<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1987 325e Power options?]]></title><description><![CDATA[<p dir="auto">I recently purchased a 1987 bmw 325e for 1400 dollars. It is primarily rust free, everything works except the rear defroster and the window washer pump.</p>
<p dir="auto">I'm currently running into a dilemma however...</p>
<p dir="auto">I wan't to make it fast! No, not 200hp at the crank! I want to atleast be at 350whp with my primary goal being around 400whp.</p>
<p dir="auto">I have the m20b27 motor (2.7liter m20) which is a very torquey motor however it only puts down around 130hp. My motor also happens to have 280k miles on it.</p>
<p dir="auto">So heres where I have two options.</p>
<p dir="auto">for my power goals I would need to:</p>
<p dir="auto">A.</p>
<p dir="auto">swap a m20 325i head (This head has ALOT more flow) onto my existing m20b27 block and then boost it.</p>
<p dir="auto">(I would have to use m20 325i electronics to do the swap. aswell as throttle body and some other misc parts). According to forums I can safely run atleast 15psi off a hx35 or hx1c on the motor with the ONLY modifications being a new (stock) headgasket and ARP headstuds. Keep in mind that this would be done on a block that already has 280k on it. My compression after swapping the 325i head onto the m20 would be 8.5:1 which is perfect for boost. My displacement would also stay at a healthy 2.7 liters.</p>
<p dir="auto">B.</p>
<p dir="auto">swap an m5x or S5x and boost it.</p>
<p dir="auto">I would most likely buy the motor and while its out I would "update" it and install things that will be harder to get at later on.</p>
<p dir="auto">Apparently this swap is easier to do on 88+ E30s due to the fact that it requires some 88+ parts.</p>
<p dir="auto">The most intimidating part for me doing this swap would be wiring. I know the m50's are also easier to swap due to the fact that they are OBD1. However the issue with the m50 is that they only come in a 2.5 liter. I am hoping for atleast a 2.8l so i can run less boost and have the same effect with increased reliability (less stress on the engine).</p>
<p dir="auto">The problem with the s5x is that they are expensive (correct me if i'm wrong?), So at this point I am thinking that the m52b28 would be the best option however I will have to convert from OBDII to OBDI</p>
<p dir="auto">I've never done this swap before and unless a forum member can guide me along the way and help out (possibly? I give free food?) it seems like I will be in uncharted territory as soon as I take the m20 out. granted there are a lot of forums but I have never actually swapped an engine or done the required electronics. Only worked on engines in the bay (Headgaskets etc).</p>
<p dir="auto">For both options I would be reusing my Getrag G260 trans (Pretty bulletproof even at 400hp)</p>
<p dir="auto">What do you think is the better option? and what am I leaving out?</p>
]]></description><link>https://wibimmers.com/topic/2256/1987-325e-power-options</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:49:48 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2256.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Dec 2013 02:04:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1987 325e Power options? on Tue, 31 Dec 2013 16:31:16 GMT]]></title><description><![CDATA[<p dir="auto">It looks like I will be going 2.7i!</p>
<p dir="auto">Check out my build in progress here: <a href="http://www.wibimmers.com/board/index.php?/topic/2261-1987-325e-eventually-boost27i-m20/" rel="nofollow ugc">http://www.wibimmers.com/board/index.php?/topic/2261-1987-325e-eventually-boost27i-m20/</a></p>
<p dir="auto">/threadclose <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/33596</link><guid isPermaLink="true">https://wibimmers.com/post/33596</guid><dc:creator><![CDATA[Laishes]]></dc:creator><pubDate>Tue, 31 Dec 2013 16:31:16 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Mon, 30 Dec 2013 21:32:08 GMT]]></title><description><![CDATA[<p dir="auto">Todd is a great guy/contact to have in this community and if you're boosting you should talk to him.  He helped me out boat loads throughout my build.</p>
<p dir="auto">Spring is coming!  Is this boosted yet?!?</p>
]]></description><link>https://wibimmers.com/post/33569</link><guid isPermaLink="true">https://wibimmers.com/post/33569</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Mon, 30 Dec 2013 21:32:08 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Mon, 30 Dec 2013 20:51:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/33563">Snap ( I <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2764.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--heart" style="height:23px;width:auto;vertical-align:middle" title="&lt;3" alt="❤" /> M50) said:</a></strong></p>
<p dir="auto">$4000 budget should do it. </p>
<p dir="auto">I had the pleasure to meet Todd from TDC a little over a week ago and I expressed my interest in turbos. The above cost is exactly what Todd said it would cost with engine, suspension and drive train related items that would need to be replaced/upgraded to handle the boost. It's not a poor man's hobby but sure is a fun one!</p>
]]></description><link>https://wibimmers.com/post/33566</link><guid isPermaLink="true">https://wibimmers.com/post/33566</guid><dc:creator><![CDATA[mkoepp]]></dc:creator><pubDate>Mon, 30 Dec 2013 20:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Mon, 30 Dec 2013 18:59:34 GMT]]></title><description><![CDATA[<p dir="auto">$4000 budget should do it.</p>
]]></description><link>https://wibimmers.com/post/33563</link><guid isPermaLink="true">https://wibimmers.com/post/33563</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 30 Dec 2013 18:59:34 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Mon, 30 Dec 2013 17:45:29 GMT]]></title><description><![CDATA[<p dir="auto">im going to assume that for the sake of making space on the pass. side, that youd want a late model cooling system/water pump/radiator etc as well</p>
]]></description><link>https://wibimmers.com/post/33558</link><guid isPermaLink="true">https://wibimmers.com/post/33558</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 30 Dec 2013 17:45:29 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Mon, 30 Dec 2013 17:11:21 GMT]]></title><description><![CDATA[<p dir="auto">For the i head swap you'll need everything from the i except the block, starter and radiator.</p>
]]></description><link>https://wibimmers.com/post/33555</link><guid isPermaLink="true">https://wibimmers.com/post/33555</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Mon, 30 Dec 2013 17:11:21 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Mon, 30 Dec 2013 16:34:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/33465">Laishes said:</a></strong></p>
<p dir="auto">Pretty much!</p>
<p dir="auto">But na, I figure 400hp in a 2700lb chassis is plenty for me <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">Welcome to light ass bmw league</p>
]]></description><link>https://wibimmers.com/post/33550</link><guid isPermaLink="true">https://wibimmers.com/post/33550</guid><dc:creator><![CDATA[RamRod E28]]></dc:creator><pubDate>Mon, 30 Dec 2013 16:34:28 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sun, 29 Dec 2013 06:02:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/33448">Ramze46 said:</a></strong></p>
<p dir="auto">I'm gonna be megasquirting my e28 and running a t4 on it on the economy m20 engine and eventually swap to the normal m20 head for more flow. Until I blow it up and deem it useless then swap to ls1!!!</p>
<p dir="auto">Thinking about keeping the m20 thus far. It's just cheaper and far more easier than other options it seems. Although if I was to boost I would run the 2.5i head on the 2.7 block</p>
]]></description><link>https://wibimmers.com/post/33466</link><guid isPermaLink="true">https://wibimmers.com/post/33466</guid><dc:creator><![CDATA[Laishes]]></dc:creator><pubDate>Sun, 29 Dec 2013 06:02:01 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sun, 29 Dec 2013 06:00:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/33464">Snap ( I <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2764.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--heart" style="height:23px;width:auto;vertical-align:middle" title="&lt;3" alt="❤" /> M50) said:</a></strong></p>
<p dir="auto">You sound like you want 1000hp</p>
]]></description><link>https://wibimmers.com/post/33465</link><guid isPermaLink="true">https://wibimmers.com/post/33465</guid><dc:creator><![CDATA[Laishes]]></dc:creator><pubDate>Sun, 29 Dec 2013 06:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sun, 29 Dec 2013 05:41:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/33462">Laishes said:</a></strong></p>
<p dir="auto">can a m30b35 out-horsepower a s50/s52b30 when boosted due to the increased displacement?</p>
<p dir="auto">All other things equal, no, 24v heads flow better. </p>
<p dir="auto">Its also a game of quantity of power vs quality of power.</p>
]]></description><link>https://wibimmers.com/post/33464</link><guid isPermaLink="true">https://wibimmers.com/post/33464</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 29 Dec 2013 05:41:03 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sun, 29 Dec 2013 03:56:55 GMT]]></title><description><![CDATA[<p dir="auto">Also; does anyone know offhand if the "sand beige" m3 vader seats are the same color as the "sand beige" e30 interior? If I were to get a pair and swap out my front seats would they match the rear seats at all?</p>
]]></description><link>https://wibimmers.com/post/33463</link><guid isPermaLink="true">https://wibimmers.com/post/33463</guid><dc:creator><![CDATA[Laishes]]></dc:creator><pubDate>Sun, 29 Dec 2013 03:56:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sun, 29 Dec 2013 03:55:34 GMT]]></title><description><![CDATA[<p dir="auto">can a m30b35 out-horsepower a s50/s52b30 when boosted due to the increased displacement?</p>
]]></description><link>https://wibimmers.com/post/33462</link><guid isPermaLink="true">https://wibimmers.com/post/33462</guid><dc:creator><![CDATA[Laishes]]></dc:creator><pubDate>Sun, 29 Dec 2013 03:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sun, 29 Dec 2013 00:59:27 GMT]]></title><description><![CDATA[<p dir="auto">Or go M30 + snail.  That's what a lot of them ur-op folks do.</p>
]]></description><link>https://wibimmers.com/post/33456</link><guid isPermaLink="true">https://wibimmers.com/post/33456</guid><dc:creator><![CDATA[rampelsauce]]></dc:creator><pubDate>Sun, 29 Dec 2013 00:59:27 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sat, 28 Dec 2013 15:14:35 GMT]]></title><description><![CDATA[<p dir="auto">I'm gonna be megasquirting my e28 and running a t4 on it on the economy m20 engine and eventually swap to the normal m20 head for more flow. Until I blow it up and deem it useless then swap to ls1!!!</p>
]]></description><link>https://wibimmers.com/post/33448</link><guid isPermaLink="true">https://wibimmers.com/post/33448</guid><dc:creator><![CDATA[RamRod E28]]></dc:creator><pubDate>Sat, 28 Dec 2013 15:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to 1987 325e Power options? on Sat, 28 Dec 2013 03:17:41 GMT]]></title><description><![CDATA[<p dir="auto">I think the popular answer would be M50 + turbo but I think the lowest cost route to 400hp would be an M20 + turbo</p>
]]></description><link>https://wibimmers.com/post/33439</link><guid isPermaLink="true">https://wibimmers.com/post/33439</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sat, 28 Dec 2013 03:17:41 GMT</pubDate></item></channel></rss>
