<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Chris,  get in here.]]></title><description><![CDATA[<p dir="auto">what's goin on here? Is it normal to play with so many sticks so frequently in a given day? </p>
<p dir="auto">goodness.</p>
]]></description><link>https://wibimmers.com/topic/2663/chris-get-in-here.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:51:19 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2663.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 May 2014 15:42:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Chris,  get in here. on Fri, 09 May 2014 06:03:39 GMT]]></title><description><![CDATA[<p dir="auto">that might help, I pounded many a 18spd the big key is to hit the split right at the last second as to not beat the f out of the shift fork other than that you can slam any gear any time so long as you are able to rev match</p>
]]></description><link>https://wibimmers.com/post/40706</link><guid isPermaLink="true">https://wibimmers.com/post/40706</guid><dc:creator><![CDATA[industrialsized]]></dc:creator><pubDate>Fri, 09 May 2014 06:03:39 GMT</pubDate></item><item><title><![CDATA[Reply to Chris,  get in here. on Fri, 09 May 2014 00:00:44 GMT]]></title><description><![CDATA[<p dir="auto">my favorite video of the multiple stick stuff</p>
]]></description><link>https://wibimmers.com/post/40691</link><guid isPermaLink="true">https://wibimmers.com/post/40691</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 09 May 2014 00:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to Chris,  get in here. on Thu, 08 May 2014 23:06:20 GMT]]></title><description><![CDATA[<p dir="auto">A co-worker at concours showed me this video a long time ago. This is not normal but is common on show trucks. Basically what he has done is replaced 1, 3 function shifter with 3 shifting sticks on his 13 speed. Personally I think its stupid and would suck to drive with.</p>
<p dir="auto">Semi trucks have non-synchronized (straight cut geared) transmissions which require double-clutch shifting unless you have the experience to rev-match each gear. Below is a shift pattern for a Eaton Fuller 13 speed.</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_05_2014_post-2724-0-58856300-1399589394.jpg"><img src="/assets/uploads/files/monthly_05_2014_post-2724-0-58856300-1399589394_thumb.jpg" alt="post-2724-0-58856300-1399589394thumb.jp" class=" img-fluid img-markdown" width="640" height="480" /></a></p>
<p dir="auto">Its a bad pic but ill explain how it all adds up to 13, this is what the shift knob looks like.</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_05_2014_post-2724-0-14204600-1399588931.jpg"><img src="/assets/uploads/files/monthly_05_2014_post-2724-0-14204600-1399588931_thumb.jpg" alt="post-2724-0-14204600-1399588931thumb.jp" class=" img-fluid img-markdown" width="300" height="225" /></a></p>
<p dir="auto">Instead of having 13 different gear slots the truck has essentially 2 shift patterns stacked on top of each other. The low range consists of reverse, low gear, 1, 2, 3 and 4th gears. The second range consists of 5, 6, 7 and 8. To flip between the low/high ranges all you do is toggle that black lever on the front of the shift knob while the transmission is in neutral. Not counting reverse we are at 9 gears right now.</p>
<p dir="auto">A 13 speed transmission is a special 9 speed because each gear in the high range has its own over drive gear. We'll call them 5.5, 6.5, 7.5 and 8.5th gears for my explanation. To shift into these gears all you need to do is pull the transmission into neutral and then push the red splitter knob forward and then reselect the gear you just came out of. This is called splitting gears and you can shift from any split gear to another one or go back/forth in sequence.</p>
<p dir="auto">See how complicated this sounds? Like driving a manual car it all becomes second nature. Assuming the stick on the left is the splitter, middle stick is the shift lever, and right stick is hi/lo this driver has to shuffle between all these sticks to get his transmission in/out of gear. My conclusion is that he has deleted his air operated shifter functions in favor of looking like a badass while not being able to focus on the road.</p>
]]></description><link>https://wibimmers.com/post/40684</link><guid isPermaLink="true">https://wibimmers.com/post/40684</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Thu, 08 May 2014 23:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to Chris,  get in here. on Thu, 08 May 2014 12:19:33 GMT]]></title><description><![CDATA[<p dir="auto">What the crap!?!</p>
]]></description><link>https://wibimmers.com/post/40590</link><guid isPermaLink="true">https://wibimmers.com/post/40590</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Thu, 08 May 2014 12:19:33 GMT</pubDate></item></channel></rss>
