<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2006 325i Shift Hesitation]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Now that I have found this forum you will probably be seeing quite a few questions from me.</p>
<p dir="auto">My latest question/issue is the hesitation I feel when taking off from a stop. When I apply the gas it seems the car is slow to accelerate. I have read a few things on other boards that this is normal to having to upgrade the ecu code. Another thing I read was to put the car is start mode and hold the gas pedal for 25 seconds to reset the shift points. Someone also stated running in DS will resolve the issue.</p>
<p dir="auto">Has anyone else experienced this and if so what was the resolution. I have read so much note sure what is fact and what is fiction. As always thanks in advance.</p>
]]></description><link>https://wibimmers.com/topic/253/2006-325i-shift-hesitation</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:49:11 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/253.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Sep 2011 02:58:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2006 325i Shift Hesitation on Mon, 19 Sep 2011 20:01:46 GMT]]></title><description><![CDATA[<p dir="auto">I am in the Madison area yes, but would be willing to drive if it means some savings. Feel free to PM me if you want to discuss. Thanks for checking though I appreciate your time on this.</p>
]]></description><link>https://wibimmers.com/post/2654</link><guid isPermaLink="true">https://wibimmers.com/post/2654</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Mon, 19 Sep 2011 20:01:46 GMT</pubDate></item><item><title><![CDATA[Reply to 2006 325i Shift Hesitation on Mon, 19 Sep 2011 17:05:24 GMT]]></title><description><![CDATA[<p dir="auto">Just checked your vehicle history. Vehicle was programmed one time in 07' for an OBD service action, which most vehicles get. The SIB i was refering to that is about your shifting problem was issued on 10/08 so your vehicle has not yet been programmed with that updated software.</p>
<p dir="auto">As far as pricing goes dealer will charge you 1 hour diagnosis to tell you it needs to be programmed then another 2-2.5 hrs to program at $125/hr or more labor rate. If you were in the milwaukee area i could help you out for much less. But i assume you are in the madison area as you bought it there.</p>
]]></description><link>https://wibimmers.com/post/2652</link><guid isPermaLink="true">https://wibimmers.com/post/2652</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Mon, 19 Sep 2011 17:05:24 GMT</pubDate></item><item><title><![CDATA[Reply to 2006 325i Shift Hesitation on Mon, 19 Sep 2011 15:47:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>tsweers89 said:</strong></p>
<p dir="auto">Also i did not see your vin in the last thread. PLease post and i can look up your vehicles repair history to see if it has been programmed for this issue before.</p>
<p dir="auto">Ok the last 7 of my VIN are KX48130</p>
]]></description><link>https://wibimmers.com/post/2651</link><guid isPermaLink="true">https://wibimmers.com/post/2651</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Mon, 19 Sep 2011 15:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to 2006 325i Shift Hesitation on Mon, 19 Sep 2011 12:38:57 GMT]]></title><description><![CDATA[<p dir="auto">Also i did not see your vin in the last thread. PLease post and i can look up your vehicles repair history to see if it has been programmed for this issue before.</p>
]]></description><link>https://wibimmers.com/post/2644</link><guid isPermaLink="true">https://wibimmers.com/post/2644</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Mon, 19 Sep 2011 12:38:57 GMT</pubDate></item><item><title><![CDATA[Reply to 2006 325i Shift Hesitation on Mon, 19 Sep 2011 12:37:09 GMT]]></title><description><![CDATA[<p dir="auto">Were are you located? I have the ability to proram vehicles and also do the lifters if that was something you wanted to do. Programming the vehicle would take anywere from 2-6hrs pending your vehicles present i-level.</p>
]]></description><link>https://wibimmers.com/post/2643</link><guid isPermaLink="true">https://wibimmers.com/post/2643</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Mon, 19 Sep 2011 12:37:09 GMT</pubDate></item><item><title><![CDATA[Reply to 2006 325i Shift Hesitation on Mon, 19 Sep 2011 03:30:46 GMT]]></title><description><![CDATA[<p dir="auto">tsweers89,</p>
<p dir="auto">Thanks for the quick response. I posted the last 7 of my VIN in the other thread about engine tick. Also do you know the ball park cost to reprogram since I am off warranty (I think you were going to check for me)?</p>
]]></description><link>https://wibimmers.com/post/2639</link><guid isPermaLink="true">https://wibimmers.com/post/2639</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Mon, 19 Sep 2011 03:30:46 GMT</pubDate></item><item><title><![CDATA[Reply to 2006 325i Shift Hesitation on Mon, 19 Sep 2011 03:04:22 GMT]]></title><description><![CDATA[<p dir="auto">First off i would check to make sure there is no leaks at the transmission. The pan gasket and mechatronic sleeve are known to leak. If all is good there you have two options. First would be to reset the transmission adaptions. Which to my knowledge cant be done without hooking it up to a gt1 or isid (bmw scan tool). Next step would be to program the vehicle, as there is a SIB (Service Bulletin) that is exactly about your issue and the fix is to program the egs control module. But i would need to check your vehicles integration level to make sure it isn't already up to date. Which need to be done through a bmw scan tool.</p>
]]></description><link>https://wibimmers.com/post/2637</link><guid isPermaLink="true">https://wibimmers.com/post/2637</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Mon, 19 Sep 2011 03:04:22 GMT</pubDate></item></channel></rss>
