<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[e46 rear brake issues... HELP ASAP]]></title><description><![CDATA[<p dir="auto">ok I guys im finally throwing the damn towel in my pass rear brake keeps hanging up and getting hot as hell and I have no idea whats causing it... the caliper piston presses in just fine when I had to change the rear pads due to the pass rear side getting eaten and the pins move freely as well and I also tried driving with my dsc on and off and that made no difference.</p>
]]></description><link>https://wibimmers.com/topic/1879/e46-rear-brake-issues...-help-asap</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:46:04 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1879.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Sep 2013 00:27:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to e46 rear brake issues... HELP ASAP on Sun, 15 Sep 2013 03:57:38 GMT]]></title><description><![CDATA[<p dir="auto">It could also be the rubber hose. The hose could be acting as a check valve, basically, holding the brakes tight. I believe they make a caliper rebuild kit also. If so, the guys on e46fanatics would have a DIY. For what its worth, do both.</p>
]]></description><link>https://wibimmers.com/post/27981</link><guid isPermaLink="true">https://wibimmers.com/post/27981</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Sun, 15 Sep 2013 03:57:38 GMT</pubDate></item><item><title><![CDATA[Reply to e46 rear brake issues... HELP ASAP on Sat, 14 Sep 2013 01:08:52 GMT]]></title><description><![CDATA[<p dir="auto">Replace the caliper. I've had the same issue, worked for me.</p>
]]></description><link>https://wibimmers.com/post/27959</link><guid isPermaLink="true">https://wibimmers.com/post/27959</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Sat, 14 Sep 2013 01:08:52 GMT</pubDate></item></channel></rss>
