<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alignment issues...]]></title><description><![CDATA[<p dir="auto">So my late model e30 pulls to the right pretty bad after replacing control arms with treehouse racing CAB's, tie rods, and new front calipers due to a seized slide pin in the caliper bracket. The car has been aligned and rechecked twice but still has the pull. So the only thing I can really think of is a bad tire. Does anyone have a set of wheels and good tires I could throw on and take for a little ride to rule out a bad tire?</p>
]]></description><link>https://wibimmers.com/topic/2557/alignment-issues...</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:57:04 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2557.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Apr 2014 00:40:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alignment issues... on Sat, 12 Apr 2014 00:27:34 GMT]]></title><description><![CDATA[<p dir="auto">ok so i replaced the front right caliper due to being stuck and it fixed the dragging brake but it still pulls. does anybody know a good alignment guy in milwaukee that would take walk-ins on a (tomorrow) saturday? It takes away all the enjoyment of driving my car and I want it fixed ASAP!!!</p>
]]></description><link>https://wibimmers.com/post/38842</link><guid isPermaLink="true">https://wibimmers.com/post/38842</guid><dc:creator><![CDATA[andyhundley]]></dc:creator><pubDate>Sat, 12 Apr 2014 00:27:34 GMT</pubDate></item><item><title><![CDATA[Reply to Alignment issues... on Fri, 11 Apr 2014 18:05:36 GMT]]></title><description><![CDATA[<p dir="auto">If I could see some alignment numbers I could definitely point the right direction.  I work with Hunter Engineering to do alignment and ride control training for our tech's so if I can't figure it out I can get my guy at Hunter Engineering to look at the numbers and see if he notices anything.</p>
]]></description><link>https://wibimmers.com/post/38810</link><guid isPermaLink="true">https://wibimmers.com/post/38810</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Fri, 11 Apr 2014 18:05:36 GMT</pubDate></item><item><title><![CDATA[Reply to Alignment issues... on Fri, 11 Apr 2014 17:26:55 GMT]]></title><description><![CDATA[<p dir="auto">He had this all done at Wilde Toyota and had a tech look at it. Andy needs to chime in with more details.</p>
]]></description><link>https://wibimmers.com/post/38804</link><guid isPermaLink="true">https://wibimmers.com/post/38804</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Fri, 11 Apr 2014 17:26:55 GMT</pubDate></item><item><title><![CDATA[Reply to Alignment issues... on Fri, 11 Apr 2014 15:11:07 GMT]]></title><description><![CDATA[<p dir="auto">Try driving backwards and see if it turns the other way.... <img src="/assets/uploads/files/emoticons_default_laugh.png" alt=":lol:" class=" img-fluid img-markdown" width="20" height="20" />  In all seriousness it sounds like any of the follow can be your problem:</p>
<p dir="auto">-dragging brake</p>
<p dir="auto">-bad tires</p>
<p dir="auto">-bent control arm(even if it is new)</p>
<p dir="auto">-you have a strong right hand (lay off masturbation) <img src="/assets/uploads/files/emoticons_default_shifty.gif" alt=":shifty:" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">-is the ride height even on both sides?</p>
<p dir="auto">-the alignment rack might be out of calibration</p>
<p dir="auto">Good luck!</p>
]]></description><link>https://wibimmers.com/post/38797</link><guid isPermaLink="true">https://wibimmers.com/post/38797</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Fri, 11 Apr 2014 15:11:07 GMT</pubDate></item><item><title><![CDATA[Reply to Alignment issues... on Wed, 09 Apr 2014 12:29:04 GMT]]></title><description><![CDATA[<p dir="auto">Yea a printout of the numbers may help, where did you have it aligned?  Some places do not do a good job at all.  Check for a dragging brake even though you just replaced stuff, just lift it up and make sure they spin nice.</p>
]]></description><link>https://wibimmers.com/post/38634</link><guid isPermaLink="true">https://wibimmers.com/post/38634</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 09 Apr 2014 12:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to Alignment issues... on Wed, 09 Apr 2014 06:20:49 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/38623">Boris3 said:</a></strong></p>
<p dir="auto">Tried just swapping the fronts left to right? Or the fronts to the rear?</p>
<p dir="auto">Do this first and see if it pulls the other way or lessens.  If not then recheck the calipers and make sure the hoses are not twisted at all.  Do you happen to have a print out of the alignment numbers?</p>
]]></description><link>https://wibimmers.com/post/38630</link><guid isPermaLink="true">https://wibimmers.com/post/38630</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Wed, 09 Apr 2014 06:20:49 GMT</pubDate></item><item><title><![CDATA[Reply to Alignment issues... on Wed, 09 Apr 2014 04:16:44 GMT]]></title><description><![CDATA[<p dir="auto">Andy I still have a couple sets of 14" bottle caps you could borrow tires off of.</p>
]]></description><link>https://wibimmers.com/post/38627</link><guid isPermaLink="true">https://wibimmers.com/post/38627</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 09 Apr 2014 04:16:44 GMT</pubDate></item><item><title><![CDATA[Reply to Alignment issues... on Wed, 09 Apr 2014 02:37:15 GMT]]></title><description><![CDATA[<p dir="auto">Tried just swapping the fronts left to right? Or the fronts to the rear?</p>
]]></description><link>https://wibimmers.com/post/38623</link><guid isPermaLink="true">https://wibimmers.com/post/38623</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Wed, 09 Apr 2014 02:37:15 GMT</pubDate></item></channel></rss>
