<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stereo head unit issue]]></title><description><![CDATA[<p dir="auto">Somewhere in the history of the e30 a PO installed an aftermarket stereo with removable face plate. Some quirky wiring issues such as hit the defrost switch when the unit is on and it blows a fuse and the unit and OEM power antenna aren't talking to each other. I can live with these.</p>
<p dir="auto">The more pressing issue is that on hard braking and acceleration the head unit slips out of the dash on the driver's side by about 1/2 -3/4 inch. I push it back in and all is good but it would be better if it didn't move.</p>
<p dir="auto">Any recommendations for a Milwaukee area install shop that could address this issue for cheap or any DIY suggestions short of shimming it into the dash would be appreciated!</p>
]]></description><link>https://wibimmers.com/topic/202/stereo-head-unit-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:32:05 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/202.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Jul 2011 23:48:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stereo head unit issue on Thu, 28 Jul 2011 16:55:39 GMT]]></title><description><![CDATA[<p dir="auto">i remember the antenna wire on my e30 was orange with no tracer...</p>
]]></description><link>https://wibimmers.com/post/2093</link><guid isPermaLink="true">https://wibimmers.com/post/2093</guid><dc:creator><![CDATA[Chadley]]></dc:creator><pubDate>Thu, 28 Jul 2011 16:55:39 GMT</pubDate></item><item><title><![CDATA[Reply to Stereo head unit issue on Sat, 23 Jul 2011 06:58:15 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the replies.</p>
<p dir="auto">I've got a track day coming up on Monday and the car is running fine so I won't play with any wiring this weekend. Just my luck and things would go south.</p>
<p dir="auto">It looks like there is a sleeve but maybe whatever tabs needed to be bent to hold things in place aren't.</p>
<p dir="auto">Also found two sets of antenna cables and power wires running into the trunk. Neither one works to raise the antenna when all hooked up but could be the power antenna or the hook up to the head unit. I do get radio reception in the city without the antenna up but lose it a few miles out. Ipod hookup works so not that big a deal.</p>
]]></description><link>https://wibimmers.com/post/2045</link><guid isPermaLink="true">https://wibimmers.com/post/2045</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 23 Jul 2011 06:58:15 GMT</pubDate></item><item><title><![CDATA[Reply to Stereo head unit issue on Sat, 23 Jul 2011 01:52:10 GMT]]></title><description><![CDATA[<p dir="auto">most aftermarket radios have an output wire for power antennas, youll probably just have to connect them properly. as for the fuse blowing, maybe there is a loose or frayed wire back there as they are in close proximity. have you pulled the unit out to inspect at all?</p>
]]></description><link>https://wibimmers.com/post/2032</link><guid isPermaLink="true">https://wibimmers.com/post/2032</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 23 Jul 2011 01:52:10 GMT</pubDate></item><item><title><![CDATA[Reply to Stereo head unit issue on Sat, 23 Jul 2011 01:07:11 GMT]]></title><description><![CDATA[<p dir="auto">i can help you out for a day of giggles. sounds like the po didnt put a sleeve around the radio</p>
]]></description><link>https://wibimmers.com/post/2031</link><guid isPermaLink="true">https://wibimmers.com/post/2031</guid><dc:creator><![CDATA[Chadley]]></dc:creator><pubDate>Sat, 23 Jul 2011 01:07:11 GMT</pubDate></item></channel></rss>
