<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M42 surprise]]></title><description><![CDATA[<p dir="auto">So finally getting into some work on the 1991 318is. Oil leak due to a bad lower pan repair so picked up a replacement lower pan</p>
<p dir="auto"><img src="http://img.tapatalk.com/d/13/11/10/gapy9uqy.jpg" alt="gapy9uqy.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Turns out I'm also missing two upper pan bolts. Not in the lower pan so great mystery as to where they went. Four bolts next to the dipstick are there but the two pan bolts at the ends are not.</p>
<p dir="auto"><img src="http://img.tapatalk.com/d/13/11/10/2ydu5y2a.jpg" alt="2ydu5y2a.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/topic/2090/m42-surprise</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:03:21 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2090.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Nov 2013 22:43:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M42 surprise on Sun, 10 Nov 2013 03:17:54 GMT]]></title><description><![CDATA[<p dir="auto">I use indian head shellac on my paper gaskets</p>
]]></description><link>https://wibimmers.com/post/31020</link><guid isPermaLink="true">https://wibimmers.com/post/31020</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sun, 10 Nov 2013 03:17:54 GMT</pubDate></item><item><title><![CDATA[Reply to M42 surprise on Sun, 10 Nov 2013 01:35:16 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. Other four upper pan bolts were barely finger tight. Nice... Replaced the missing bolts and blue locktite on all six of them.</p>
]]></description><link>https://wibimmers.com/post/31018</link><guid isPermaLink="true">https://wibimmers.com/post/31018</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sun, 10 Nov 2013 01:35:16 GMT</pubDate></item><item><title><![CDATA[Reply to M42 surprise on Sun, 10 Nov 2013 00:34:31 GMT]]></title><description><![CDATA[<p dir="auto">Looks like its going to be the same  18mm long M6 hardware as the rest of the oil pan screws. Im guessing the previous mechanic became lazy/negligent/hungry.</p>
<p dir="auto">I am running an oil pan baffle and crank scraper which sandwiches between the pan and the block. I tried using two paper gaskets + rtv, but it became a nightmare when trying to get the oil pan screw holes to line up on all of the pieces so that the screw could actually be threaded in.</p>
<p dir="auto">I ended up using black rtv only, no paper gaskets, and have had great success.  Some manufacturers run gasketless from the factory, just rtv applied by an angry union guy or an angry union robotic arm.</p>
]]></description><link>https://wibimmers.com/post/31014</link><guid isPermaLink="true">https://wibimmers.com/post/31014</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 10 Nov 2013 00:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to M42 surprise on Sun, 10 Nov 2013 00:16:56 GMT]]></title><description><![CDATA[<p dir="auto">Related question: oil pan paper gasket, install dry or permatex/rtv on one/both sides?</p>
]]></description><link>https://wibimmers.com/post/31013</link><guid isPermaLink="true">https://wibimmers.com/post/31013</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sun, 10 Nov 2013 00:16:56 GMT</pubDate></item><item><title><![CDATA[Reply to M42 surprise on Sat, 09 Nov 2013 22:55:08 GMT]]></title><description><![CDATA[<p dir="auto">Second pic<img src="http://img.tapatalk.com/d/13/11/10/utu9aqar.jpg" alt="utu9aqar.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/31010</link><guid isPermaLink="true">https://wibimmers.com/post/31010</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 09 Nov 2013 22:55:08 GMT</pubDate></item></channel></rss>
