<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Question about the e46]]></title><description><![CDATA[<p dir="auto">I'm looking at a couple different e46 models and was wondering if anyone here owns one.</p>
<p dir="auto">The ones i'm looking at  are the 323i or the 330ci. </p>
<p dir="auto">!)Whats the common problems with these models and whats the worse you have experienced with your car?</p>
<p dir="auto">2)What do you personally like about the model you own?</p>
]]></description><link>https://wibimmers.com/topic/2157/question-about-the-e46</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:00:22 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2157.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Dec 2013 02:25:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Question about the e46 on Thu, 02 Jan 2014 18:19:57 GMT]]></title><description><![CDATA[<p dir="auto">I've had my 2001 330i for a bit over a year now. Bought from a repair place in Marion that didn't do the best of work. Only things I've had to do so far have been pump leak on washer fluid resevoir, lower hose coolant temp sensor, thermostat and front control arms. The torque of engine is great- an all around fun car.</p>
]]></description><link>https://wibimmers.com/post/33728</link><guid isPermaLink="true">https://wibimmers.com/post/33728</guid><dc:creator><![CDATA[Hammerdown]]></dc:creator><pubDate>Thu, 02 Jan 2014 18:19:57 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Thu, 02 Jan 2014 15:30:01 GMT]]></title><description><![CDATA[<p dir="auto">E46s have vanos issues; rear subframe issues. Sometimes harmonic balancing issues (aluminum block right?) and the cooling system (just like with an e39) will need to be gone through. If you want a used e46 to be reliable I would fix all the issues listed above.</p>
<p dir="auto">Anddd that'll usually run your wallet outve money.</p>
<p dir="auto">Sent from my iPhone using <a href="http://tapatalk.com/m?id=1" rel="nofollow ugc">Tapatalk</a></p>
]]></description><link>https://wibimmers.com/post/33709</link><guid isPermaLink="true">https://wibimmers.com/post/33709</guid><dc:creator><![CDATA[Laishes]]></dc:creator><pubDate>Thu, 02 Jan 2014 15:30:01 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Thu, 02 Jan 2014 13:21:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/32045">xXxGOODKILLAxXx said:</a></strong></p>
<p dir="auto">Thanks for the reply's, so the major thing I guess I should be looking for is if the rear sub-frame has cracks or not. Anyone here have that issue yet if so did you have it repaired and what did it cost? </p>
<p dir="auto">Here is a thread I started about my M3 subframe issues.  The worst I've ever seen.  <a href="http://www.m3forum.net/m3forum/showthread.php?t=378512" rel="nofollow ugc">http://www.m3forum.net/m3forum/showthread.php?t=378512</a></p>
]]></description><link>https://wibimmers.com/post/33699</link><guid isPermaLink="true">https://wibimmers.com/post/33699</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Thu, 02 Jan 2014 13:21:58 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Tue, 03 Dec 2013 17:31:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">See this thread <a href="http://www.wibimmers.com/board/index.php?/topic/1696-a-note-to-all-e46-owners/" rel="nofollow ugc">http://www.wibimmers.com/board/index.php?/topic/1696-a-note-to-all-e46-owners/</a></p>
]]></description><link>https://wibimmers.com/post/32052</link><guid isPermaLink="true">https://wibimmers.com/post/32052</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Tue, 03 Dec 2013 17:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Tue, 03 Dec 2013 09:18:41 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply's, so the major thing I guess I should be looking for is if the rear sub-frame has cracks or not. Anyone here have that issue yet if so did you have it repaired and what did it cost?</p>
]]></description><link>https://wibimmers.com/post/32045</link><guid isPermaLink="true">https://wibimmers.com/post/32045</guid><dc:creator><![CDATA[xXxGOODKILLAxXx]]></dc:creator><pubDate>Tue, 03 Dec 2013 09:18:41 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Mon, 02 Dec 2013 18:27:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/32012">Ramze46 said:</a></strong></p>
<p dir="auto">I have an 2000 328i e46 and by far the best car I've owned to date I like mine over the 330 due to the engine has been around forever and I love the look of a pre face lifted e46</p>
<p dir="auto">The engines are pretty much the same, your engine is the m52b28tu compared to the m52b28 that was in the e36 328's.  Yours is aluminum block and dual vanos.  The heads/ blocks are not interchangeable with m50/52.  Not saying thats a bad thing, just the m52tu is interchangeable to the m54 but you still have a cable throttle  vs drive by wire that the m54's have.</p>
]]></description><link>https://wibimmers.com/post/32014</link><guid isPermaLink="true">https://wibimmers.com/post/32014</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 02 Dec 2013 18:27:58 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Mon, 02 Dec 2013 18:01:07 GMT]]></title><description><![CDATA[<p dir="auto">I have an 2000 328i e46 and by far the best car I've owned to date I like mine over the 330 due to the engine has been around forever and I love the look of a pre face lifted e46</p>
]]></description><link>https://wibimmers.com/post/32012</link><guid isPermaLink="true">https://wibimmers.com/post/32012</guid><dc:creator><![CDATA[RamRod E28]]></dc:creator><pubDate>Mon, 02 Dec 2013 18:01:07 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Sun, 01 Dec 2013 03:12:15 GMT]]></title><description><![CDATA[<p dir="auto">The power difference between a 323 and 330 is very large. If I had a chaoice between the two, 330 no question.</p>
<p dir="auto">Tons of info here: <a href="http://forum.e46fanatics.com/showthread.php?t=1007722" rel="nofollow ugc">http://forum.e46fanatics.com/showthread.php?t=1007722</a></p>
]]></description><link>https://wibimmers.com/post/31934</link><guid isPermaLink="true">https://wibimmers.com/post/31934</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Sun, 01 Dec 2013 03:12:15 GMT</pubDate></item><item><title><![CDATA[Reply to Question about the e46 on Sun, 01 Dec 2013 03:02:18 GMT]]></title><description><![CDATA[<p dir="auto">I know there are a few guys on here with e46's</p>
<p dir="auto">Maybe they will chime in!</p>
]]></description><link>https://wibimmers.com/post/31933</link><guid isPermaLink="true">https://wibimmers.com/post/31933</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Sun, 01 Dec 2013 03:02:18 GMT</pubDate></item></channel></rss>
