<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Distributor rotor screws]]></title><description><![CDATA[<p dir="auto">Anyone have some good advice for removing the three torx screws that hold the distributor rotor in? Trying to replace my timing belt and can't get the rotor out of the distributor. Seems like they're torqued in at 500 ft/lbs. Already broke off one torx screwdriver in one of the screws, and felt like I was about to round out another one before I gave up and put everything back together.</p>
]]></description><link>https://wibimmers.com/topic/1976/distributor-rotor-screws</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:00:43 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1976.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Oct 2013 03:21:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Distributor rotor screws on Wed, 16 Oct 2013 01:51:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/29420">jc43089 said:</a></strong></p>
<p dir="auto">Also try putting the torx bit in the screw and then tapping on it with a hammer before trying to turn it, sometimes the jarring will help.</p>
<p dir="auto"> Yep.  Will try that too.  Plan on working on the distributor tomorrow.  If all goes well, and doesn't take too long, I may delve into the rest of the project too.</p>
]]></description><link>https://wibimmers.com/post/29526</link><guid isPermaLink="true">https://wibimmers.com/post/29526</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Wed, 16 Oct 2013 01:51:18 GMT</pubDate></item><item><title><![CDATA[Reply to Distributor rotor screws on Mon, 14 Oct 2013 13:22:34 GMT]]></title><description><![CDATA[<p dir="auto">Also try putting the torx bit in the screw and then tapping on it with a hammer before trying to turn it, sometimes the jarring will help.</p>
]]></description><link>https://wibimmers.com/post/29420</link><guid isPermaLink="true">https://wibimmers.com/post/29420</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 14 Oct 2013 13:22:34 GMT</pubDate></item><item><title><![CDATA[Reply to Distributor rotor screws on Mon, 14 Oct 2013 01:19:22 GMT]]></title><description><![CDATA[<p dir="auto">A coworker of mine said that if I soak them in WD40 for a bit first, and then use a short cheater bar with slow, steady pressure (along with a good quality torx bit), that they should break loose.  Think I'll try that on the two that don't have the bit broken off in them.  The other I'll probably have to drill from the way it sounds.</p>
]]></description><link>https://wibimmers.com/post/29403</link><guid isPermaLink="true">https://wibimmers.com/post/29403</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Mon, 14 Oct 2013 01:19:22 GMT</pubDate></item><item><title><![CDATA[Reply to Distributor rotor screws on Sun, 13 Oct 2013 19:55:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/29391">6670charger said:</a></strong></p>
<p dir="auto">OK, well, it sounds like maybe between some better torx bits and possibly some WD40 or similar, I might have some success.  I guess the good thing here is that this time I can work on the distributor first without having to take anything else apart and waste two hours worth of time like I did the last time.</p>
<p dir="auto">This should do the trick like Mike said. With my craftsman hex wrenches I was able to get mine off, it will take some force the first time to crack them loose. If anything breaks, its all cheap to replace anyways.</p>
]]></description><link>https://wibimmers.com/post/29392</link><guid isPermaLink="true">https://wibimmers.com/post/29392</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sun, 13 Oct 2013 19:55:39 GMT</pubDate></item><item><title><![CDATA[Reply to Distributor rotor screws on Sun, 13 Oct 2013 19:38:45 GMT]]></title><description><![CDATA[<p dir="auto">OK, well, it sounds like maybe between some better torx bits and possibly some WD40 or similar, I might have some success.  I guess the good thing here is that this time I can work on the distributor first without having to take anything else apart and waste two hours worth of time like I did the last time.</p>
]]></description><link>https://wibimmers.com/post/29391</link><guid isPermaLink="true">https://wibimmers.com/post/29391</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Sun, 13 Oct 2013 19:38:45 GMT</pubDate></item><item><title><![CDATA[Reply to Distributor rotor screws on Sun, 13 Oct 2013 03:58:52 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/29354">6670charger said:</a></strong></p>
<p dir="auto">You need better torx bits. Craftsman works and they will replace it if you do break it if you buy the Professional grade.</p>
]]></description><link>https://wibimmers.com/post/29379</link><guid isPermaLink="true">https://wibimmers.com/post/29379</guid><dc:creator><![CDATA[mkoepp]]></dc:creator><pubDate>Sun, 13 Oct 2013 03:58:52 GMT</pubDate></item><item><title><![CDATA[Reply to Distributor rotor screws on Sun, 13 Oct 2013 03:52:14 GMT]]></title><description><![CDATA[<p dir="auto">They will come out. Don't be afraid. If you do break one they are easy to drill out. Usually once the drill bites  the bolt it pushes the broken bolt through the back. I personally have never broken one but they do break loose with a "snap". </p>
<p dir="auto">"Just give her"</p>
<p dir="auto">Mike</p>
]]></description><link>https://wibimmers.com/post/29378</link><guid isPermaLink="true">https://wibimmers.com/post/29378</guid><dc:creator><![CDATA[mkoepp]]></dc:creator><pubDate>Sun, 13 Oct 2013 03:52:14 GMT</pubDate></item><item><title><![CDATA[Reply to Distributor rotor screws on Sat, 12 Oct 2013 03:40:57 GMT]]></title><description><![CDATA[<p dir="auto">Soak them in freeze off,pb blaster, or deep creap.</p>
]]></description><link>https://wibimmers.com/post/29355</link><guid isPermaLink="true">https://wibimmers.com/post/29355</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Sat, 12 Oct 2013 03:40:57 GMT</pubDate></item></channel></rss>
