  3. General Technical
  4. M20 intake manifold design thread
55 Posts 13 Posters 979 Views 3 Watching
  • ClassEC
    ClassEC
    ClassE
    I'll be supplying the chips and soda for this debacle - so let's start with the hard questions:
    Doritos or Sun Chips?
    • ClassEC
      ClassEC
      ClassE
      On a more serious note: I'm 100000% in for this.
      -I like the "front" TB inlet to allow for easy integration of IC cooler piping later (wink-wink).
      -My previous SRI was built by a gentleman on the east coast who specialized in such things. Acouple design things to consider: vacuum ports and locations. TB flange variations. Integral fuel rail mounts.
      -I'll have to find the data - but I recall reading a lot of research on having the full bell radius stacks "flush" with the plenum side VS extending "into" the plenum when researching my previous mani. Extending "into" was the winner for all applications.
      -Gotta look good (design/fitment/welds). I ❤ pretty stuff.
      My previous SRI off my MK3 ABA:
      • ClassEC
        ClassEC
        ClassE
        ^^^That manifold had the full bell radius stacks extending into the plenum. Sounded AMAZING at WOT, nice gains in upper RPMs as well.
          On my manifold Id like the TB flange to be such that it can be easily cut off and a larger one re-welded, or simply re-drilled for a larger TB if I ever find that I am in need of one.
            the manifold I will be building with definitely have the stock bolt pattern for the TB. Can always redrill for a different one
            • frcefedF
              frcefedF
              frcefed
              Can I pre-order mine?
                Haha Ill make you one but we need to finish the design! I just need to order runners. I just recently ordered 2" .125 wall 6061 t6 for my supercharger intake manifold, but we might need something different for this? not sure.
                • ClassEC
                  ClassEC
                  ClassE
                  Here's my 5 minute sketch of how my previous SRI was built as a reference.
                  -Flange w-injector bungs (either original mani chopped or new machined)
                  -Velocity stacks
                  -Flat "plate" with round holes cut to slip stacks through - welded to flange
                  -Round plenum with a portion machined off to match height of plate the stacks are slipped through.
                  Maybe something like these would work?!? (Google searched - we'd obviously need to to determine overall runner length and such)
                  http://www.velocitystacksonline.com/product/B154-170
                  My concerns are the meet-up of the stacks and original mani (obvious material thickness difference - both for welding and esthetics) and runner length.
                  • frcefedF
                    frcefedF
                    frcefed
                    Dtmfiberwerkz offers this manifold for $900
                    • JeffJ
                      JeffJ
                      Jeff
                      What is the logic in that manifold why? What does it help? And dimension's on it?
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                      • ClassEC
                        ClassEC
                        ClassE
                        If you do some digging in that - they've never actually made one. There's acouple threads I've found on it - company advertises them and shows that as a reference but hasn't actually made one.
                        • I
                          I
                          industrialsized
                          if you need help in the making of any parts let me know i can probably get it handled for you guys i run a fairly large machine shop so if you want something like a bunch of flanges waterjeted out i can get it done for you
                          also i'm with earl on the m4x manifolds but i guess i can just steal whatever you come up with and cut cyl 1 and 6 of to make an intake for myself
                          • frcefedF
                            frcefedF
                            frcefed
                            So what would happen if I ordered one of these manifolds? Would they just be like "oh, we were kidding" haha.. not that I would order it, especially if the picture represents the actual product, seeing as it wouldn't fit an m20 and if it did, the throttle body would hit the hood.
                            • ClassEC
                              ClassEC
                              ClassE
                              I would assume they'd do what most companies do - send an email saying the product is not available.
                              I wouldn't want to order one without seeing the final product anyways.
                              • ClassEC
                                ClassEC
                                ClassE
                                Drooling:
                                  Volvo?
                                  • ClassEC
                                    ClassEC
                                    ClassE
                                    2.5T that's going into a MK2.
                                      Volvo?
                                      YOU CAN COUNT
                                        Serious note. I have plenty of materials now.
                                        I have 2" 6061 with .125 wall.
                                        I will be Welding 1" of tubing onto each runner, porting the piss out of it to make sure it's a smooth transition. And then from there I can weld to clean aluminum.
                                        My plan is to make a die for a tapered inlet from the plenum, and I will use the 2" tubing.
                                        7 degree taper? And then I will machine little radii for the first part of the velocity stack.
                                        Or I might make a die to form a velocity stack? Not sure.
                                        Also. I built a brake booster delete out of 1x4x4 aluminum and I think it's going to work awesome. It's installed but the car is not running yet. This leaves LOTS of room to play with. We will be doing an itb adapter soon as well.
                                        I changed the pedal ratio to 6.2:1.
                                          For the prototype, you guys should be thinking about the ability to swap pieces easily. Let's say your plenum is the right size but you need to swap out your stacks, you should be able to remove them and replace them with the new pieces. The finished product should be one piece to reduce turbulence. Prototyping is always easier when you can take it all apart.
                                          My .02
                                          I'll powder coat the prototypes for you guys if you'd like.
