<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1998 328i Radiator Replacement Leaking]]></title><description><![CDATA[<p dir="auto">Hey Guys,</p>
<p dir="auto">I just did my first major car repair, and swapped out my cooling system on my 1998 328i e36 following the guide on Pelican Parts! For the most part, it was a success (car didn't blow up), but I noticed a leak at my Nissens radiator's lower hose connector spot (neck?). I loosened and retightened the hose clamp, and when I made it pretty darn tight I noticed the leak slowed down significantly, but it's still there. I noticed the connector has more of a lip than the ribbed connection that the stock radiator had... so maybe the hose clamp isn't in the most optimal position. Any of you had this issue and fix it without swapping the radiator? Googling this specific issue seems a lot of people have issues with the Nissens radiator in this exact spot...</p>
<p dir="auto">Do you guys think I need to grab a new radiator, one that has the multi-ribbed necks vs. the single-rib that Nissens has, or should I just try to reseat the hose &amp; clamp until I can get it to stop dripping.</p>
<p dir="auto">Any feedback would be great!!</p>
]]></description><link>https://wibimmers.com/topic/1962/1998-328i-radiator-replacement-leaking</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:57:17 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1962.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Oct 2013 17:45:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1998 328i Radiator Replacement Leaking on Wed, 09 Oct 2013 11:52:06 GMT]]></title><description><![CDATA[<p dir="auto">reseat the hose and run 2 clamps with the adjusters staggered</p>
]]></description><link>https://wibimmers.com/post/29201</link><guid isPermaLink="true">https://wibimmers.com/post/29201</guid><dc:creator><![CDATA[industrialsized]]></dc:creator><pubDate>Wed, 09 Oct 2013 11:52:06 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 328i Radiator Replacement Leaking on Wed, 09 Oct 2013 10:34:58 GMT]]></title><description><![CDATA[<p dir="auto">Is the neck possibly cracked?</p>
<p dir="auto"><a href="http://forums.bimmerforums.com/forum/showthread.php?1192187-Nissen-better-then-Behr-radiator" rel="nofollow ugc">http://forums.bimmerforums.com/forum/showthread.php?1192187-Nissen-better-then-Behr-radiator</a></p>
]]></description><link>https://wibimmers.com/post/29197</link><guid isPermaLink="true">https://wibimmers.com/post/29197</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 09 Oct 2013 10:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 328i Radiator Replacement Leaking on Wed, 09 Oct 2013 07:12:55 GMT]]></title><description><![CDATA[<p dir="auto">Try to reset the hosr position. If that doesn't work then replace the hose.</p>
]]></description><link>https://wibimmers.com/post/29196</link><guid isPermaLink="true">https://wibimmers.com/post/29196</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Wed, 09 Oct 2013 07:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 328i Radiator Replacement Leaking on Tue, 08 Oct 2013 18:04:56 GMT]]></title><description><![CDATA[<p dir="auto">I replaced upper, lower, and expansion tank hoses. I didn't replace the return hose because I didn't quite understand the system when I ordered parts, and it goes way back there so it would have been a bitch anyways!</p>
<p dir="auto">Yes, this hose was replaced.</p>
]]></description><link>https://wibimmers.com/post/29176</link><guid isPermaLink="true">https://wibimmers.com/post/29176</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Tue, 08 Oct 2013 18:04:56 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 328i Radiator Replacement Leaking on Tue, 08 Oct 2013 17:49:09 GMT]]></title><description><![CDATA[<p dir="auto">Are you using old hoses or did you install new hoses?</p>
]]></description><link>https://wibimmers.com/post/29174</link><guid isPermaLink="true">https://wibimmers.com/post/29174</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Tue, 08 Oct 2013 17:49:09 GMT</pubDate></item></channel></rss>
