  4. '88 E30
'88 E30
1.1k Posts 36 Posters 0 Views 1 Watching
    Drove it home from storage today
    Promptly folded the mirrors
    See you fuckers in 2019
      snap said:
      Lovely engagement photo, Mr and Mrs Kaiser!
        C&C on April 14th?!?!?!?
          4/14/2019
          See you there
            In the quest to lower intake temps, I have come to a realization.
            After much deliberation with snap, wasntm3 & staring at the engine bay for hours- air to air and air to water Intercooling have been tossed as there is not sufficient room. Which leaves meth injection as the remaining option.
            Next up on the to do list is to replace the intake & charge pipe with something a little less plastic that can hold some threads and dissipate heat better than the 1/4” thick abs.
            Also I know my MS3 can control the spray, but at this point I’d rather get something that has its own controller for simplicity sake.
            If anyone has some experience with any specific meth kits or if you’ve pieced your own together I’d love to hear about it.
            Was looking at devils own/aquamist/snow performance
            Picture of 20lbs of shit in a 10lb bag
              After rotating my head 90 degrees onto my shoulder, I noticed that you have lots of ample room for all sorts of things on the left side of your engine bay......
              air to air and air to water Intercooling have plenty of room to party over there.
                Info on the Moroso coolant expansion tank? I wont be able to use the Zionsville setup anymore and that looks like a nice solution.
                  Rotate your phone silly!
                  Thought about it. That’s a lot of pipe routing to put it next to the headers
                    It’s an okay solution, quite a bit smaller size - shouldn’t really be much of an issue assuming the rest of the cooling system is adequate.
                    https://www.summitracing.com/parts/mor-63766?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-moroso&gclid=EAIaIQobChMIvaLUsozj2gIVEC9pCh1deg_8EAQYAyABEgLivvD_BwE
                      Daggerty
                      Get @patsbimmer1 to get you a price on this.
                      https://www.ecstuning.com/b-snowperformance-parts/stage-1-water-meth-injection-kit/20001~sno/
                      I put together my own following this http://www.turbomirage.com/water there is different shuflo pumps you can use then what he has that are cheaper they just take up more space. I can get you the hook up on the lines for it and push in style fittings. The hobbs switch from Napa you can get else where for way cheaper than $30. Depending on what kind of oil pressure switch you can use them. Don't buy the wash rack nozzles he suggests just get some name brand ones that have R&D.
                      Is it worth doing it yourself? If you are like me and have all the stuff readily accessible at low cost and are the biggest Jew around, offense, then yes.
                      If you can get one under $300, then do it if you just want an easy install that's done in a couple of hours.
                        Daggerty
                        There is no reason to run a whole bunch of intercooler piping when the intake is right there. You would just be robbing power. In turbo cars it makes sense because the exhaust is on the opposite side of the intake so you have to run the piping anyways so fmic air to air, yeah.
                        Manufactures like to use air to water coolers because they take up less space in a way. You don't have a giant fmic to fit under a bumper cover. And they have more parts so more money for the dealer when they fail. These system also can only do so good if you are doing pull after pull unless you have it plumbed to your ac system or 10 gallon ice tank.
                        Both of these also make more restrictions for the intake because you have a core for them to go through, turbulent air ,restriction, blah blah blah. No I am not drunk.
                        The 1 stage kit you can only have come on at one boost setting but you can tee off the line to put 2 nozzles in. A nozzle before the blower is ideal because it creates a seal around the fins rotors whatever you got. Creating that extra .0002 psi, something to do with it being compressed, moving it fast to evaporate, and its cooling the unit creating the boost down also. Some say this damages the turbine, there is no evidence supporting this. There is evidence however that the meth will eat away at the coating on certain rotors/screws.
                        When you tune it make sure you have a failsafe for the meth if it stops, weather it be a spark cut or you do your tuning without it then turn it on. Because running a tune created with meth can be as aggressive as race gas but if it stops then you're just on pump gas with a crap load of timing.
                        everything on the internet about meth can be found above by this guy who wasted his life typing it. Sorry if you read all that
                          Daggerty
                          I am happy I choose meth 😈 it is one of the path less traveled things that is good. E85 is similar to it by adding octane and cooling abilities, with kind of plug and play once you have the system. Instead of worrying about an extra tank to fill.
                            Im quoting this because I am thankful for the info, but I couldn't laugh at the same time.. LOL.
                              I read it all, affirms many things. I was thinking pre TB spray (post sc) in this case. Which means I’ll likely ditch the plastic intake crap from VF as they don’t really hold threads and they annoy me.
                              I’ll be running ms3, which can control water/meth injection, but I’d most likely just use the controller that comes with that kit and only spray to keep IATs down, not to advance the timing (for now)
                                lower intake temps, meth, blah, blah, blah...send it!
                                  @patsbimmer1 $ check on the kit Daggerty posted pls
                                    Mirrors are folded in on this one too lol
                                      This will be for sale eventually/soon. Just need to slap it back together
                                        Will you take 1k and my slightly eatin sandwich?
                                        It's from Kwik Trip 😉
                                          Just make sure it's drivable next time I visit.
