<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Motion to find a time machine...]]></title><description><![CDATA[<p dir="auto">....go back to 1983</p>
<p dir="auto">and sack the man that insisted that the M20 intake manifold to resemble a crustacean. </p>
<p dir="auto"><img src="http://thumbs4.ebaystatic.com/d/l225/m/mOizREWR1HR_ERDt6uKKcwg.jpg" alt="mOizREWR1HRERDt6uKKcwg.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/topic/2643/motion-to-find-a-time-machine...</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:57:38 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2643.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 May 2014 14:05:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 17:44:37 GMT]]></title><description><![CDATA[<p dir="auto">Yea I know that. I just want to build them so I don't have to wait.</p>
]]></description><link>https://wibimmers.com/post/40646</link><guid isPermaLink="true">https://wibimmers.com/post/40646</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 08 May 2014 17:44:37 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 17:40:22 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/40641">Rowleym said:</a></strong></p>
<p dir="auto">Seriously does anyone know the size of motor mounts I need for an e30 24v swap? Its the only thing I need to swap it! </p>
<p dir="auto">E28 m5 mounts or Condor Speed Shops swap mounts</p>
]]></description><link>https://wibimmers.com/post/40642</link><guid isPermaLink="true">https://wibimmers.com/post/40642</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 08 May 2014 17:40:22 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 17:31:21 GMT]]></title><description><![CDATA[<p dir="auto">Seriously does anyone know the size of motor mounts I need for an e30 24v swap? Its the only thing I need to swap it!</p>
]]></description><link>https://wibimmers.com/post/40641</link><guid isPermaLink="true">https://wibimmers.com/post/40641</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 08 May 2014 17:31:21 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 17:30:19 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/40623">Snap said:</a></strong></p>
<p dir="auto">unless you end up finding/using an MLS gasket for the intake manifold (pro would be re-usability) </p>
<p dir="auto">I'd agree that it should be suitible as finished. </p>
<p dir="auto">Do you have a profilometer at work? </p>
<p dir="auto">If that means a surface finish tester, than yes <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /> </p>
<p dir="auto">I mean, with my face mill I can practically get a mirror finish. Its not a problem.</p>
]]></description><link>https://wibimmers.com/post/40640</link><guid isPermaLink="true">https://wibimmers.com/post/40640</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 08 May 2014 17:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 15:24:12 GMT]]></title><description><![CDATA[<p dir="auto">unless you end up finding/using an MLS gasket for the intake manifold (pro would be re-usability) </p>
<p dir="auto">Do you have a profilometer at work?</p>
]]></description><link>https://wibimmers.com/post/40623</link><guid isPermaLink="true">https://wibimmers.com/post/40623</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 08 May 2014 15:24:12 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 15:22:15 GMT]]></title><description><![CDATA[<p dir="auto">Yea you should be able to take a little off with a face mill until it cleans up, this is a typical thing to do on engines like my land cruiser has with intake/exhaust on the same side and using the same mounting bolts.  There are half holes in each piece so they share hardware and if the thicknesses don't match perfect you can't get a good seal.</p>
]]></description><link>https://wibimmers.com/post/40622</link><guid isPermaLink="true">https://wibimmers.com/post/40622</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 08 May 2014 15:22:15 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 15:15:55 GMT]]></title><description><![CDATA[<p dir="auto">Snap I have 3 extras, I have begin working on one! I cut it, and then milled it flat, but I need to figure out how long of runners I want, And I also have to cut cylinder 6 runner shorter, because it has a bend starting nearly at the flange. </p>
<p dir="auto">Also I gotta figure out velo stacks, and if I want to make them or not. </p>
<p dir="auto">One thing I noticed. HOLY CRAP the stock flange was not very flat. </p>
<p dir="auto">I can mill a flange correct? I shouldn't need to grind it right? I normally get amazing finish with my face mill, but I don't know what kind of sealing it needs.</p>
]]></description><link>https://wibimmers.com/post/40621</link><guid isPermaLink="true">https://wibimmers.com/post/40621</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 08 May 2014 15:15:55 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 15:09:59 GMT]]></title><description><![CDATA[<p dir="auto">You can't just get rid of the crab manifold. How are you going to go about completing your "Under the Sea" themed engine bay??</p>
]]></description><link>https://wibimmers.com/post/40619</link><guid isPermaLink="true">https://wibimmers.com/post/40619</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 08 May 2014 15:09:59 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 15:01:04 GMT]]></title><description><![CDATA[<p dir="auto">I have a spare manifold. I'd like to work on something as well, throw it on, virtual dyno it (megasquirt thing)  and see what happens.  Consider 2014 the year the crab received cosmetic surgery.</p>
]]></description><link>https://wibimmers.com/post/40614</link><guid isPermaLink="true">https://wibimmers.com/post/40614</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 08 May 2014 15:01:04 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 14:57:42 GMT]]></title><description><![CDATA[<p dir="auto">I have every intention of coming up with a custom manifold design and having one build this fall - with the intention of adding boost shortly there after.</p>
<p dir="auto">I think a NA M20 with some simple bolt-ons (cam, exhaust, software/fueling) and a SRI w/velocity stacks would pull just fine.</p>
]]></description><link>https://wibimmers.com/post/40613</link><guid isPermaLink="true">https://wibimmers.com/post/40613</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Thu, 08 May 2014 14:57:42 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 14:33:34 GMT]]></title><description><![CDATA[<p dir="auto">ClassE's build thread brought forth a few negative opinions of the m20 manifold out of the woodwork. </p>
<p dir="auto">I am neutral about it.</p>
<p dir="auto">Form follows function and it was designed for a particular function. </p>
<p dir="auto">A log manifold would sound cooler though.</p>
]]></description><link>https://wibimmers.com/post/40602</link><guid isPermaLink="true">https://wibimmers.com/post/40602</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 08 May 2014 14:33:34 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Thu, 08 May 2014 14:23:42 GMT]]></title><description><![CDATA[<p dir="auto">I personally like the m20 manifold just taking them off and putting them on is a bit of a chore but not nearly as bad as working on a Jeep 4.0... Both the intake and exhaust are on the same side of the damn head!!! I will go back in time with you to sack the man that thought that that was a good idea!</p>
]]></description><link>https://wibimmers.com/post/40601</link><guid isPermaLink="true">https://wibimmers.com/post/40601</guid><dc:creator><![CDATA[RamRod E28]]></dc:creator><pubDate>Thu, 08 May 2014 14:23:42 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Fri, 02 May 2014 19:01:44 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://1.bp.blogspot.com/-HVR5Wq2SKTc/UQxf-1qsSaI/AAAAAAAAcC0/C5vuTYfVqV8/s1600/THOUSAND+YARD+STARE.jpg" alt="THOUSAND+YARD+STARE.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">oh the horror</p>
]]></description><link>https://wibimmers.com/post/40144</link><guid isPermaLink="true">https://wibimmers.com/post/40144</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 02 May 2014 19:01:44 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Fri, 02 May 2014 18:47:00 GMT]]></title><description><![CDATA[<p dir="auto">They deserve sledge hammers</p>
]]></description><link>https://wibimmers.com/post/40140</link><guid isPermaLink="true">https://wibimmers.com/post/40140</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 02 May 2014 18:47:00 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Fri, 02 May 2014 18:35:45 GMT]]></title><description><![CDATA[<p dir="auto">Why you no like crab manifold?!</p>
]]></description><link>https://wibimmers.com/post/40134</link><guid isPermaLink="true">https://wibimmers.com/post/40134</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Fri, 02 May 2014 18:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to Motion to find a time machine... on Fri, 02 May 2014 16:16:23 GMT]]></title><description><![CDATA[<p dir="auto">I am in favor but I have different motives... Sack the man who decided to NOT bring over the euro e36 M3!</p>
]]></description><link>https://wibimmers.com/post/40112</link><guid isPermaLink="true">https://wibimmers.com/post/40112</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Fri, 02 May 2014 16:16:23 GMT</pubDate></item></channel></rss>
