<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 Door Lock Cylinder Rekey Link]]></title><description><![CDATA[<p dir="auto">I have to mess around with my locks a little and I found this helpful link.</p>
<p dir="auto"><a href="http://www.unofficialbmw.com/e30/interior/door_locks/e30_door_lock_cylinder_rekey.html" rel="nofollow ugc">http://www.unofficialbmw.com/e30/interior/door_locks/e30_door_lock_cylinder_rekey.html</a></p>
<p dir="auto">I'll add more links as I find them.</p>
]]></description><link>https://wibimmers.com/topic/2274/e30-door-lock-cylinder-rekey-link</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:01:30 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2274.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Jan 2014 14:05:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Wed, 22 Jan 2014 20:54:34 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://img.tapatalk.com/d/14/01/23/a9yqu9uj.jpg" alt="a9yqu9uj.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Trunk lock is installed. Locks and unlocks with ease.</p>
<p dir="auto">I have a new trunk actuator coming. My old one was seized up and locked in one position.</p>
<p dir="auto">I also have a drivers door rebuilding kit. That will be next then on to the passenger door.</p>
<p dir="auto">Sent from my SCH-I535 using Tapatalk</p>
]]></description><link>https://wibimmers.com/post/34735</link><guid isPermaLink="true">https://wibimmers.com/post/34735</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Wed, 22 Jan 2014 20:54:34 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Tue, 21 Jan 2014 04:42:14 GMT]]></title><description><![CDATA[<p dir="auto">Nice plug for <a href="http://bestofbrewcity.com" rel="nofollow ugc">bestofbrewcity.com</a></p>
]]></description><link>https://wibimmers.com/post/34660</link><guid isPermaLink="true">https://wibimmers.com/post/34660</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Tue, 21 Jan 2014 04:42:14 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Tue, 21 Jan 2014 00:01:54 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://img.tapatalk.com/d/14/01/21/hahyvuby.jpg" alt="hahyvuby.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Painted and reassembled ready for install.</p>
<p dir="auto">I tried to move my electronic lock for the trunk and it is locked solid. I guess I'll have to get a new one.</p>
]]></description><link>https://wibimmers.com/post/34641</link><guid isPermaLink="true">https://wibimmers.com/post/34641</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Tue, 21 Jan 2014 00:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Wed, 15 Jan 2014 21:32:50 GMT]]></title><description><![CDATA[<p dir="auto">I got the cylinder and the waffles all installed in the housing along with the spring and ball bearing.</p>
<p dir="auto">I thought I flung the bearing across my living room on the first install attempt. Went to 3 different hardware stores in between my appointments with no luck. I come home, sit at my table and see the damn bearing smack dab in the middle of my work station!!</p>
<p dir="auto"><img src="http://img.tapatalk.com/d/14/01/16/a5y4aqeb.jpg" alt="a5y4aqeb.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">^this is a smooth operator now.</p>
<p dir="auto">I'm going to wire wheel or sandblast the black housing tonight and paint it up. After that dries I need to put this together.</p>
<p dir="auto"><img src="http://img.tapatalk.com/d/14/01/16/6uze5uta.jpg" alt="6uze5uta.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/34405</link><guid isPermaLink="true">https://wibimmers.com/post/34405</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Wed, 15 Jan 2014 21:32:50 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Wed, 15 Jan 2014 03:39:37 GMT]]></title><description><![CDATA[<p dir="auto">I got the whole thing apart plus the waffles out. I PB blasted the cylinder and took pipe cleaner and ran it through then brake cleaned the whole thing.</p>
<p dir="auto">I took some 220 grit sanding paper and cleaned up the waffles on all sides so they slide smoothly. I'm only doing the first 4 waffles and not all 7.</p>
<p dir="auto">Now I just need to grease everything up and reinstall. Tomorrow I'll finish up.</p>
<p dir="auto">I will also wire wheel the black housing and repaint before install.</p>
<p dir="auto"><img src="http://img.tapatalk.com/d/14/01/15/u3uru4y5.jpg" alt="u3uru4y5.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/34352</link><guid isPermaLink="true">https://wibimmers.com/post/34352</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Wed, 15 Jan 2014 03:39:37 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Tue, 14 Jan 2014 16:03:43 GMT]]></title><description><![CDATA[<p dir="auto">Here is a good write up about common issues.</p>
<p dir="auto"><a href="http://nomad-bmw.blogspot.com/2012/10/e30-central-locking-issues.html" rel="nofollow ugc">http://nomad-bmw.blogspot.com/2012/10/e30-central-locking-issues.html</a></p>
]]></description><link>https://wibimmers.com/post/34305</link><guid isPermaLink="true">https://wibimmers.com/post/34305</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Tue, 14 Jan 2014 16:03:43 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Tue, 14 Jan 2014 15:57:23 GMT]]></title><description><![CDATA[<p dir="auto">I just got my trunk lock cylinder disassembled. This was all gumed up. Does pelican parts have a rebuild kit?</p>
<p dir="auto"><img src="http://img.tapatalk.com/d/14/01/14/utuby8u4.jpg" alt="utuby8u4.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/34302</link><guid isPermaLink="true">https://wibimmers.com/post/34302</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Tue, 14 Jan 2014 15:57:23 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Fri, 10 Jan 2014 01:11:34 GMT]]></title><description><![CDATA[<p dir="auto">never investigated, but as long as you can get it apart, i imagine the waffers have to be the same thing as in the door locks. you can definately order one from BMW keyed to your VIN.</p>
]]></description><link>https://wibimmers.com/post/34041</link><guid isPermaLink="true">https://wibimmers.com/post/34041</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Fri, 10 Jan 2014 01:11:34 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Sun, 05 Jan 2014 06:46:03 GMT]]></title><description><![CDATA[<p dir="auto">what's the procedure on taking apart the trunk lock? I've done the door cylinders but never figured out those.</p>
]]></description><link>https://wibimmers.com/post/33855</link><guid isPermaLink="true">https://wibimmers.com/post/33855</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sun, 05 Jan 2014 06:46:03 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Fri, 03 Jan 2014 04:47:43 GMT]]></title><description><![CDATA[<p dir="auto">i definately recommend the rebuilt to save a few $$, its not very difficult.  the hardest part is getting the c-clip on and off to remove the cylinder from the car, but once you master that doing this is a breeze.</p>
<p dir="auto">heres a picture i took of how I diagrammed the rebuild</p>
<p dir="auto"><img src="http://img541.imageshack.us/img541/1484/lvah.jpg" alt="lvah.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">of course, get a new key at the same time you rebuild the lock so they work the best together.  when I rebuilt the lock on my last e30, the original key was so worn it wouldnt work anymore with the rebuilt cylinder.</p>
]]></description><link>https://wibimmers.com/post/33755</link><guid isPermaLink="true">https://wibimmers.com/post/33755</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Fri, 03 Jan 2014 04:47:43 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Fri, 03 Jan 2014 01:11:32 GMT]]></title><description><![CDATA[<p dir="auto">Or move south like Florida so no more snow and more quality time with racecar</p>
]]></description><link>https://wibimmers.com/post/33747</link><guid isPermaLink="true">https://wibimmers.com/post/33747</guid><dc:creator><![CDATA[RamRod E28]]></dc:creator><pubDate>Fri, 03 Jan 2014 01:11:32 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Thu, 02 Jan 2014 16:53:51 GMT]]></title><description><![CDATA[<p dir="auto">Nice. I don have any central locking. And my trunk doesn't lock. Or shut very well if it's cold.</p>
<p dir="auto">We need to move west.</p>
]]></description><link>https://wibimmers.com/post/33722</link><guid isPermaLink="true">https://wibimmers.com/post/33722</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Thu, 02 Jan 2014 16:53:51 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Thu, 02 Jan 2014 15:46:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/33710">CYoung said:</a></strong></p>
<p dir="auto">Wrong link?</p>
<p dir="auto">Oops!  Edited.</p>
]]></description><link>https://wibimmers.com/post/33713</link><guid isPermaLink="true">https://wibimmers.com/post/33713</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Thu, 02 Jan 2014 15:46:23 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Door Lock Cylinder Rekey Link on Thu, 02 Jan 2014 15:40:55 GMT]]></title><description><![CDATA[<p dir="auto">Wrong link?</p>
]]></description><link>https://wibimmers.com/post/33710</link><guid isPermaLink="true">https://wibimmers.com/post/33710</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Thu, 02 Jan 2014 15:40:55 GMT</pubDate></item></channel></rss>
