<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 Fuel System Upgrade Ideas]]></title><description><![CDATA[<p dir="auto">I have started to think about really upgrading my fuel system.  I began this to get your input and have a running log of what is going through everyones brains.</p>
<p dir="auto">Has anyone seen a setup like this for an e30?  I can only find e36 setups.  Custom and this one:</p>
<p dir="auto"><a href="http://www.rallyroad.net/content/rally-road-e36-bmw-dual-fuel-pump-hanger" rel="nofollow ugc">http://www.rallyroad.net/content/rally-road-e36-bmw-dual-fuel-pump-hanger</a></p>
<p dir="auto">Ideally I would run dual 255 walbros in the tank.  Have 6AN fittings coming out and off of each pump.  Those two lines hook up to a T fitting with a 10AN fitting for the output line and run that to my fuel rail.  Which would be this one:  <a href="http://www.rallyroad.net/content/high-flow-billet-fuel-rail" rel="nofollow ugc">http://www.rallyroad.net/content/high-flow-billet-fuel-rail</a></p>
<p dir="auto">Questions:</p>
<p dir="auto">-Do you think running two filters on the 6AN lines would be better or one on the 10AN line?</p>
<p dir="auto">-Return line diameter either 10AN or 8AN to the FPR?</p>
]]></description><link>https://wibimmers.com/topic/2312/e30-fuel-system-upgrade-ideas</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:06:18 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2312.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jan 2014 14:15:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Thu, 24 Apr 2014 11:49:10 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://img1.etsystatic.com/000/0/5606155/il_570xN.240095507.jpg" alt="il570xN.240095507.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">...For squirts,  or some sort of OBD-2 tuning system. </p>
<p dir="auto">You have quite a bit of untapped potential</p>
]]></description><link>https://wibimmers.com/post/39487</link><guid isPermaLink="true">https://wibimmers.com/post/39487</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 24 Apr 2014 11:49:10 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Thu, 24 Apr 2014 04:35:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/39477">DrLeadFoot said:</a></strong></p>
<p dir="auto">Pat Kummrow said it's getting fuel and spark. It might be an ecu issue. #sketch</p>
<p dir="auto">Sent from my SCH-I535 using Tapatalk</p>
<p dir="auto">#megasquirt</p>
<p dir="auto">Mr. Leadballs</p>
]]></description><link>https://wibimmers.com/post/39479</link><guid isPermaLink="true">https://wibimmers.com/post/39479</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Thu, 24 Apr 2014 04:35:11 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Thu, 24 Apr 2014 03:51:06 GMT]]></title><description><![CDATA[<p dir="auto">Pat Kummrow said it's getting fuel and spark. It might be an ecu issue. #sketch</p>
]]></description><link>https://wibimmers.com/post/39477</link><guid isPermaLink="true">https://wibimmers.com/post/39477</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Thu, 24 Apr 2014 03:51:06 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Thu, 24 Apr 2014 03:03:19 GMT]]></title><description><![CDATA[<p dir="auto">Yea If going in tank route definitely just do the simple way and just get a damn good in tank pump. One and done. How much power do you even plan on making and what fuel?</p>
]]></description><link>https://wibimmers.com/post/39472</link><guid isPermaLink="true">https://wibimmers.com/post/39472</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 24 Apr 2014 03:03:19 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Wed, 23 Apr 2014 19:57:25 GMT]]></title><description><![CDATA[<p dir="auto">im not a fan of dual pumps running in parallel like you would with the hobbs switch, </p>
<p dir="auto">Id rather not run dual pumps in series, but thats an easy way to go about it</p>
<p dir="auto">If it were me, I would have 1 very high flow pump and just let your fuel pressure regulator deal with it.</p>
]]></description><link>https://wibimmers.com/post/39454</link><guid isPermaLink="true">https://wibimmers.com/post/39454</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 23 Apr 2014 19:57:25 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Wed, 23 Apr 2014 19:30:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/39364">Rowleym said:</a></strong></p>
<p dir="auto">For the return from the surge tank. Hey will you be at spring green? I would love to shoot some ideas about surge tank placement/size. I would love to have some of my work on your car sir <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">I will not be able to make it. </p>
<p dir="auto">Back to the pumps:</p>
<p dir="auto">Here is the pump I'm going to get.  I might run 2 of these.</p>
<p dir="auto"><a href="http://store.034moto...surge-tank.html" rel="nofollow ugc">http://store.034moto...surge-tank.html</a> which would run in tandem but as an external pump.  These would both be running all the time.</p>
<p dir="auto">This would be easier and should work just fine.</p>
]]></description><link>https://wibimmers.com/post/39453</link><guid isPermaLink="true">https://wibimmers.com/post/39453</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Wed, 23 Apr 2014 19:30:51 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Tue, 22 Apr 2014 13:49:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/39358">DrLeadFoot said:</a></strong></p>
<p dir="auto">Why would I need to do this?</p>
<p dir="auto">I have to do this fuel thing sooner than later.  The fuel pump took a dump I think.</p>
]]></description><link>https://wibimmers.com/post/39364</link><guid isPermaLink="true">https://wibimmers.com/post/39364</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Tue, 22 Apr 2014 13:49:30 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Tue, 22 Apr 2014 13:01:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/34632">Rowleym said:</a></strong></p>
<p dir="auto">Also, You would need to convert the stock feed line to 6an somewhere, whether it be at the stock tank or just before the surge doesn't matter. </p>
]]></description><link>https://wibimmers.com/post/39358</link><guid isPermaLink="true">https://wibimmers.com/post/39358</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Tue, 22 Apr 2014 13:01:03 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Mon, 20 Jan 2014 18:20:32 GMT]]></title><description><![CDATA[<p dir="auto">Also, You would need to convert the stock feed line to 6an somewhere, whether it be at the stock tank or just before the surge doesn't matter.</p>
]]></description><link>https://wibimmers.com/post/34632</link><guid isPermaLink="true">https://wibimmers.com/post/34632</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Mon, 20 Jan 2014 18:20:32 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Mon, 20 Jan 2014 18:19:48 GMT]]></title><description><![CDATA[<p dir="auto">Well from after the surge tank, I would go to a 8an to the fuel rail, and then on the return side of the fuel rail, have a 6an line coming to your FPR, and then from the FPR, 6an line back to the surge tank. The surge tank probably also has a return to the stock tank.</p>
]]></description><link>https://wibimmers.com/post/34631</link><guid isPermaLink="true">https://wibimmers.com/post/34631</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Mon, 20 Jan 2014 18:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Mon, 20 Jan 2014 16:08:53 GMT]]></title><description><![CDATA[<p dir="auto">Run the stock set up to that thing then -6 lines everywhere else?</p>
]]></description><link>https://wibimmers.com/post/34620</link><guid isPermaLink="true">https://wibimmers.com/post/34620</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Mon, 20 Jan 2014 16:08:53 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Mon, 20 Jan 2014 16:00:35 GMT]]></title><description><![CDATA[<p dir="auto">Thats EXACTLY what I think you should do. I really like the product you found there! That will make for a super clean, High power setup.</p>
]]></description><link>https://wibimmers.com/post/34619</link><guid isPermaLink="true">https://wibimmers.com/post/34619</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Mon, 20 Jan 2014 16:00:35 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Mon, 20 Jan 2014 14:45:10 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the info.  I currently have a 255 walbro in the tank.  Have that feed the surge tank?</p>
<p dir="auto">Or just incorporate this:  <a href="http://store.034motorsport.com/fully-enclosed-fp34-044-fuel-surge-tank.html" rel="nofollow ugc">http://store.034motorsport.com/fully-enclosed-fp34-044-fuel-surge-tank.html</a></p>
]]></description><link>https://wibimmers.com/post/34612</link><guid isPermaLink="true">https://wibimmers.com/post/34612</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Mon, 20 Jan 2014 14:45:10 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Fuel System Upgrade Ideas on Fri, 17 Jan 2014 18:04:03 GMT]]></title><description><![CDATA[<p dir="auto">Honestly, if i were you, I would run the stock pump to a surge tank(probably -6) And then have a bosch 044 feed the rail. I really think swirl pots help a whole lot, and it makes things easy as well. I would run a -6 return line to your FPR because thats what most of them are, and man, its your return line, you don't need it much bigger.</p>
]]></description><link>https://wibimmers.com/post/34513</link><guid isPermaLink="true">https://wibimmers.com/post/34513</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Fri, 17 Jan 2014 18:04:03 GMT</pubDate></item></channel></rss>
