  4. The E46 M3 Journal
The E46 M3 Journal
536 Posts 34 Posters 0 Views 1 Watching
    Two more trans bolts (the top two ones that go into the block) then the trans is out.
    Then pop this in!
      Doorman
      Every man lives shiny parts!
      Best of luck to you bud!
          On the install train!
            One bolt is in. I'll button the rest up soon if the rain holds off.
              Is the rod joint pin closest to the trans tapered?  I have the pin 1/4 of the way in and it won't budge.  It rotates the gear selector shaft on the trans when I turn the SMG side.
              What gives?!  I've used an extension and a hammer and nothing moves.
                So close!
                  Any progress with that joint pin?
                    Replaced the pressure plate now I'm getting an error code "83"
                    Gear Position Sensor?
                      DrLeadFoot said:
                      So close!
                      To what, parting it out? Hahaha
                      Hope you get this figured out soon.
                        It did move a foot under its own power. No engine light!!
                          Time for burnouts!!
                            Time for burnouts!!
                            That's all it wants to do! It slams into gear uber hard.
                              Drove it around the block!! Doesn't shift into second.
                              I bled the actuator 3 or 4 times and it allowed me to ease on the gas and slowly grab 1st gear like it normally did. Maybe I'll just keep on bleeding the actuator and see what happens. At least I can drive it to a show now if needed.
                                I would rage
                                  I would rage drift it into a curb
                                  FTFY
                                    this is what happens when those BMW engineers get all redneck with stuff. they are usually pretty good about not doing that.
                                    "hey! lets make an 'SMG' transmission. we will just attach a thinga-ma-bob that moves the lever around to the regular manual box and make is super complicated so it looks like new tech, instead of designing a new transmission."
                                      Drive it to a shop... Not a show! Lol.
                                      I rage drifted my E30 M3 into a curb. Trying to keep this one between the lines.
                                      Tied up with work lately but mid next week I'll run the program as many times as I can while I excavate items from my garage and try to find an E30 that I know is in there somewhere.
                                        Ran the program and couple of more times while I was cleaning out the garage.
                                        It still "cannot find the center of the shift path."
                                        I'm leaning towards taking it to the dealer and just get it fixed. Maybe their software is better than the Windows XP laptop I have.
                                        • CMartC
                                          CMartC
                                          CMart
                                          You did good, congrats on all of your progress.
                                          Excursion 7.3
                                          E30 LS1
