid isPermaLink="true">https://wibimmers.com/post/44512</guid><dc:creator><![CDATA[BMWben]]></dc:creator><pubDate>Tue, 08 Jul 2014 20:31:37 GMT</pubDate></item><item><title><![CDATA[Reply to E34 Heater Core Leak? on Tue, 08 Jul 2014 02:34:58 GMT]]></title><description><![CDATA[<p dir="auto">Back of the engine on a v8, most likely a valley pan which is under the intake manifold. e34's are known to have bad heater cores but that would be leaking inside the car. Otherwise there are some 2 coolant hoses that go to the heater core in the engine bay. Id inspect the valley pan and go from there. If no leak is visually seen there then pressure test the system and inspect.</p>
]]></description><link>https://wibimmers.com/post/44452</link><guid isPermaLink="true">https://wibimmers.com/post/44452</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Tue, 08 Jul 2014 02:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to E34 Heater Core Leak? on Tue, 08 Jul 2014 01:47:19 GMT]]></title><description><![CDATA[<p dir="auto">Im having the same issue but mine is leaking by the front somewhere but not enough to get engine hot but is leaking badly once reaches optimal temp and i replaced my upper rad hose.. sorry for thread jacking</p>
<p dir="auto">Sent from my LG-LS970 using Tapatalk</p>
]]></description><link>https://wibimmers.com/post/44449</link><guid isPermaLink="true">https://wibimmers.com/post/44449</guid><dc:creator><![CDATA[I love my E39]]></dc:creator><pubDate>Tue, 08 Jul 2014 01:47:19 GMT</pubDate></item><item><title><![CDATA[Reply to E34 Heater Core Leak? on Tue, 08 Jul 2014 01:13:21 GMT]]></title><description><![CDATA[<p dir="auto">They're all that price. Mine leaks but not enough to lower the coolant level since I bought it and no noticable leaks other than the scent when the heat is on.</p>
]]></description><link>https://wibimmers.com/post/44446</link><guid isPermaLink="true">https://wibimmers.com/post/44446</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Tue, 08 Jul 2014 01:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to E34 Heater Core Leak? on Tue, 08 Jul 2014 01:02:52 GMT]]></title><description><![CDATA[<p dir="auto">Trade me cars. That is all</p>
]]></description><link>https://wibimmers.com/post/44445</link><guid isPermaLink="true">https://wibimmers.com/post/44445</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 08 Jul 2014 01:02:52 GMT</pubDate></item></channel></rss>
