<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DIY  e30 differential removal.]]></title><description><![CDATA[<p dir="auto">So Benjamin (gunmetalgray) and I decided to remove the 4.10 LSD from my rolled 318is. We had everything you could ever want to do the job right; tools, ambition, stunning good looks, a faithful dog, and slightly overcast skies with a nice wind.</p>
<p dir="auto">Tools used:</p>
<p dir="auto">2- 19mm socket</p>
<p dir="auto">2- 1/2" socket wrench</p>
<p dir="auto">2- breaker bars</p>
<p dir="auto">1- 1970's Mustang Bobcat</p>
<p dir="auto">1- Milwaukee Sawzall</p>
<p dir="auto">To start, we had to drag the disgusting wreck of a car up to the parking pad. All went well.</p>
<p dir="auto">Then, we jacked that baby up and used cinder blocks as jack stands. All went well.</p>
<p dir="auto">Then, we started to remove various nuts, bolts, and tetanus (aka rust) covered heat shields. All went well.</p>
<p dir="auto">Then, shit got real tricky. To remove the differential, one must remove 2 bolts located on top of the diff, and two on the side that mount it to the rear subframe. In order to remove those bolts, we decided to use the sawzall to cut the sway bar end links in half so it would be easier to access the bolts. No pics of that, but trust me, all went well.</p>
<p dir="auto">After loosening the bolts mentioned above, we set out to remove the driveshaft from the differential. This looked awfully hard, so we decided to cut the driveshaft in half approximately 3" behind the rear subframe.</p>
<p dir="auto"><a href="http://bimmerfest.com/forums/attachment.php?attachmentid=286030&amp;d=1311281348" rel="nofollow ugc">http://bimmerfest.com/forums/attachment.php?attachmentid=286030&amp;d=1311281348</a></p>
<p dir="auto">After making 3 very poor cuts the driveshaft was still in one piece, and the differential was still stuck in place. To remove it, we had the brilliant idea of strapping the differential to the bobcat and simply pulling it out backwards. All went better than expected.</p>
<p dir="auto"><a href="http://bimmerfest.com/forums/attachment.php?attachmentid=286029&amp;d=1311281348" rel="nofollow ugc">http://bimmerfest.com/forums/attachment.php?attachmentid=286029&amp;d=1311281348</a></p>
<p dir="auto">After a little finagling around with the halfshafts the diff decided to pop out. Sweet.</p>
<p dir="auto"><a href="http://bimmerfest.com/forums/attachment.php?attachmentid=286032&amp;d=1311281348" rel="nofollow ugc">http://bimmerfest.com/forums/attachment.php?attachmentid=286032&amp;d=1311281348</a></p>
<p dir="auto">We decided to leave this peice of the driveshaft still attached. If it looks razor sharp in the pic. that's because it is.</p>
<p dir="auto"><a href="http://bimmerfest.com/forums/attachment.php?attachmentid=286033&amp;d=1311281348" rel="nofollow ugc">http://bimmerfest.com/forums/attachment.php?attachmentid=286033&amp;d=1311281348</a></p>
<p dir="auto">Now you can sit back and enjoy the view.</p>
<p dir="auto"><a href="http://bimmerfest.com/forums/attachment.php?attachmentid=286034&amp;d=1311281348" rel="nofollow ugc">http://bimmerfest.com/forums/attachment.php?attachmentid=286034&amp;d=1311281348</a></p>
<p dir="auto">And look at these two studs!!!!!!!!!!!!!!!</p>
<p dir="auto"><a href="http://bimmerfest.com/forums/attachment.php?attachmentid=286031&amp;d=1311281348" rel="nofollow ugc">http://bimmerfest.com/forums/attachment.php?attachmentid=286031&amp;d=1311281348</a></p>
<p dir="auto">Moral of the story; if you need a part removed, feel free to ask for my or Ben's help, we get shit done.</p>
<p dir="auto">The End.</p>
]]></description><link>https://wibimmers.com/topic/201/diy-e30-differential-removal.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 03:59:49 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/201.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Jul 2011 21:19:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DIY  e30 differential removal. on Thu, 21 Jun 2012 16:50:01 GMT]]></title><description><![CDATA[<p dir="auto">wow.... ive swapped many diffs... never had anything seized up so bad I had to chop the DS in half. Oh well, im guessing you didnt need it anymore. I just apply heat with a torch, quench with PB blaster.... give it some time... Use a 1/2" breaker bar... if that doesnt work repeat heat, quench, time.... sooner or later it will come. Might have to use impact sockets as well and an airdrive.</p>
<p dir="auto">Biggest thing is remember to disconnect the speed sensor before you drop the diff or you could fuck it up. I did that once... <img src="/assets/uploads/files/emoticons_default_sad.png" alt=":(" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/7973</link><guid isPermaLink="true">https://wibimmers.com/post/7973</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Thu, 21 Jun 2012 16:50:01 GMT</pubDate></item><item><title><![CDATA[Reply to DIY  e30 differential removal. on Sat, 23 Jul 2011 04:53:25 GMT]]></title><description><![CDATA[<p dir="auto">Milwaukee Sawzall (for that matter any Milwaukee power tool) FTW. I dont blame you.</p>
]]></description><link>https://wibimmers.com/post/2034</link><guid isPermaLink="true">https://wibimmers.com/post/2034</guid><dc:creator><![CDATA[rampelsauce]]></dc:creator><pubDate>Sat, 23 Jul 2011 04:53:25 GMT</pubDate></item><item><title><![CDATA[Reply to DIY  e30 differential removal. on Fri, 22 Jul 2011 21:45:20 GMT]]></title><description><![CDATA[<p dir="auto">haha they weren't actually hard, I was just dying to use the sawzall <img src="/assets/uploads/files/emoticons_default_biggrin.png" alt=":D" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/2029</link><guid isPermaLink="true">https://wibimmers.com/post/2029</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Fri, 22 Jul 2011 21:45:20 GMT</pubDate></item><item><title><![CDATA[Reply to DIY  e30 differential removal. on Fri, 22 Jul 2011 21:33:57 GMT]]></title><description><![CDATA[<p dir="auto">well thats one way to do it. those bolts which looked 'awfully hard' are actually a cinch.</p>
]]></description><link>https://wibimmers.com/post/2028</link><guid isPermaLink="true">https://wibimmers.com/post/2028</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Fri, 22 Jul 2011 21:33:57 GMT</pubDate></item><item><title><![CDATA[Reply to DIY  e30 differential removal. on Fri, 22 Jul 2011 00:47:11 GMT]]></title><description><![CDATA[<p dir="auto">Hey man, anyway we can help spread the good word <img src="/assets/uploads/files/emoticons_default_wink.png" alt=";)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/2025</link><guid isPermaLink="true">https://wibimmers.com/post/2025</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Fri, 22 Jul 2011 00:47:11 GMT</pubDate></item><item><title><![CDATA[Reply to DIY  e30 differential removal. on Fri, 22 Jul 2011 00:05:26 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for actually putting time in to do this write up.</p>
]]></description><link>https://wibimmers.com/post/2023</link><guid isPermaLink="true">https://wibimmers.com/post/2023</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Fri, 22 Jul 2011 00:05:26 GMT</pubDate></item><item><title><![CDATA[Reply to DIY  e30 differential removal. on Thu, 21 Jul 2011 21:30:24 GMT]]></title><description><![CDATA[<p dir="auto">Not at Autozone, but for a pack of PBR longnecks I'd rent it out for a day <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/2021</link><guid isPermaLink="true">https://wibimmers.com/post/2021</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Thu, 21 Jul 2011 21:30:24 GMT</pubDate></item><item><title><![CDATA[Reply to DIY  e30 differential removal. on Thu, 21 Jul 2011 21:26:00 GMT]]></title><description><![CDATA[<p dir="auto">Sweet! do they rent those bobcats at autozone? haha, honestly though, thats how you git'r'done.</p>
]]></description><link>https://wibimmers.com/post/2020</link><guid isPermaLink="true">https://wibimmers.com/post/2020</guid><dc:creator><![CDATA[Celina325is]]></dc:creator><pubDate>Thu, 21 Jul 2011 21:26:00 GMT</pubDate></item></channel></rss>
