<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Best way to drain an E30 fuel tank?]]></title><description><![CDATA[<p dir="auto">Anyone know the best way to drain the fuel tank in a 89 325IS? Is the fuel outlet off the side if the tank where I can pull the "send" line, or do I have to pull the line an jumper a relay?</p>
<p dir="auto">Any help would be great, if it's jumper the relay an help with the "do-this and this" would be great as I suck with electrical. Thanks!!!</p>
]]></description><link>https://wibimmers.com/topic/2059/best-way-to-drain-an-e30-fuel-tank</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:39:42 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2059.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Oct 2013 22:57:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Fri, 01 Nov 2013 05:44:46 GMT]]></title><description><![CDATA[<p dir="auto">just be careful of fires</p>
<p dir="auto"><img src="http://stream1.gifsoup.com/webroot/animatedgifs/95095_o.gif" alt="95095o.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/30591</link><guid isPermaLink="true">https://wibimmers.com/post/30591</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 01 Nov 2013 05:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Fri, 01 Nov 2013 00:53:58 GMT]]></title><description><![CDATA[<p dir="auto">my drain plug was stripped so we had to drop it down full of gas.</p>
]]></description><link>https://wibimmers.com/post/30581</link><guid isPermaLink="true">https://wibimmers.com/post/30581</guid><dc:creator><![CDATA[andyhundley]]></dc:creator><pubDate>Fri, 01 Nov 2013 00:53:58 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Thu, 31 Oct 2013 22:19:42 GMT]]></title><description><![CDATA[<p dir="auto">large tank e30's (with transfer tube and single in tank pump)  drain plug on the passenger side.  takes an allen. do not take off the transfer tube (below the driveshaft) as it will most likely crimp the tube. </p>
<p dir="auto">small tank e30's (dual pumps in tank ...one on each side)  should be on the same side.</p>
]]></description><link>https://wibimmers.com/post/30578</link><guid isPermaLink="true">https://wibimmers.com/post/30578</guid><dc:creator><![CDATA[jason89i]]></dc:creator><pubDate>Thu, 31 Oct 2013 22:19:42 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Thu, 31 Oct 2013 17:39:57 GMT]]></title><description><![CDATA[<p dir="auto">I want sure if E30 were a "tank in pump" setup where the access/holes were on top of the tank, or if they used an inline filter that would use a bung on the tank (then I could just pull the send line and empty the tank).</p>
<p dir="auto">I'll look for a drain tonight then, unless some one can tell me a good way to jumper the pump relay )since I'm pulling the line into the filter anyways).</p>
]]></description><link>https://wibimmers.com/post/30563</link><guid isPermaLink="true">https://wibimmers.com/post/30563</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Thu, 31 Oct 2013 17:39:57 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Thu, 31 Oct 2013 16:28:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/30558">Earl said:</a></strong></p>
<p dir="auto">That is what I thought? Luckily you didn't need to use it and a jack stand did it for you=) Sorry John, couldn't resist</p>
<p dir="auto">yeah i know, i took the easy way out.</p>
]]></description><link>https://wibimmers.com/post/30559</link><guid isPermaLink="true">https://wibimmers.com/post/30559</guid><dc:creator><![CDATA[johnprusinski]]></dc:creator><pubDate>Thu, 31 Oct 2013 16:28:29 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Thu, 31 Oct 2013 16:04:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/30557">johnprusinski said:</a></strong></p>
<p dir="auto">shouldn't there be a drain hole? i know there is one on my gas tank. if there isn't a drain hole just disconnect hoses and don't smoke. </p>
]]></description><link>https://wibimmers.com/post/30558</link><guid isPermaLink="true">https://wibimmers.com/post/30558</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 31 Oct 2013 16:04:03 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Thu, 31 Oct 2013 15:42:34 GMT]]></title><description><![CDATA[<p dir="auto">shouldn't there be a drain hole? i know there is one on my gas tank. if there isn't a drain hole just disconnect hoses and don't smoke.</p>
]]></description><link>https://wibimmers.com/post/30557</link><guid isPermaLink="true">https://wibimmers.com/post/30557</guid><dc:creator><![CDATA[johnprusinski]]></dc:creator><pubDate>Thu, 31 Oct 2013 15:42:34 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Thu, 31 Oct 2013 14:23:27 GMT]]></title><description><![CDATA[<p dir="auto">I was gonna say I've dropped 1/2 full tanks before, which I know is never advised to do. Just take the extra precautions to make sure you don't start a fire.</p>
]]></description><link>https://wibimmers.com/post/30553</link><guid isPermaLink="true">https://wibimmers.com/post/30553</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Thu, 31 Oct 2013 14:23:27 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Thu, 31 Oct 2013 02:25:51 GMT]]></title><description><![CDATA[<p dir="auto">Thats a good story. my tank leaked and my gage was reading a 1/8th of a tank so i figured that it was near empty. once we dropped it and disconnected the filler neck hose, it poured roughly 10-12 gallons of gas on the ground. does that help at all? haha</p>
]]></description><link>https://wibimmers.com/post/30523</link><guid isPermaLink="true">https://wibimmers.com/post/30523</guid><dc:creator><![CDATA[andyhundley]]></dc:creator><pubDate>Thu, 31 Oct 2013 02:25:51 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to drain an E30 fuel tank? on Wed, 30 Oct 2013 23:31:11 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://u.jimdo.com/www36/o/s81524813caa3b966/img/id423e3b094e049a8/1357735506/std/bmw-3series-e30-burnout.jpg" alt="bmw-3series-e30-burnout.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Ask andyhundley, he just replaced his tank. If it were me, i would disconnect the downstream line on the fuel filter ( located just forward of the driver rear tire, and drain it into some buckets with the relay jumpered. I dont know the pins right off hand but I will research.</p>
]]></description><link>https://wibimmers.com/post/30516</link><guid isPermaLink="true">https://wibimmers.com/post/30516</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 30 Oct 2013 23:31:11 GMT</pubDate></item></channel></rss>
