  4. '88 E30
'88 E30
savebigmoney
    Bassboy3313 said:
    Why isn't this done yet? Ay ay ay!!
    Because I suck at buying things
    andyhundley said:
    Are you gonna make it to the E30 Picnic?
    Nope. Going to automotion with some friends
      Parts should be getting here mid to late next week.
      I'll be able to get the s50 sealed up and ready to go.
      Still have to order a radiator/hoses, engine mounts, Trans mounts, O2 sensor and some random other crap for the car.
      Right now the focus is on getting the motor sealed up & ready
        This stuff was a pain in the ass
        After the silicone spray to seal&make color last
        Exhaust Hardware/gaskets came today as well. New studs to mount these and then the rest of the parts show up Thursday/Friday hopefully
          Does header wrap still cause manifolds to corrode and crack?
            Did you get new lock nutz?
              Under the "Fair Oxidation Treaty of 2013" wraps and coatings applied to tubular internal combustion engine components are now exempt from defects caused by corrosion.
                New hardware yes
                  Never had it happen to Any other stuff I've had wrapped. Even if it does. These are raceland headers that barely fit correctly. They don't look very nice either.
                  Earl you worry too much
                    The Ebay/Raceland Headers sound much better after being wrapped. The ones I did look exactly like yours, I hate that you have to wrap the three tubes as one...
                    Looks Good!
                      Looks Good!
                      Thanks man
                      I wrapped 2 from collector to manifold. Then started at end of exhaust, worked my way back to the manifold side going from 3-2-1 tubes.
                      It is annoying that 3 have to be wrapped but oh well
                        Installed, bimmer world shorted me of hardware. Copper nuts, I need 24, they sent 18. More like bummer world. I ended up reusing 6 old ones from one of the two 24 valvers I have.
                        They sent me a pack of gummy bears, but not the right amount of hardware. Priorities.
                          Gummy bears = priority
                            Thy are sending me more nuts. But I already used some from the m50.
                            Convenient
                              New waterpump, tstat/housing are on. Need to rob the tensioner off the m50 yet.
                              New oil line from vanos to oil filter housing as well. 47a14b33d5e3e1bbda597846c6bcc669.jpg42e1f6a0e5923365d1be8980b369e7af.jpg
                              Today I'm going to swap pans/pickup/new oil pump nut. Put on the new sensors, see how far I can get before I need to swap the harness
                                Things happened over the weekend. Got the valve cover on for good now. Spark plugs are on their way as well.
                                Got the pan off the s50 with no broken bolts/surprises.
                                Had the m50 on the hoist, popped the pan and pickup tube off the motor. Robbed the ECS magnetic drain plug for the e34 pan. Realized I never order a damn oil pickup tube gasket.
                                Ordered one, also ordered trans mounts, engine mounts, power steering delete block/plate, dipstick orings and new PCV piece/hoses. I'll still need to buy some hose that goes from the fuel pressure regulator to the intake manifold.
                                Engine wise I'm pretty sure that's about it right now.
                                Safety wired the oil pump nut from bimmer world
                                The oil pump nut on the m50 was finger loose...the s50 was still good and tight-but added piece of mind is nice.
                                Cut the tab off for the old pickup tube (so the e34 pan will fit) and cleaned up the windage tray and reinstalled.
                                Gunk'd the pan and sprayed it white. This will be dirty before the car even has oil in it
                                  holy crap, logged on with a computer,
                                  Tapatalk takes the formatting and fist phuks it
                                    anybody have clutch/flywheel/pressure plate recommendations?
                                    I'm open to opinions
                                    inb4 stock (im open to that option as well, just curious if anyone has had luck with anything else)
                                    thanks dudes
                                      I love my UUC/Fidanza flywheel with e34 m5 OE clutch.  It is spendy though.
                                        I was looking into grip force setups on their website. They offer some "packages" with the fidanza flywheel option; or their fx racing single mass flywheels. From what I've read some use re-badged LUK clutches.
                                        Id rather only do this once.
                                        Here's a link to what some dudes on bimmerforums run and like
                                        http://www.ebay.com/itm/FX-STAGE-2-RACE-CLUTCH-KIT-14-4-LBS-CHROMOLY-FLYWHEEL-fits-BMW-M3-Z3-E36-S50-S52-/161702586973?vxp=mtr&hash=item25a639aa5d
                                          The fidanza branded flywheels are made for an m3 clutch. The uuc ones are made by fidanza but machined differently for the e34 m5 clutch just an FYI.
                                          Sent from my potato phone
