<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[100 shots of nitrous or more]]></title><description><![CDATA[<p dir="auto">Okay So what exactly do i need to run more then 100 shots of nitrous on my 1999 m3, i need step by step, im trying to go for a higher wet shot..</p>
]]></description><link>https://wibimmers.com/topic/1734/100-shots-of-nitrous-or-more</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:04:09 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1734.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Aug 2013 00:49:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 100 shots of nitrous or more on Sat, 10 Aug 2013 18:25:55 GMT]]></title><description><![CDATA[<p dir="auto">im using zex nitrous kit i got the fuel line and the nitrous line  ill post up pictures soon..</p>
]]></description><link>https://wibimmers.com/post/26441</link><guid isPermaLink="true">https://wibimmers.com/post/26441</guid><dc:creator><![CDATA[m3clubbmw]]></dc:creator><pubDate>Sat, 10 Aug 2013 18:25:55 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Wed, 07 Aug 2013 03:36:31 GMT]]></title><description><![CDATA[<p dir="auto">is this a wet kit? is there a fuel line and a nitrous line? what brand is it? can you poast a picture of it?</p>
]]></description><link>https://wibimmers.com/post/26350</link><guid isPermaLink="true">https://wibimmers.com/post/26350</guid><dc:creator><![CDATA[industrialsized]]></dc:creator><pubDate>Wed, 07 Aug 2013 03:36:31 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 20:56:16 GMT]]></title><description><![CDATA[<p dir="auto">all im using is the wideband gauge to monitor the fuel ratio, im using 93 oct fuel, i have AA long tube headers, the nitrous has a switch that i can on and off when on it activates at full throttle</p>
]]></description><link>https://wibimmers.com/post/26345</link><guid isPermaLink="true">https://wibimmers.com/post/26345</guid><dc:creator><![CDATA[m3clubbmw]]></dc:creator><pubDate>Tue, 06 Aug 2013 20:56:16 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 20:16:00 GMT]]></title><description><![CDATA[<p dir="auto">As you mention a wet shot in the first post, where did you tap for fuel?   Are you monitoring the health of the engine at all, such as fuel pressure, AFR and/or EGT?</p>
<p dir="auto">Are you using a window switch?  Any type of controller as industrialsized referred to?  Have you tried simply swapping jets?  Have you done any research about safely using nitrous?</p>
]]></description><link>https://wibimmers.com/post/26341</link><guid isPermaLink="true">https://wibimmers.com/post/26341</guid><dc:creator><![CDATA[Narcosis]]></dc:creator><pubDate>Tue, 06 Aug 2013 20:16:00 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 19:59:33 GMT]]></title><description><![CDATA[<p dir="auto">im running 75 shot, but i want to know wat do i need to do to run 100 shot safely, or 125.</p>
]]></description><link>https://wibimmers.com/post/26339</link><guid isPermaLink="true">https://wibimmers.com/post/26339</guid><dc:creator><![CDATA[m3clubbmw]]></dc:creator><pubDate>Tue, 06 Aug 2013 19:59:33 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 12:25:19 GMT]]></title><description><![CDATA[<p dir="auto">Do you currently have a nitrous setup?  If so, what's the configuration?  What's your power goal, as well as overall goal for the car?</p>
]]></description><link>https://wibimmers.com/post/26319</link><guid isPermaLink="true">https://wibimmers.com/post/26319</guid><dc:creator><![CDATA[Narcosis]]></dc:creator><pubDate>Tue, 06 Aug 2013 12:25:19 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 07:32:46 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://www.grillwilson.com/site/wp-content/uploads/2012/01/4fast_Gif_13-193_thumb.gif" alt="4fastGif13-193thumb.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/26316</link><guid isPermaLink="true">https://wibimmers.com/post/26316</guid><dc:creator><![CDATA[Black M car]]></dc:creator><pubDate>Tue, 06 Aug 2013 07:32:46 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 04:30:03 GMT]]></title><description><![CDATA[<p dir="auto">untrue earl</p>
<p dir="auto">i'm not going to give you a step by step because im sure that you are more than capable of doing a google serch but I will give you some tips and if you need it and i can hopefully anwser some specific questions if you have any. and its not "shots" it's shot. a 100shot is a rough calculation of the amout of HP increase the nitrous is giving you when flowing. if you want to add more than around 50% of the motors power with nitrous the best way to go is with a "progressive controler"or at minumum multipule stages it will pulse the nitrous and fuel solenoids much like a fuel injector and gently add hp untill you solinoids can't flow any greater volume because of internal oriface restrictions at that point you will want to add larger solenoids or multipule solenoids. the reason you need to meter nitrous is because of the instantanious reaction it has in a gasoline engine the impact on the pistons, rods,crank, ect. must be regulated to insure that the inital hit of the nitrous wont cause catastrophic failure of any one engine component, you must soften the inital impact or VERY BAD THINGS WILL HAPPEN. that said nitrous is one of if not the most cost efective and safe power adders when controled. the only real issue with useing nitrous on older motors is that if the compression rings arnt in good shape the nitrous will find its way into the top pistion grove and slowly from the small amouts that colect in the grove exploding with the rest of the air fuel mixture strech the ring grove and eventualy peel it off the top of the piston.</p>
<p dir="auto">I'm confedent that any of the m5x famliy of engines are well suited to the use of nitrous in stock form. given the crank support very strong rods and relitivly tight tolerances i'm sure that given the proper controlers they can withstand in excess of 200% power increases.</p>
<p dir="auto">the biggest tip i can give you is always run redundant fuel solenoids its really bad when one fails and your motor goes pop!</p>
]]></description><link>https://wibimmers.com/post/26309</link><guid isPermaLink="true">https://wibimmers.com/post/26309</guid><dc:creator><![CDATA[industrialsized]]></dc:creator><pubDate>Tue, 06 Aug 2013 04:30:03 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 01:53:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/26300">m3clubbmw said:</a></strong></p>
<p dir="auto"> im trying to go for a higher wet shot..</p>
<p dir="auto"><img src="http://static.giantbomb.com/uploads/original/4/40057/2482831-archer-1-phrasing.jpg" alt="2482831-archer-1-phrasing.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">what earl said. boost it.</p>
]]></description><link>https://wibimmers.com/post/26306</link><guid isPermaLink="true">https://wibimmers.com/post/26306</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Tue, 06 Aug 2013 01:53:03 GMT</pubDate></item><item><title><![CDATA[Reply to 100 shots of nitrous or more on Tue, 06 Aug 2013 01:16:58 GMT]]></title><description><![CDATA[<p dir="auto">Absolutely no one here runs or cares to run nitrous. I'm sure you can find a thread someone telling you what you need. I highly suggest boosting the car or buying a different car instead.</p>
]]></description><link>https://wibimmers.com/post/26303</link><guid isPermaLink="true">https://wibimmers.com/post/26303</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Tue, 06 Aug 2013 01:16:58 GMT</pubDate></item></channel></rss>
