  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
536 Posts 34 Posters 9.9k Views 1 Watching
    Finally got the M3 into storage for the year.
      Somebody forgot to fold in their mirrors
        Oil changed @ 147,928
          New rear tires, lower control arms, upper and lower rear ball joints. 9a0a39f80ab636e9440cc2154c486d3e.jpg6fe96f9695c022be9a7afca625bc5955.jpg8ca310205d1d249f755f5a0860dcb2b8.jpg
            Looks good, I have the same lower arms, they are so easy to adjust.
              Daggerty
              Nice, when did that rear arm break?
              • IceddragonI
                IceddragonI
                Iceddragon
                I hear this is an SMG E46, how's that treating you? I want to be in the market later this year and am undecided on manual vs SMG.
                  For how I use the car I love the SMG. I usually put on about 2500-3000 a month being a Realtor and driving all over SE WI.
                  I lost compression and put in a "new" motor 2 winters ago. After the swap my SMG pump went bad. Then my gear selector rod bent on the install. So needed a new one of those. All is well now.
                  With all the people swapping the 6 speed there are "cheaper" SMG parts available.
                    I'm a little excited for 10 years from now when I might have one of the few, cleaner SMGs around
                      Most people never have to replace an S54 or diagnose an SMG system in their lives. But very few people get to daily drive an E46 M3
                        It is a true joy.
                        Need a new drivers side caliper. Haven't checked the passenger side but might do that one as well. Apparently there is a required computer bleeding program for any e46. I really don't want a newer model BMW after the e46 as this one is tip toeing on the deep end of all computer everything.
                          150,900 miles: New driver side front caliper, new OEM front rotors, new PFC pads. Computer bled the ABS system and completely flushed system with new OEM BMW fluid.
                          Right rear line had some air in it and the driver's side front did as well.
                            SMG electric motor fried out. Replaced with a new Burkhart unit. All is well!7ec3e8650cb2ad6ce5fb0b2945b824a5.jpg2e32e55ddcffb8e05da59019a686f9d4.jpg7b6c1b6502ffb85733f6395aa3bf21f2.jpge8eb905d330e0e1eb1bc7b5e2df45563.jpg
                                I love the cold tach display with the reduced rev limit on those.
                                You are also now the resident SMG master tech
                                  I'll take that title.
                                  E30, LS1, SMG'd T-56???
                                  • IceddragonI
                                    IceddragonI
                                    Iceddragon
                                    That tachometer is so clever if I'm understanding it right. The yellow bars go away once the engine is warm? Or are they indicators?
                                      Yessir, the maximum rpm is limited with respect to engine temperature. Im not sure if its coolant or oil temp dependent but its neat that its displayed on the tach
                                        Haven't updated this one in awhile.
                                        Recently:
                                        - Replaced constant pressure oil valve.
                                        - Installed RTABs with poly bushings
                                        - Got 2 big leaks in my exhaust properly welded and fixed.
                                        - Installed new Bavarian Sound Werks speakers.
                                        - Sound deaded the front door panels.c5a2e8388c0094e47bd415518bcd1f21.jpg28c5e046a87425988e28f7e74ba0cc17.jpg
                                          How do you like the Bav Sound speakers? Always been interested in them, just don’t make anything for pre-2k models.
